Jet Cat P200 read ad ......
Old September 15th 03, 03:37 PM
TomnKeyLargo
Default Jet Cat P200 read ad ......
That price Ian gave and trust of 42 lbs. was before the motor was completed.
The ad even says available this fall. Its on Jet Cat USA web page, and its a
old ad. I have been in touch with the dealer and the price is about $3200 bucks
and the Jet Cat P200 now produces 50 lbs of thrust. There are several other
companys that make small Jet turbines, I have seen thrust ratings now at 150
lbs. which would be more than enough for self launch. The fin idea was thought
of, but remember that some of the thrust comes from the sucking action of the
motor. The exhaust is 660 C's. If you mount it like a motorglider engine it
will have to high enough so you don't burn your tail feathers off, if it drops
out of the belly, then self lauch could cause fob injestion. Shop around and go
out to a rc field where you can see and talk to the guys who have them.
Overhaul is now at 50 hrs. Thats only for inspection and maybe a bearing. No
big thing. 50 hrs is alot of time....about 600 climbs of 2500 ft. Mounted on a
retractable pod boom with a arm that extends might be a idea. Food for though.
Tom
Old September 15th 03, 06:18 PM
tango4
Of course you could mount it on an offset mounting so that the exhaust goes
to one side of the tail. I'm sure the yaw induced would actually be quite
small.
Ian
"TomnKeyLargo" wrote in message
completed.
a
bucks
other
150
thought
it
drops
and go
No
on a
though.
Tom
Old September 15th 03, 06:39 PM
Eric Greenwell
says...
Or mount it on a metal Vee tail glider, like an HP-18.
For sustainer use (in-flight use only), vortex generators mounted on
the engine nacelle might mix enough slipstream air with the exhaust to
provide sufficient cooling.
if it drops
Even for a self-launcher, that's about 5 years of flying, based on my
experience (200 hours a year, about 50 launches and 10 air restarts a
year).
Mounted on a
Tom
Even just fixed on a strut about 12" above the fuselage it would have
little effect on thermalling and speeds up to best L/D +10 knots or
so.
!Replace DECIMAL.POINT in my e-mail address with just a . to reply
directly
Eric Greenwell
Richland, WA (USA)
Old September 16th 03, 07:45 AM
Slingsby
Eric Greenwell wrote in message ...
says...
if it drops
year).
Mounted on a
Tom
so.
I would think that mounting a couple of small jets at or just behind
the wing/fuselage junction could also serve to remove some of the low
speed turbulence in that area. Also, if the engine had a tight
cowling around it then perhaps some water could be sprayed or drizzled
onto the outside of the engine and the resulting steam would mix with
the exhaust to provide some additional thrust. SWB Turbines in
Neenah, WI (SWBTurbines.com)has a Mamba turbojet which puts out 11
Lbs. of thrust. It is only 3.5 inches in diameter and would fit
nicely at the wing junction interface. SWB also has 45, 60 and a
100Lb thrust engine.
Old September 16th 03, 05:27 PM
Eric Greenwell
says...
Perhaps a simple, straight forward way to test the concept is to
remove the engine from a current self-launcher like the PIK 20 E and
replace it with a P200 turbine or similar unit. The mast can already
take the forces, and it wouldn't be necessary actually have it
retractable for the initial tests. A fuel tank is already in the
glider, along with a big battery for starting.
My major concern is the heat of the exhaust, so perhaps the very first
thing to do is measure the air temperature about 12 feet behind one of
these turbines. Maybe it's OK; maybe you find out full power can't be
used on the ground, but enough power to taxi can be used; maybe it's
just too hot, even when mixing with air at 50 knots in climb.
If it worked out, making it retractable would be easy.
I still think someone with a metal vee-tail glider ought to jump on
this idea, and just mount the engine on a short pylon.
directly
Eric Greenwell
Richland, WA (USA)
Old September 16th 03, 09:50 PM
Chris Ashburn
It might get a pit toasty for the wing runner in self-launch mode, but
how about one at each wing tip?
It seems most gliders these days already have some sort of interchangable
tip, so make a new set with a jet built in.
Fuel storage would be the main issue. If you give up the water
ballast option though, there's plenty of room in the wing.
Chris
Old September 17th 03, 01:13 AM
Bob Kuykendall
Please send one (1) turbojet engine in a stamped, self-addressed envelope...
Bob K.
Old September 17th 03, 02:05 AM
Ray Lovinggood
Sailplanes = The Quiet Challenge
Jet Engines = Converters (they convert fuel to noise,
especially the ones in T-37 tweety birds)
Why would I want to fly something noisy? Many of us
in America already 'suffer' from towplane noise, so
why add the ear-splitting noise of a turbine?
I would rather see the further development of electric
self-launchers and greater use, in America, of ground
launches.
Leave the turbines to the Caproni (sp?) afficianados
and U-2/TR-1 pilots.
Ray Lovinggood
Carrboro, North Carolina, USA
LS-1d, 'W8'
Old September 17th 03, 05:14 AM
Finbar
Seems to me that a flameout at one tip might be a concern...
How about right at the end of the tailboom? It would require specific
engineering: the glider would have to be designed for it, both to fit
the engine there and from a c.g. point of view - although now that I
think of it, my glider already has tail weights to bring the c.g. aft!
The hot exhaust would be no issue. You'd have to duct inlet air from
the top of the tailboom to avoid ingesting foreign objects. Existing
gliders might be a little tough to retro-fit, but I'd imagine some
clever shops could do it (converting all the certificated gliders to
Experimental in the process, presumably...) As Chris says, you'd put
the fuel in the wings, displacing some (probably not all) of the
water, or put it between the wings in the fuselage. You'd have the
engine so far from the pilot and fuel, the exhaust aft of the
structure, and no complicated swinging arms, bomb bay doors, etc.
The noise in the cockpit would be pretty nasty, though...
Chris Ashburn wrote in message ...
Chris
Get Over $50,000 Fast and Easy, READ HOW [email protected] Owning 0 January 1st 05 04:41 PM
TFR's Read Carefully Ron Rosenfeld Piloting 2 September 20th 04 06:12 PM
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
OT - What espioange/war novels do you read? [SURVEY] Eric Pinnell Military Aviation 34 April 28th 04 06:23 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
