Eric Greenwell wrote in message ...
In article , says... Imagine compensating for a crosswind the correct way -- with crab angle. Then you decide, "Gosh, I'm high. I think I'll slip." The resulting slip would point the nose closer to parallel with the runway centerline. But for some reason, we need to differentiate this slip from one that puts the nose askew. Assuming this isn't a troll, perhaps you could expound on why crabbing is correct and side slipping isn't for dealing with a cross wind on final approach. I've tried both, and the side slip seems to work just as well, and more easily. Ok, here's MY attempt to define the terminology; ON FINAL.... IF you are holding the fusalage aligned with the runway, with a wing down slightly, most call this a side slip, maybe because you are holding your track true across the wind by slipping sideways to cancel out the relative crosswind. Your heading & bearing are the same. IF you are flying coordinated, and you are not flying directly up or down wind, you are "crabbing" along the ground, your heading & your bearing being different. If you're too high & decide to slip off altitude, you are doing a forward slip, because there you were, lined up with the runway, and you boot full rudder & steer with the stick so that you are still "going forward" in the same direction you were before. Put another way, if you're looking over the nose with a wing down, you're slipping sideways. If you're looking out the side window in the direction you're going, you're slipping forward towards your goal. If this explains it, send me a dollar. If Im all wrong, I don't want to know. It works for me. -Dan |
Dan,
You've got it right, at least the way that most of us are taught. But let me clarify something that we aren't typically taught. Aerodynamically speaking, there is no difference between a forward and a side slip. One is used during final for crosswind landings in order to align the fuselage with the runway throughout the final leg of you pattern. However, it is, in term of how you use the controls, exactly the same as any other slip. The difference is that you are executing the slip along with a crab. That is, if you exit the slip, you will have a crab angle that aligns your track with the runway. The only reason I bring this up is that I've seen a thread that suggests that there is a difference between a forward and side slip. That the forward slip (by tilting the lift vector) somehow compensates for a crosswind. Of course, it does not. Only crab angle compensates for crosswind with respect to the ground. The slip simply aligns the fuselage with the runway, at the cost of some glide performance. This technique is very useful for smooth crosswind landings in high wing taildraggers, where there is an advantage to setting one main gear on the ground rather than both at once. It is not nearly so applicable to gliders, though many of us were taught to compensate for crosswinds this way. It has some minor advantages... the upwind wing is "low" at touchdown, less finesse is required with the rudder... but also has some disadvantages... the controls are crossed, the airspeed indicator is unreliable, the glider will not achieve maximum performance if sink or turbulence is encountered, there is some risk of touching a wingtip if the flair is not properly executed. But most important, many pilots seem not to realize that they are, in fact, using the slip not to compensate for crosswind, but to align the nose with the runway in order to gain a more "normal" view of the approach. That is its only real value. Giving a slip different names based on its application only perpetuates the confusion. And I guess that's my point. To sum up: A slip is aerodynamically the same, regardless of wind. A slip always increases drag. A slip can be used to align the nose with the runway during a crosswind approach (match heading with track), at the cost of additional drag. A tangent to the orignal thread, more concerned with semantics than application, but I thought I'd turn the discussion in this direction. Cheers. |
Buck & Eric,
go with what you know. If you are comfortable using a slip to align the nose with the runway, it's a perfectly reasonable way to compensate for crosswind. However, I must once again take exception to the notion that tilting the lift vector compensates for crosswind. This is simply wrong. Draw some pictures to work your way through the problem. Tilting the lift vector produces a turn, regardless of wind. The turn will continue so long as the wings are banked. If, however, you use opposite rudder to counteract the turn, you are creating a force with the fuselage to balance the inward component of your lift. That is, the forces are balanced... You will continue to fly straight. A slip only increases drag by presenting more of the fuselage to the relative wind. It is stable, straight line flight. An unbalanced force (like tilting the lift vector) creates an acceleration, which means that either your speed or direction changes. Remember, that for an aircraft in the air, the wind is not a force. Since the aircraft moves with the airmass, there is no wind. So tilting a lift vector against "the wind" is meaningless. If the airmass is moving with respect to the ground, you establish a desired track across the ground by crabbing. (When was the last time you flew x-country from point A to point B in a slip?) The difficulty comes when we need to transition from the air to the ground. The moment the wheels touch the ground, the wind becomes an unbalanced force, and we need to make control inputs to deal with it. There are two techniques. We know them both. But be clear, we compensate for airmass movement using a crab, not a slip. Transition to the ground is achieved by momentarily crossing the controls. I prefer to do this during the flair. Others choose to initiate that process after turning base. It's a matter of preference. I like my yaw string straight and my airspeed indicator dependable when near the ground. (Eric, note that your visual and aural cues become less trustworthy when near the ground or when flying sideways.) Again, a matter of choice. But let's get off this notion that a tilted wing cancels out the effect of wind. It doesn't, at least, not while you are in the air. To establish a track down the runway you are crabbing. To align the fuselage parallel with the rundway, you are slipping. You may initiate both simultaneously, but they are distinct actions and serve very different purposes. This is building block stuff, which is why I'm still beating it. |
"Ian Johnston" wrote in message news:cCUlhtvFIYkV-pn2-w2Ux5bntNpQz@localhost...
On Thu, 11 Sep 2003 16:21:48 UTC, (Chris OCallaghan) wrote: : Tilting the lift vector produces a turn, regardless of wind. panto Oh no it doesn't /panto All a sideways tilt in the lift vector tries to do is move the glider sideways. Whether or not that results in a turn depends on what you do with the rudder. Ian Um, I think it is the stabilizer/elevator instead of the rudder. Jet Jocks call it "Bank and Yank." NB. I posted this twice; here the second time through Google Groups. For some reason the Glider Net refuses my posts, saying I have illegal attachments. I notice that neither place picks up all the posts on the subject. This is one of the funniest threads I've read. Almost everyone makes a good argument, but includes at least one undefensable statement. |
