Shirley wrote:
"Liam Finley" wrote... On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. Unless that was said "tongue-in-cheek", that's just plain ignorant. You don't have to like it, but Schweizer has its place. Not everyone who loves to go places and drive has to do so in a Ferrari to enjoy the trip! --Shirley Well put, Shirley! john |
F.L. Whiteley wrote:
Atkins, 22lbs between Thanksgiving and Easter and a little more since. Although I bike 45-60mins most days, exercise won't do it all. When I did high impact step in the mid-90's, I got into very good condition;^) and gained 25lbs;^( Frank Whiteley Yep, I'm doing the Atkins...that worked well for a friend of mine also. I guess gliding just gives me one more incentive to add to the long list of incentives to slim down ![]() john |
As a single seater consider the Lak 12 ,a bear to rig if you don't have the
rigging gear but is a huge cockpit and a max placarded weight 140kg - 150kg without tailballast.and 50/1 ld I saw a pilot who put even put one on its nose while waiting for takeoff "JohnH" wrote in message et... Hello, I'm just now learning about Gliding and will start instruction soon. Question: I'm 6ft tall and weigh 232 lbs. Have I weighed myself out of many sailplane options? I DO plan on losing some more weight, but just in case I don't, would appreciate some knowledge on this ![]() instructor said I'm ok for the trainer I'll be flying in. Thanks in advance john |
![]() "Liam Finley" wrote in message m... unicate (Shirley) wrote in message ... "Liam Finley" wrote... On the other hand, if you are content to fly Schweizer junk your whole life, you've got nothing to worry about. Unless that was said "tongue-in-cheek", that's just plain ignorant. You don't have to like it, but Schweizer has its place. Not everyone who loves to go places and drive has to do so in a Ferrari to enjoy the trip! --Shirley Not ignorance. I've more time in Schweizers than most US pilots have in the air total. Yes, they have their place, it's called an aluminum recycling plant. Arrogance perhaps then? |
"Guy Byars" wrote in message ...
If you want to move into high performance single seaters, your options will be somewhat restricted, but you'll manage to find something. Its typical for Euro gliders to come out of the factory with a max cockpit load of 242 lbs (110 kg.), but that often gets reduced when extra equipment is installed. Most high performance gliders have provision to store ballast in the tail. This could increase the minimum cockpit weight. You will have to reduce the water ballast accordingly to stay below gross weight. I will assume you meant "maximum" cockpit weight. Isn't water ballast a different issue from fuselage weight? In other words, it may be perfectly ok, structurally, to add 300 lbs of water in the wings but that same 300 lbs added to the fuselage (with pilot) would not be ok. The issue is the structural limits of attachment of the fuse to the wings, I believe. Perhaps I simply misread your message and this is not what you were implying. But I add this comment just to make the issue clear to the original poster. Water in the wings does not stress the attachment of the fuse. -Doug |
![]() "Andy Blackburn" wrote in message ... Atkins - 35 lbs. in 2.5 mos. Watch the cholesterol though. When I was first looking seriously at soaring, weight was an issue. I went the low-fat route, lost about 50 pounds, and haven't looked back. It also got me off cholesterol medication. Like all diets, low fat has its medical caveats. Low fat products tend to substitute sugar for fat to add taste; watch your blood sugar. Vaughn |
The real problem with Schweizer sailplanes it the quality of the gelcoat.
GA |
JohnH wrote:
have also received some encouraging and enlightening emails. I apparently am not the only one on this board that has been fighting the pilot weight problem ; I weigh 220 and I should probably weigh about 170. I fly powered planes and I've just started soaring. I don't really know about soaring, since I just started and my instructor is a beanpole, but in powered planes, my biggest problem has been how many passengers I can take. Right now I can get 2 adults and 1 kid, but if I lose the 50 lbs., I can take 3 adults (assuming that one of them is a woman, probably). Also, when I fly solo, it means that I could take an extra 9 gallons (1 hour) of fuel on board. In any case, don't let it bother you -- flying and soaring both kick ass! Even if you have to fly in big clunky junk, it's still better than not flying at all. - awh |
in the air total. Yes, they have their place, it's called an aluminum recycling plant. What a coincidence! I was just opening such a plant! Anyone wanting to discard their Schweizer please bring it to me and I will happily pay the going recycle rate. (Sanford and Sons theme plays in the background, then Sir Mix-A-Lot lyric "pull up quick to git widdum") Hmmm...620,000 US pilots, 130K US pilots with Airplane ATP (1500+ hrs). Average US pilot, must have well over 300 hrs. So Liam has over 300 hours in Schweizers. How'd he do that since they're such hunks of junk? Perhaps a LOT of time on tow... :PPPP |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 12:23 AM |
