Is anyone still interested in CuSoft "Polar Explorer" program for PC?
Old July 26th 03, 12:32 AM
Branko Stojkovic
Default Is anyone still interested in CuSoft "Polar Explorer" program for PC?
Hello,
Sme 10 years ago I wrote a program for DOS named "Polar Explorer" - designed
for analyzing both theoretical and practical aspects of glider performance
in any conditions. The program was advertised in the Soaring magazine for a
couple of years by CuSoft Research Inc., and some 30 odd copies sold for USD
99 each.
If anyone is interested in this program (see the short description below), I
will consider posting it on my current company's website: www.trimill.com
Sincerely,
Branko Stojkovic
SHORT DESCRIPTION
Polar Explorer is designed to answer many `specific` questions about glider
performance. As a result, you can use it for many different purposes. The
following are a few examples of what you can do:
Complement the books and articles on glider performance and soaring tactics
by working out practical examples.
Find out the `optimum circling technique` for any glider at any altitude and
wing loading.
Plan and analyze cross-country flights and final glides.
Optimize configuration and wing loading in any weather conditions.
Apply `generalized speed-to-fly theory` to maximize cross-country
performance when using ridge lift or waves.
Compare circling and cross-country performances in addition to comparing
polars.
Design and test speed rings and final glide computers, for any altitude and
wing loading.
Enter and analyze any glider polar that you come across. The glider polar
library that comes with the program already contains 150 polars (see below).
If you are contemplating any modifications to your sailplane (e.g. adding
winglets), you can use Polar Explorer's advanced features to estimate the
performance gains.
Polar Explorer 2.1 ? Polar Library
Sources of Polars:
(J) Flight Test Evaluations of... by Richard H. Johnson published in the
Soaring magazine.
(D1) Flugmessungen mit 25 Segelflugzeugen by H. Laurson and H. Zacker, DFVLR
Institute, Germany, (1972)
(D2) Flugmessungen an 35 Segelflugzeugen und Motorseglern by H. Laurson and
H. Zacker, DFVLR Institute, Germany, (1976)
(D3) Flugmessungen mit Segelflugzeugen von 12 bis 13 M Spannweite by Hans
Zacher, DVL, München-Riem, Germany, (1965)
(D*) German Test Data
(M) Flight performance measurements on twelve sailplanes by H. J. Merklein
and H. Zacher, Scientific Flight Research Establishment Munich , (1964).
(C) Calculated polar published by the manufacturer
1. Ahrens Delphin V2 (D3)
2. AK 1 /D KEUL (D2)
3. ASH 25 /N80WK/#4 (J)
4. ASH 26E (C)
5. ASK 13 /D 2018 (D1)
6. ASK 16 /D KEIK (D2)
7. ASK 21 /N362KS/#225 (J)
8. Astir CS /D 7290 (D2)
9. ASW 15 /D 0510 (D1)
10. ASW 15 /D 0791 (D1)
11. ASW 17 /N45JD (J)
12. ASW 17/20m /D 1110 (D2)
13. ASW 17S/21m /D 2119 (D2)
14. ASW 19 /D 4525 (D2)
15. ASW 19 /N19KL (J)
16. ASW 20 /N104WR/#17 (J)
17. ASW 20 [ 9] /N104WR/#17 (J)
18. ASW 20 [8,0] /N104WR/#17 (J) [Flaps +8 & 0 deg]
19. ASW 22/22m /N2702J/#15 (J)
20. ASW 22/24m /N2702J/#15 (J)
21. ASW 24 (D*)
22. ASW 27 (C)
23. Bergfalke II /D 1217 (M)
24. Bergfalke III /D 1737 (D1)
25. Bergfalke IV /D 1005 (D2)
26. Blanik L 13 (C)
27. Bocian /D 1578 (M)
28. Calif A 21 S /D 2176 (D2)
29. Cirrus /D 0471 (D1)
30. Cirrus /D 0471 (D2)
31. Club Libelle /D 3695 (D2)
32. D 34 b Aphrodite/D 4607 (M)
33. D 34 d (D3)
34. D 34 d /D 4607 (M)
35. D 36 V1 /D 4685 (D1)
36. D 37 Artemis /D 2278 (D2)
37. D 37 Artemis /D KEDD (D2)
38. D 38 /D 0938 (D2)
39. DG 300 /N33HB/#E47 (J) [Sealed, clean holes]
40. DG 100 /D 1076 (D2)
41. DG 100 /D 7099 (D2)
42. DG 101 G /N101TX/#E168 (J)
43. DG 200 /N200GA/#2 101 (J)
44. DG 600/15 /N70205 (J) [15m; No winglets]
45. DG 600/15W /N70205 (J) [15m; With winglets]
46. DG 600/17 /N70205 (J) [17m]
47. Discus A /N52XX/#33 (J) [sealed)
48. Discus A [W] /N52XX/#33 (J) [Ballasted]
49. Elfe S3 /HB 902 (D1)
50. Elfe S4 /D 6301 (D2)
51. Elfe S4 /D 6668 (D2)
52. FK 3 /D 0292 (D1)
53. FS 24 Phonix T /D 8385 (M)
54. FS 25 Curevo /D 8141 (D1)
55. FS 29 13.8m /D 2929 (D2)
56. FS 29 16m /D 2929 (D2)
57. FS 29 19m /D 2929 (D2)
58. FS 29 all /D 2929 (D2)
59. Glasflugel 604 /D 8085 (D2)
60. Glasflugel 604 /N57L (J)
61. Glasflugel 604 mod./N57L (J) [Corrected profile]
62. Grob 102 Club IIIb/N3981A (J ) [/#5610 Sealed]
63. Grob 103 Twin II /N427BG (J
64. Grob 103 Twin II mod. (J) [Mod. wheel fairings]
65. Grob 103C Twin III (J) [#34107]
66. Grob 109B /N300BG/#6390 (J)
67. H 101 Salto /D 2040 (D1)
68. H 201 St.Libelle/D 0082 (D1
69. H 301 Libelle /D 9412 (D1)
70. H 401 Kestrel /D 0245 (D1)
71. Hi 25 Kria (D3)
72. Hornet /D 7816 (D2)
73. J 4 Javelin /N5TF (J)
74. Jantar 1 /N46DB (J)
75. Jantar 2A /N980 (J)
76. Jantar Std. /N51AS/#880 (J)
77. Jantar Std. /SE TOI (D2)
78. Jantar Std.2 /N45AS/#863 (J)
79. Janus /D 3111 (D2)
80. Janus /N468F (J)
81. Jaskolka Z O SZD 8ter (M) [FFM /HB 604]
82. K 7 /D 1800 (M)
83. K 8 /D 1590 (M)
84. K 8 KM 48 /D KIBO (D1)
85. Ka 6 BR/S /D 8390 (M)
86. Ka 6 CR (D3)
87. Ka 6 CR /D 1810 (D1)
88. Ka 6 CR /D 1810 (D2)
89. Ka 6 CR /D 4390 (M)
90. Ka 6 E /D 3657 (D)
91. Kestrel /D 0475 (D2)
92. Kestrel 19(T59D)/D 5999 (D2
93. KORA 1 /D KORT (D2)
94. Kranich III /D 1398 (M)
95. LCF 2 /D 6446 (D2)
96. LS 1 C /D 0558 (D1)
97. LS 1 F /D 3252 (D*)
98. LS 1 F /D 3252 (D2)
99. LS 3 /N45EW (J)
100. LS 4 /D 2628 (D*)
101. LS 4 /D 2628; W/S=34.4 (D
102. LS 4 /D 6680 (D*)
103. LS 4A /N274W/#321 (J)
104. LS 4A /N430RH/#384 (J)
105. Mini Nimbus /N871T/#16 (J) [Seals installed]
106. Mistral /D 4998 (D2)
107. Mosquito /N46898 (J)
108. Mu 22 b /D 1848 (D1)
109. Mu 26 /D 0726 {1971} (D1)
110. Mu 26 /D 0726 {1972} (D1)
111. Nimbus 3/22.9 /N49JD/#19 (J)
112. Nimbus 3/24.5 /N49JD/#19 (J)
113. Nimbus 3/24.5 Mod. (J) [Profiled wing]
114. Nimbus II /D 0107 (D1)
115. Nimbus II /D 0699 (D1)
116. Nimbus II /D 2111 (D2)
117. Nimbus II Smooth /N45DJ (J) [Smoothed wings]
118. Phoebus C /D 0559 (D1)
119. Pik 20 A /OY XCR (D2)
120. Pik 20 A.I. /N100DC/#8 (J) [With ail. interconn]
121. Pik 20 B Mod. /N46JD (J) [Mod. wing leading edge]
122. Pik 20 D 78 /N19YZ (J)
123. Pik 20 No AI /N100DC/#8 (J) [No ail. interconn.]
124. Pilatus B4 PC11 /HB 1127(D2
125. RF 5 B Sperber /D KOKS (D2)
126. Sagitta /PH 319 (D1)
127. Salto 15 mod. /D 2220 (D2)
128. SB 10 /D 6085 (D2)
129. SB 8 V2 /D 6085 (D1)
130. SB 9 /D 6085 (D1)
131. Schweizer 1 26E /N33904 (J) [#634]
132. Schweizer 1 35 /N17976 (J)
133. Schweizer 1 36 /N362IT (J)
134. SF 27 A /D 6068 (D1)
135. SF 28 Tandem /D KFAJ (D2)
136. SF 30 Club Spatz /D 3697(D2
137. Skylark 3 F /RAF 146 (M)
138. Std. Cirrus /D 0483 (D1)
139. Std. Cirrus /D 3261 (D2)
140. Std. Cirrus B /N5CC (J)
141. Std. Cirrus/16m /D 3261 (D2
142. SZD 30 Pirat /D 3660 (D1)
143. SZD 55 1 /N3176T (J)
144. Vega /N3751Q/#1927 (J)
145. Ventus A /N47JD/#29 (J)
146. Ventus A/16.6 (J) [Original wing]
147. Ventus A/16.6 Mod. (J) [Profiled wing]
148. Ventus B /N139P (J)
149. Zuni /N14XZ/#14 (J)
150. Zuni [ 8.8] /N14XZ/#14 (J) [Flaps 8.8 deg])
151. Zuni [0] /N14XZ/#14 (J) [Flaps 0 deg])
Old July 26th 03, 01:06 AM
John Giddy
Branko,
Do you know if it will run correctly under the "DOS Window"
of various flavours of Windows, or does it need a pure DOS
environment ?
John G.
"Branko Stojkovic" wrote in message
| Hello,
glider performance
copies sold for USD
| 99 each.
www.trimill.com
| Sincerely,
| Branko Stojkovic
| SHORT DESCRIPTION
and soaring tactics
at any altitude and
| wing loading.
conditions.
cross-country
| polars.
any altitude and
| wing loading.
The glider polar
polars (see below).
to estimate the
| performance gains.
| Sources of Polars:
published in the
| Soaring magazine.
by H. Laurson and
Spannweite by Hans
by H. J. Merklein
Munich , (1964).
| 4. ASH 26E (C)
| 21. ASW 24 (D*)
| 22. ASW 27 (C)
| 26. Blanik L 13 (C)
| 33. D 34 d (D3)
| 71. Hi 25 Kria (D3)
| 82. K 7 /D 1800 (M)
| 83. K 8 /D 1590 (M)
| 86. Ka 6 CR (D3)
| 99. LS 3 /N45EW (J)
Commercial polar routes? General Aviation 6 January 28th 05 08:03 PM
Jon Johanson..Long delete if not interested Jerry Springer Home Built 0 December 21st 03 05:55 PM
LX 1000 polar calibration Vignaud Frédéric Soaring 0 July 14th 03 05:14 PM
