What glider will provide the best characteristics for
mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
Grob 102
"Jerome Conners" wrote in message ... What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
![]() John Shelton wrote: Grob 102 "Jerome Conners" wrote in message ... What glider will provide the best characteristics for mountain wave ascents to record heights? The Perlan project is using a DG 505M http://www.firnspiegel.com/perlan/ They are also designing a special glider for the project. Their site is a place to start. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Foster is using a modified DG505, I believe.
Wad. --- "Jerome Conners" wrote in message ... What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
2-32, all metal strong as hell, no gelcoat to crack.
Sam Fly Jerome Conners wrote: What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
2-33. Same advantages as 2-32 plus a whole lot cheaper
if your only way down again is by parachute. More seriously, is the glider critical or is it a question of meteorology, breathing equipment and crew endurance ? Ian At 23:48 13 December 2003, Sam Fly wrote: 2-32, all metal strong as hell, no gelcoat to crack. Sam Fly Jerome Conners wrote: What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
Read "Exploring the Monster" by Robert F. Whelan, Wind Canyon Books, Inc.,
ISBN 1-891118-32-3. On 19th March 1952 Larry Edgar and Harold Klieforth set the world absolute altitude record to 44,255ft. in a Pratt-Read two-seat glider. This had a best glide ratio of about 24 at 60 mph, and a min. sink of about 3.45ft/sec. at 51 mph (figures from the book), it also had poor penetration. They were flying from Bishop, California. They had state-of-the-art oxygen equipment and clothing, supplied by the military because they were taking part in government funded research. In those days military equipment was designed for unheated and unpressurised cockpits. They deliberately left 700 fpm lift when the altimeter read 44,000 ft because they considered that they had reached the limit of their equipment. I believe this two-seater record still stands, it was beaten by a single seater in 1961. I understand that the Perlan project is using a DG505M, with the engine removed so that the space and weight allowance for the engine can be used for high altitude equipment. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Jerome Conners" wrote in message ... What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. What publications provide the design information for mountain wave ascents? Jer Jerome Conners, PE Comstock Aeronautics and Engineering PO Box 509 Virginia City, NV 89440 775-834-8363 (work) 775-834-8364 (FAX) 775-847-0214 (home) |
What glider will provide the best characteristics for mountain wave ascents to record heights? What are those characteristics...air foil design, lofting characteristics, L/D ratio, oxygen system, etc. Jerome Conners, PE I really think that a nice high Vne would be great, since during a record attempt one would want wicked winds aloft (120+ knots on the nose) and it would be terrifying to choose between exceeding Vne/flutter speed or drift downwind uncontrollably. Sounds like a Jantar might be a real solid choice ![]() Apparently without water ballast which might freeze... Maybe an LS-4? I'm considering these factors myself... |
I believe the absolute record is 49,011 ft. set in 1986 by Bob Harris, flying a
Grob 102 out of California City. Bob |
SparrowHawk: All CARBON, strong as hell, no gelcoat to crack, and if
you can get above your release altitude, in most states you have set a new ultralight climb record. |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Edwards air show B-1 speed record attempt | Paul Hirose | Military Aviation | 146 | November 3rd 03 05:18 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
