We recently re-commissioned a winch that had been operated successfully
for years using armored tow-target cable. That being difficult to find these days, we are using regular stranded cable and are having trouble with the cable piling up at the center (width-wise)of the drum, then slipping off to the side causing slack loops of cable that eventually grow enough to whip out beyond the circumference of the drum, impacting adjacent structure. The winch has never had a level-wind mechanism. It would seem that the stranded cable has less tendency than the smooth, armored cable to slip off of the high spot at the center of the drum and lay into the lower, edge areas of the drum, which would result in a more level winding of the cable on the drum. It looks like a level-wind will be necessary, or a return to the old armored cable. Any suggestions? Lach Ohman |
Lach --
We're having excellent results with Plasma/Dyneema/Spectra hollow braid 5 mm rope. Our drum is 48 inch by 6 inch with 63 inch end plates. No line breaks, kinks, pile-ups or tangles in 75 plus tows to around 1700 ft. With well-designed pay-on sheaves there is absolutely no need for a level wind. Rope is forty plus cents a foot, but have you priced a tug and pilot plus their care and feeding lately? BJ Lach and JoAnn Ohman wrote: We recently re-commissioned a winch that had been operated successfully for years using armored tow-target cable. That being difficult to find these days, we are using regular stranded cable and are having trouble with the cable piling up at the center (width-wise)of the drum, then slipping off to the side causing slack loops of cable that eventually grow enough to whip out beyond the circumference of the drum, impacting adjacent structure. The winch has never had a level-wind mechanism. It would seem that the stranded cable has less tendency than the smooth, armored cable to slip off of the high spot at the center of the drum and lay into the lower, edge areas of the drum, which would result in a more level winding of the cable on the drum. It looks like a level-wind will be necessary, or a return to the old armored cable. Any suggestions? Lach Ohman |
Our club operate several two drum winches and use stranded
steel cable. Two Tost winches have smaller, wide drums with 'pay on' rollers that reciprocate across the width to lay the cable flat like a cotton reel. The 'Skylaunch' has large diameter and very narrow drums with no 'pay on' gear, but has high sides and raised guides on the sides of the drum to ensure it goes onto the body. The smaller wide drum Tost drum have the problem you describe if the pay on gear fails or sticks. The cable either throws large loops, goes over the side, or burys itself and then jams on pay out. The large narrow drums with no pay on gear work well. The narrow width prevents the bunching and burying problems. With the smaller wide drums perhaps by raising the sides and ensuring the cable goes to the centre of the drum will solve the initial problems. There are several ways of adding pay on rollers, but it depends on what space you have round the cable drums for modification. There are some good photos of various winches on http://www.skylau nch.de/album/d.html these may give you some ideas on how to modify your drums or add pay on gear. Another possible alternative is to look at 'Plasma' type ropes, this had been discussed at length on RAS and URAS and a few clubs in America are using it. It is expensive and has its own problems, but that is another story. |
"Lach and JoAnn Ohman" wrote in message ...
We recently re-commissioned a winch that had been operated successfully for years using armored tow-target cable. That being difficult to find these days, we are using regular stranded cable and are having trouble with the cable piling up at the center (width-wise)of the drum, then slipping off to the side causing slack loops of cable that eventually grow enough to whip out beyond the circumference of the drum, impacting adjacent structure. The winch has never had a level-wind mechanism. It would seem that the stranded cable has less tendency than the smooth, armored cable to slip off of the high spot at the center of the drum and lay into the lower, edge areas of the drum, which would result in a more level winding of the cable on the drum. It looks like a level-wind will be necessary, or a return to the old armored cable. Any suggestions? Lach Ohman Lach, I found the following reference in the German Aeroclub's (DAeC)rules and regulations regarding the technical aspects of building a winch: "Hinweis: Eine Spulvorrichtung ist erforderlich, wenn das Verhältnis von Trommelbreite zum Abstand zwischen Trommel und Rollen kleiner als 1:18 ist." Translation: Note: A level winding mechanism is required if the ratio between the drum's width and the distance between the drum and fair-lead rollers is less than 1:18. This may sound complicated but makes sense: if you have a wide drum and a short distance, the cable will pile up in the center. It will not deflect to the sides by itself. On the other hand, if you have a narrow drum and a long distance, the cable will fill up the available space more evenly. I don't know if using the Dyneema type rope will change your situation or not. Hope this helps Ulrich Neumann Libelle 'GM' |
Dave Martin wrote in message ...
Our club operate several two drum winches and use stranded steel cable. Two Tost winches have smaller, wide drums with 'pay on' rollers that reciprocate across the width to lay the cable flat like a cotton reel. The 'Skylaunch' has large diameter and very narrow drums with no 'pay on' gear, but has high sides and raised guides on the sides of the drum to ensure it goes onto the body. The smaller wide drum Tost drum have the problem you describe if the pay on gear fails or sticks. The cable either throws large loops, goes over the side, or burys itself and then jams on pay out. The large narrow drums with no pay on gear work well. The narrow width prevents the bunching and burying problems. With the smaller wide drums perhaps by raising the sides and ensuring the cable goes to the centre of the drum will solve the initial problems. There are several ways of adding pay on rollers, but it depends on what space you have round the cable drums for modification. There are some good photos of various winches on http://www.skylau nch.de/album/d.html these may give you some ideas on how to modify your drums or add pay on gear. Another possible alternative is to look at 'Plasma' type ropes, this had been discussed at length on RAS and URAS and a few clubs in America are using it. It is expensive and has its own problems, Name one problem- |
Dave Martin wrote
Another possible alternative is to look at 'Plasma' type ropes, this had been discussed at length on RAS and URAS and a few clubs in America are using it. It is expensive and has its own problems, At 00:06 24 December 2003, Craig Freeman wrote: Name one problem- Problem 1 Cutting it in an emergency Problem 2 Pursuading UK clubs and the BGA to support trials to evaluate its claimed advantages. Problem 3 Pursuading UK clubs that the extra expense may be saved by the higher launches, easier handling, longer life. |
And problem 4, which explains why I don't agree that my club should do
trials: we would have to pioneer modifications to the pay-on pulleys, possibly the scroll gear that ensures even winding onto the drum, and possibly the guillotines, at considerable trouble and expense with no certainty that it would be successful. All that is on top of the expense of at least one drum of the new cable. Having worked for years to develop know-how and a system that ain't broke, with low cost per launch and almost no cable breaks, I see no reason to try to fix it. We have better uses for our resources. My fears about the redevelopment costs come from having heard that the fibre cable can burn if it rubs. Knowing that our pulleys are heavy, need considerable pressure to accelerate them, and are deeply scored from steel cable use, I doubt if it is worth the cost and effort. Chris N. |
At 12:42 24 December 2003, Chris Nicholas wrote:
And problem 4, which explains why I don't agree that my club should do trials: we would have to pioneer modifications to the pay-on pulleys, possibly the scroll gear that ensures even winding onto the drum, and possibly the guillotines, at considerable trouble and expense with no certainty that it would be successful. All that is on top of the expense of at least one drum of the new cable. Having worked for years to develop know-how and a system that ain't broke, with low cost per launch and almost no cable breaks, I see no reason to try to fix it. We have better uses for our resources. My fears about the redevelopment costs come from having heard that the fibre cable can burn if it rubs. Knowing that our pulleys are heavy, need considerable pressure to accelerate them, and are deeply scored from steel cable use, I doubt if it is worth the cost and effort. Chris N. Chris I accept all your arguments apart from the last line, if we never try we will never know! Dave |
Dave Martin It is expensive and has its own problems, At 00:06 24 December 2003, Craig Freeman wrote: Name one problem- Problem 1 Cutting it in an emergency Problem 2 Pursuading UK clubs and the BGA to support trials to evaluate its claimed advantages. Problem 3 Pursuading UK clubs that the extra expense may be saved by the higher launches, easier handling, longer life. Problem 1. Skylaunch has a cutter available Problem 2,3 I understand your situation but this is not a problem with the rope. I would liked to have seen some real test data too before purchasing, but after using it I am glad I did not wait. I would not go back to wire for any reason ever period. Unfortunatly we don't fly enough to put the time on the rope which could help you out with pursuading UK clubs. Someday clubs will wish they had switched sooner. |
| GEM 1200 Problem | Jim Kaufeld | Owning | 11 | March 22nd 04 04:54 AM |
| A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 08:59 PM |
| Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 06:29 PM |
| Winch Way Is Up !! | Craig Freeman | Soaring | 45 | November 6th 03 04:08 PM |
| using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 03:46 PM |
