Yesterday evening I talked with a friend about avoiding excessive speed when
	recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL  |
K.P. Termaat wrote:
	Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
If you are already very fast and pull the airbrakes, you have to be very
	careful during the pull up because the wing won't stand the same g-load as without airbrakes. -- Bert Willing ASW20 "TW" "Erik Braun" a écrit dans le message de ... K.P. Termaat wrote: Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
must have slipped my notice that airbrakes on 'modern
	low drag gliders' were speed limiting. my speed stays pretty much constant at full travel. notwithstanding that, why on earth would you want to increase your sink rate further than that caused by the spin in the first place. sounds like a death wish to me! do what you were taught in your spin training, its a recovery drill not a starting pint to experiment with your life and possibly the life of your passenger/pupil. At 09:36 25 March 2004, Erik Braun wrote: K.P. Termaat wrote: Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
Hello Erik,
	Yes that's what my handbook says for my Ventus-2cxT also. I guess however that when recovering from a spin using the standard method (or the more advanced one including a bit of aileron) that then Vne will be exceeded after rotation has stopped and pitch angle is something like 60°. To avoid this the idea is to pull the brakes even before the rotation has stopped. But I am worried about that. Karel, NL "Erik Braun" schreef in bericht ... K.P. Termaat wrote: Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
OK the answer to this one is very simple, VNE stands
	for 'Velocity never exceed' the never is not optional. Pulling the airbrakes or pulling back hard on the stick may cause structural damage to the glider, however this structural damage is not likely to be catastrophic. Exceeding VNE may induce aerodynamic flutter, this can and almost certainly will cause catastrophic failure of the airframe. Put simply try and avoid both but if the choice is exceed the placarded G loading or VNE the G loading is the only choice. The potential for catastophic failure is much much greater if VNE is exceeded, exceeding VNE is therefore not an option. I have no doubt there will now be lots of postings from people who say they have exceeded VNE and got away with it. Even idiots can be lucky sometimes. At 11:30 25 March 2004, Bert Willing wrote: If you are already very fast and pull the airbrakes, you have to be very careful during the pull up because the wing won't stand the same g-load as without airbrakes. -- Bert Willing ASW20 'TW' 'Erik Braun' a écrit dans le message de ... K.P. Termaat wrote: Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
Don Johnstone wrote:
	OK the answer to this one is very simple, VNE stands for 'Velocity never exceed' the never is not optional. Pulling the airbrakes or pulling back hard on the stick may cause structural damage to the glider, however this structural damage is not likely to be catastrophic. Why not? Exceeding VNE may induce aerodynamic flutter, this can and almost certainly will cause catastrophic failure of the airframe. Put simply try and avoid both but if the choice is exceed the placarded G loading or VNE the G loading is the only choice. The potential for catastophic failure is much much greater if VNE is exceeded, Why? exceeding VNE is therefore not an option. Isn't there a built in safety margin for both G's and VNE? I have no doubt there will now be lots of postings from people who say they have exceeded VNE and got away with it. Even idiots can be lucky sometimes.  |
	OK the answer to this one is very simple, VNE stands for 'Velocity never exceed' the never is not optional. Pulling the airbrakes or pulling back hard on the stick may cause structural damage to the glider, however this structural damage is not likely to be catastrophic. "May"? At Vne, "pulling back hard on the stick" will guarantee catastrophic structural failure, not just "damage". Even "pulling back modestly" (like one-third of the stick travel) can get you very close to the limits. Exceeding VNE may induce aerodynamic flutter, this can and almost certainly will cause catastrophic failure of the airframe. References? The majority of people I know that have suffered flutter did so without catastrophic failure. The glider often had damage to a control surface or linkage, but not structural damage. Put simply try and avoid both but if the choice is exceed the placarded G loading or VNE the G loading is the only choice. The potential for catastophic failure is much much greater if VNE is exceeded, exceeding VNE is therefore not an option. References? I have no doubt there will now be lots of postings from people who say they have exceeded VNE and got away with it. Even idiots can be lucky sometimes. Inadvertently exceeding Vne doesn't automatically make the pilot an idiot. Most of these "idiots" will be good pilots that got caught in a bad situation; some might be pilots that took exceptional risks. Anyway, we are talking about what to do when caught between a rock and hard place, not what led to it. Let's not prejudge anyone. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA  |
Hi guys,
	Thanks for the discussion. Once one has exceeded Vne a choice must be made by the pilot of either pulling the airbrakes or put some backpressure on the stick or do both. We know the dramatic outcome of the Nimbus 4DM at Minden a couple of years ago when doing the latter. Probably I would go for only putting some backpressure on the stick and have the max g-load number for the wing available. Hopefully the wing will survive flutter that may occur and will not destroy the whole wing. Some years ago I saw and heard a tail of a Cirrus move about heavily in a too fast fly by, but the glider survived with minimum damage. However the above is not my concern. I am worried about a possible means to avoid Vne to be exceeded after recovery when the glider is still in its spinning (rotation) mode. The idea is to pull the airbrakes even before the rotation has stopped. Karel, NL "K.P. Termaat" schreef in bericht ... Hello Erik, Yes that's what my handbook says for my Ventus-2cxT also. I guess however that when recovering from a spin using the standard method (or the more advanced one including a bit of aileron) that then Vne will be exceeded after rotation has stopped and pitch angle is something like 60°. To avoid this the idea is to pull the brakes even before the rotation has stopped. But I am worried about that. Karel, NL "Erik Braun" schreef in bericht ... K.P. Termaat wrote: Yesterday evening I talked with a friend about avoiding excessive speed when recovering from a spin in a modern low drag glider with the somewhat larger span. He came up with the idea of pulling the airbrakes when still recovering from the rotating mode. I am not sure this can be done without disturbing the recovering action or without hurting the glider. Any comment will appreciated. Karel, NL Pulling the airbrakes is what most handbooks say on this subject. But if you're already very fast I'd do this carefully.  |
Pete Zeugma wrote:
	must have slipped my notice that airbrakes on 'modern low drag gliders' were speed limiting. my speed stays pretty much constant at full travel. Of course, if the glider is already running at Vne I wouldn't pull the airbrakes but try to recover really carefully. But up to ~220kmh, I'd do this, because they DO produce a big drag an make the glider slower (in my experience at least, which doesn't include a Nimbus or the other big ones). Erik  |
| Thread Tools | |
| Display Modes | |
| Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 05:32 AM |
| Avoiding gliders | Stefan | Piloting | 16 | August 6th 03 06:44 AM |
