IFR checkride in fs2004
Old September 24th 04, 10:10 PM
Amit Dhingra
Default IFR checkride in fs2004
This is the one based in Seattle when you have to make a missed approach on
runway 34R. I make the missed approach at altitude 900 ft. But still I am
announced failed as a went 'below' the missed approach height of 840 ft.
Done it multiple times now. A little frustrating. Any ideas?
Thanx
Amit
Old September 24th 04, 11:18 PM
Greasy Rider
"Amit Dhingra" wrote in message
on
Fly somewhere else?
Old September 25th 04, 12:04 AM
Matthew Chidester
make sure your alt setting is correct.. press M and then B during flight..
one will fix the DG and the other will fix the alt -
then try it again and make sure you don't go below mins. you should be able
to do it - I think 1ft under and you busted.
good luck
Matthew
Old September 25th 04, 12:46 AM
Icebound
on
Thanx
Amit
There are some bugs in the checkride and some peculiarities. The first bug
is that the track from FACTS to SEA is actually 340 not 338, but the checker
is checking against 338.
1. You have to set the VOR to SEA and turn the OBS to 338 within 30
seconds.
2. You have to stay within 50 feet below and 100 feet above the required
altitude. Try to stay at or above the requested altitude.
3. You have 2 minutes to turn to 338 and head north.
4. Once the 2 minutes are up, you cannot correct more than 10 degrees off
338
5. You must pass each of the checkpoints at the published altitude (+ or -
tolerance). The key DMEs from SEA are 17.0, 11.0, and 4.4. You cannot cross
"high", which would normally be acceptable in real life, I believe.
6. you must climb out on the go-around at 500 feet per minute. If you drop
below 200 fpm, you fail.
2. You cannot correct more than + or - 10 degrees off 339 on the way up on
the missed approach.
Then the fun really starts when you go to the next task: the hold.
Old September 25th 04, 02:39 AM
Matthew Chidester
good grief.. I've never tried the lesson but sheesh i'm instrument rated in
real life and I bet i'd fail that dumb thing..
Old September 25th 04, 12:24 PM
Benny Jørgensen
Hi'
I wonder if the limit is + - 50 feet ????
Happy Landings
Benny
"Amit Dhingra" skrev i en meddelelse
on
Thanx
Amit
Old September 27th 04, 04:50 PM
James Hodson
On Fri, 24 Sep 2004 23:04:31 GMT, "Matthew Chidester"
Hi Matthew
I'm aware of the effects of pressing the key "B" but what does
pressing "M" achieve?
Cheers
James
Old September 27th 04, 05:23 PM
Matthew Chidester
M or B (I can't remember which) resets the heading indicator - sometimes
you have to set it every 15 min. because it replicates the pressision or
whatever you call it that the gyro.. depends on your realism setting but it
could mess up your IFR test if you're heading in the wrong direction, even
though you think you're lined up correctly. The other of course sets your
alitmeter to the correct setting for alt.
ok this isn't making sense but "m" resets the heading indicator to the true
heading (compass heading) so ususally I hit M, and B
hope that made sense,
Matthew
Old September 29th 04, 03:37 PM
James Hodson
On Mon, 27 Sep 2004 16:23:20 GMT, "Matthew Chidester"
I certainly did, I think. I've achieved the same by twiddling the knob
and wasn't aware of a keyboard shortcut.
James
Old September 29th 04, 03:49 PM
Matthew Chidester
James
glad to help wish I knew all the shortcuts.
Matthew
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
9800 Pro & FS2004 Skyhawk Simulators 4 September 30th 04 09:37 PM
Bridges in FS2004 Kevin Reilly Simulators 18 October 2nd 03 11:00 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
