#31
These reports led you to the wrong conclusion.
Overstress is the key here, weahter with or without airbrakes. It's a lot easier to overstress the structure or eventually even cause flutter by trying to recover from a high speed dive without using the brakes. "Todd Pattist" wrote in message ... "Arnold Pieper" wrote: Don't be affraid to open the airbrakes at high speed, believe me, the manufacturer is just a little smarter than that. I'm not afraid to open them at high speed, I'm afraid to lower the G-limit when I need G-s to recover. I've seen too many accident reports where structural failure was attributed to overstressing with the brakes open. You have to be careful at high speed just because they tend to jump out more easily, so, have a firm hand on it. Real aerobatic training (as opposed to some occasional loops) will clarify a lot of this. Although it's been long time, my training was by a national glider aerobatic champion. Todd Pattist - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
#32
I thought you flew an ASW20 (might be mistaken)? This
is one ship where the wing twist at high speed results in a subtle trim change that you might not even notice. At high speed the stick eventually needs to be brought slightly back to avoid continuing acceleration. The faster you go the further back it needs to come. Don't get me wrong, it is VERY subtle and you probably wouldnt ever notice it. But there was some speculation that the ASW20 accident mentioned earlier was the result of a speed being reached (above VNE) where the trim change was such that the stick was on the back stop and the sailplane was still pitching nose down. The reason that this behaviour is allowed is because it isn't dangerous (or even noticable) unless you exceed VNE. This is just stuff I have heard around, so not sure if it is 100% true. But I have heard it from some pretty reliable people. At 23:42 01 April 2004, Arnold Pieper wrote: I don't know where you guys get these things from, but this behaviour means these gliders should have their certifications cancelled. I've never flown anything with these characteristics. 'Mark Navarre' wrote in message ... From: 'Arnold Pieper' Date: 3/31/2004 1:16 PM Pacific Standard Time Message-id: Maybe true if 'near vertical', however, staying at a near vertical dive is something that requires a conscient effort. The glider won't just stay there on its own. To remain in a 90 degree vertical dive requires a significant amount of forward stick force and concentration. As speed increases, the nose will come up (away from vertical) even if you don't want it to, and even with full forward trim, it would still require an honest push on the stick to maintain that attitude. Not true with all gliders. Several modern racing ships will, when trimmed within CG limits for best climb performance, 'tuck' or pitch down with increasing airspeed, resulting in a large outside loop or exceeding VNE without pilot input. The crossover speed for this in my own ship is about 115 kts, above which slight back pressure is needed to maintain speed. - Mark Navarre 2/5 black ace LoCal, USA - |
#33
I own and fly an ASW 20, and the behaviour you describe is definitively
complete nonsense. Even approaching Vne you need to positively push the stick to maintain speed. -- Bert Willing ASW20 "TW" "Jon Meyer" a écrit dans le message de ... I thought you flew an ASW20 (might be mistaken)? This is one ship where the wing twist at high speed results in a subtle trim change that you might not even notice. At high speed the stick eventually needs to be brought slightly back to avoid continuing acceleration. The faster you go the further back it needs to come. Don't get me wrong, it is VERY subtle and you probably wouldnt ever notice it. But there was some speculation that the ASW20 accident mentioned earlier was the result of a speed being reached (above VNE) where the trim change was such that the stick was on the back stop and the sailplane was still pitching nose down. The reason that this behaviour is allowed is because it isn't dangerous (or even noticable) unless you exceed VNE. This is just stuff I have heard around, so not sure if it is 100% true. But I have heard it from some pretty reliable people. At 23:42 01 April 2004, Arnold Pieper wrote: I don't know where you guys get these things from, but this behaviour means these gliders should have their certifications cancelled. I've never flown anything with these characteristics. 'Mark Navarre' wrote in message ... From: 'Arnold Pieper' Date: 3/31/2004 1:16 PM Pacific Standard Time Message-id: Maybe true if 'near vertical', however, staying at a near vertical dive is something that requires a conscient effort. The glider won't just stay there on its own. To remain in a 90 degree vertical dive requires a significant amount of forward stick force and concentration. As speed increases, the nose will come up (away from vertical) even if you don't want it to, and even with full forward trim, it would still require an honest push on the stick to maintain that attitude. Not true with all gliders. Several modern racing ships will, when trimmed within CG limits for best climb performance, 'tuck' or pitch down with increasing airspeed, resulting in a large outside loop or exceeding VNE without pilot input. The crossover speed for this in my own ship is about 115 kts, above which slight back pressure is needed to maintain speed. - Mark Navarre 2/5 black ace LoCal, USA - |
#34
On 2 Apr 2004 09:26:34 GMT, Jon Meyer
wrote: This is just stuff I have heard around, so not sure if it is 100% true. But I have heard it from some pretty reliable people. Basic rule #1 about aviation rumours: Never believe anything as long as you have not seen it yourself. The behaviour described above is, as Bert alreay pointed out, absolute nonsense and exactly the contrary of how a 20 behavies in reality. Bye Andreas |
#35
![]() The behaviour described above is, as Bert alreay pointed out, absolute nonsense and exactly the contrary of how a 20 behavies in reality. It's not all BS, there was this Doctor that extended the wing span on his ship, back in the '70's. He brought a new meaning to the term, *final glide* as the wing tips dug-in and he almost completed an outside loop, with the stick full back, but the ground got in the way. Wing twist at high speed is real. JJ Sinclair |
#36
![]() Subject: Devices for avoiding VNE? From: Andreas Maurer Date: 4/2/2004 5:48 AM Pacific Standard Time Message-id: Basic rule #1 about aviation rumours: Never believe anything as long as you have not seen it yourself. The behaviour described above is, as Bert alreay pointed out, absolute nonsense and exactly the contrary of how a 20 behavies in reality. I have seen it myself, my ship was not out of CG limits, the effect is subtle, but present nevertheless. Other pliots with AS-W20's may not experience the tuck due to flying with a further forward CG and resulting trim speed change, thereby canceling the aeroelastic twist of the wings. 20 B's have stiffer wings than the A or C, by the way, and may not twist as much. The speed at which this begins to occur on my ship is out of the normal range of efficient cruising speed anyway. Just fly the plane...put the stick where it gives you the speed you want and keep it there until you want a different speed. It's not autopilot! - Mark Navarre 2/5 black ace LoCal, USA - |
#37
JJ Sinclair wrote:
The behaviour described above is, as Bert alreay pointed out, absolute nonsense and exactly the contrary of how a 20 behavies in reality. It's not all BS, there was this Doctor that extended the wing span on his ship, back in the '70's. He brought a new meaning to the term, *final glide* as the wing tips dug-in and he almost completed an outside loop, with the stick full back, but the ground got in the way. Wing twist at high speed is real. JJ Sinclair I think the context here is "certified gliders" operated within their limits, are supposed to have positive stability at Vne. If you have one that doesn't, this suggests there is something wrong with your glider. I'm sure we all agree that wing twist can happen, and we are not surprised it might happen to someone that extended the span on his glider, or exceeds Vne by 40 or 50 knots. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#38
I a bit suspicious of this whole wing twist thing.
Since the center of lift for most airfoils is at about 0.25 chord, which is generally a bit haead of the spar, you'd expect the natural aerodynamic forces to generate neutral to positive twisting with loading. The only counter-examples I know of are in jet fighters. The F-100 was known to have aileron reversal at maximum dynamic pressure (transonic at low altitude) under high Gs. On a glider you would have to have a lot of washout built into the tips to get it to twist because you would need to generate negative angle of attack at the tip. I guess this is possible if you modify your glider extensively, or maybe if do an aggressive negative-G pushover at a high enough speed. Neither of those are in my bag of tricks so I'll consider myself relatively safe for now. At 16:54 02 April 2004, Eric Greenwell wrote: JJ Sinclair wrote: The behaviour described above is, as Bert alreay pointed out, absolute nonsense and exactly the contrary of how a 20 behavies in reality. It's not all BS, there was this Doctor that extended the wing span on his ship, back in the '70's. He brought a new meaning to the term, *final glide* as the wing tips dug-in and he almost completed an outside loop, with the stick full back, but the ground got in the way. Wing twist at high speed is real. JJ Sinclair I think the context here is 'certified gliders' operated within their limits, are supposed to have positive stability at Vne. If you have one that doesn't, this suggests there is something wrong with your glider. I'm sure we all agree that wing twist can happen, and we are not surprised it might happen to someone that extended the span on his glider, or exceeds Vne by 40 or 50 knots. -- ----- change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
#39
![]() I a bit suspicious of this whole wing twist thing. Take a K-6 up to 100 and look at the tips. Take an ASH-25 up to 80 with landing flaps on and look at the tips. In the case of the K-6, she does have a few degrees of tip wash-out (leading edge down) In the case of the ASH-25 with landing flaps on, Only the inboard flaps go down, the outboard flaps and ailerons go up to produce a negative angle of attack. So why do the wings in both cases bend down? Why does the B-52 use spoilers instead of ailerons? Because at higher airspeeds an aileron input causes the wing to bend and can cause the ship to turn in the opposite direction (wing twist) Even in a *certified* ship, if the wings start to tuck under and you don't catch it right away, you could find yourself in a situation where elevator won't stop the pitch down action. Now, all of this is at or above VNE, so if we are flying our glass slippers within limits, we should be OK. JJ Sinclair |
#40
Andy Blackburn wrote:
I a bit suspicious of this whole wing twist thing. Since the center of lift for most airfoils is at about 0.25 chord, which is generally a bit haead of the spar, you'd expect the natural aerodynamic forces to generate neutral to positive twisting with loading. I think you are right to be suspicious about the importance of wing twist in a certified glider, but not for your reason. Most gliders do have wing twist built into them, and the pitching momemt of the airfoil also is twisting the wing in the same direction. The reason we don't have worry about it is the designer knows about these factors, used sufficent structure to avoid excessive twisting, then validated his design with structural and flight tests. A glider operated well outside it's limits, a damaged one, or a modified one... Plenty to worry about then. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Aircraft Deceleration Devices | SteveM8597 | Military Aviation | 10 | April 13th 04 10:01 AM |
GPS and Night Vision Devices | Steve | Products | 0 | February 12th 04 11:34 AM |
WinPilot-compatible GPS devices | Ted Wagner | Soaring | 21 | January 12th 04 10:27 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Airdropped Fusion Devices | Blinky the Shark | Military Aviation | 4 | September 17th 03 05:34 PM |
