Ok im really bored and I thoguht i would open a can
of worms..has Standard Class Design reached a plateau? and if so where do we go from here? |
Mark Brown wrote:
Ok im really bored and I thoguht i would open a can of worms..has Standard Class Design reached a plateau? and if so where do we go from here Well I guess it means that pilots will have to learn some decent amount of skill instead buying a better glider to improve their results. Of course there's always the latest version of the PDA flight director software to tell you when to push/pull/bank/go there/at that speed/or whatever, etc... One pilot over here followed his PDA during a competition final glide even to the point of hitting a tree. The logical answer to that one was that he hadn't programmed the location of the tree into the map drawing software. Rgds, Derrick. |
Mark Brown wrote:
Ok im really bored and I thoguht i would open a can of worms..has Standard Class Design reached a plateau? and if so where do we go from here? Yes? The way (most) composite sailplanes are made, wet hand layup of cloth, is ancient history in composite fabrication. Some newer material technology like the pre-preg cloth construction of the Sparrowhawk (and Duckhawk I assume?) and the carbon rod spar of the Genesis are a couple examples of how new designers are wait.......here it comes..... Breaking the Mold! Thank you , thank you. :-) Also, technology in sail making can custom weave a sail on a mold thread by thread (more or less). Could a glider fusalage be spun out on a mold? dunno. Also, the new Eclipse mini-busjet uses a high tech welding technique for its aluminum skin, eliminating rivets (or at least a lot of them). These new fabrication techniques can reduce limitations set by materials and weight (but probably not cost. )-: ). If a thinner airfoil is better, but couldn't be constructed using old techniques, new materials can make it possible. In some cases perhaps construction could be made less expensive. Haven't heard of any big advances in making the smooth surface required by laminar flow, without lots of sanding, but only a ludite would tell you it can't be done. Not big incentive on the part of the manufacturers to change. Maybe the Duckhawk or Diana II will start shaking the old men awake :-) Shawn |
"Mark Brown" wrote in message
... Ok im really bored and I thoguht i would open a can of worms..has Standard Class Design reached a plateau? and if so where do we go from here? What makes you think it has ? |
Obviously not the same reasons that make you think
it hasnt ;-)! At 18:54 02 May 2004, Arnie wrote: 'Mark Brown' wrote in message ... Ok im really bored and I thoguht i would open a can of worms..has Standard Class Design reached a plateau? and if so where do we go from here? What makes you think it has ? |
"Shawn Curry" wrote in message ... Mark Brown wrote: Ok im really bored and I thoguht i would open a can of worms..has Standard Class Design reached a plateau? and if so where do we go from here? Yes? The way (most) composite sailplanes are made, wet hand layup of cloth, is ancient history in composite fabrication. Some newer material technology like the pre-preg cloth construction of the Sparrowhawk (and Duckhawk I assume?) and the carbon rod spar of the Genesis are a couple examples of how new designers are wait.......here it comes. Anyone care to comment if these light pre-preg composites are repairable if damaged? Breaking the Mold! Thank you , thank you. :-) Also, technology in sail making can custom weave a sail on a mold thread by thread (more or less). Could a glider fusalage be spun out on a mold? dunno. Also, the new Eclipse mini-busjet uses a high tech welding technique for its aluminum skin, eliminating rivets (or at least a lot of them). Ever seen Rutan's Boomerang? Been done, in Montrose IIRC. Filament winding composite structures like a glider fuselage would likely take several uninterrupted hours, given the nature of the method. Can't stop once you've started. But it's certainly doable. These new fabrication techniques can reduce limitations set by materials and weight (but probably not cost. )-: ). If a thinner airfoil is better, but couldn't be constructed using old techniques, new materials can make it possible. In some cases perhaps construction could be made less expensive. Haven't heard of any big advances in making the smooth surface required by laminar flow, without lots of sanding, but only a ludite would tell you it can't be done. Not big incentive on the part of the manufacturers to change. Maybe the Duckhawk or Diana II will start shaking the old men awake :-) At the Diana 2 talk at the SSA convention, the question was asked that if someone damaged the structure of a Diana 2 wing, could it be repaired at one of the regular repair stations. The reply was no, with the caveat that if the glider is very successful in sales, such a repair service could be made available in North America, perhaps. The potential impact on insurance coverage might be substantial. Some of the research behind the Diana 2 has involved the ideas, methods, and review of some of those old men BTW. Maybe the Cole's can comment on the Sparrowhawk's repairability. Frank Whiteley Colorado |
F.L. Whiteley wrote:
The way (most) composite sailplanes are made, wet hand layup of cloth, is ancient history in composite fabrication. Some newer material technology like the pre-preg cloth construction of the Sparrowhawk (and Duckhawk I assume?) and the carbon rod spar of the Genesis are a couple examples of how new designers are wait.......here it comes. Anyone care to comment if these light pre-preg composites are repairable if damaged? According to Greg Cole, it's not a problem. He went into a bit of detail with me a few months ago, but I don't remember them well enough to pass it on. Wet layup repairs can be made up to a point, as I recall. Of course, the factory should be contacted first for the proper methods. Every composite component is laid up in a mold and assemblies are done in jigs, so you could buy replacement parts, even a wing, and have it fit. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
"Eric Greenwell" wrote in message ... F.L. Whiteley wrote: The way (most) composite sailplanes are made, wet hand layup of cloth, is ancient history in composite fabrication. Some newer material technology like the pre-preg cloth construction of the Sparrowhawk (and Duckhawk I assume?) and the carbon rod spar of the Genesis are a couple examples of how new designers are wait.......here it comes. Anyone care to comment if these light pre-preg composites are repairable if damaged? According to Greg Cole, it's not a problem. He went into a bit of detail with me a few months ago, but I don't remember them well enough to pass it on. Wet layup repairs can be made up to a point, as I recall. Of course, the factory should be contacted first for the proper methods. Every composite component is laid up in a mold and assemblies are done in jigs, so you could buy replacement parts, even a wing, and have it fit. -- That's partly the point, Eric. "Ring, ring, I've dinged my wing." "No problem, we have a new wing, what color?" "Ka-ching!" Old style $3000 repair is suddenly an $8000 replacement (thinking Sparrowhawk price arena). Parts are cooked in an autoclave IIRC. Just scarfing these would seem exceedingly difficult. As far as repairing structural damage to a filament wound structure, I think that's probably not very likely other than for minor issues. Doesn't mean methods can't be developed, but I don't think they are fielded yet. I know folks who've done outstanding work with wet layup GRP and CF repairs, arriving within ounces of the original weight with essentially totaled gliders, but it's not quite the same thing and probably ends somewhere between patching a hole and a structural splice. I supposed we'll find out before long. Frank |
damaged? According to Greg Cole, it's not a problem. He went into a bit of detail with me a few months ago, but I don't remember them well enough to pass it on. Wet layup repairs can be made up to a point, as I recall. Of course, the factory should be contacted first for the proper methods. Every composite component is laid up in a mold and assemblies are done in jigs, so you could buy replacement parts, even a wing, and have it fit. -- That's partly the point, Eric. "Ring, ring, I've dinged my wing." "No problem, we have a new wing, what color?" "Ka-ching!" Well, trash a wing on a German glider, and try to buy a replacement from the factory. I wasn't suggesting you have to replace a "dinged" wing, as they are easily (according to Greg) repaired. Perhaps I wasn't clear, so let's try again: not everything can be repaired, or the repair is so involved, it's better/cheaper to replace it (broken spars often fall in this category). If so, you aren't out of luck, because you can buy a replacement. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
and if so where do we go from here? While othewrs had argue the merits of various building methods these do not directly offer any performance improvments. Given the size of most of the production runs I would look at vacuum infusion for wetting out the cloth. Aerodynamically the place to go is reflexed airfoils. Note: I did not say flying wings. Reflexed airfoils can operate quite well on tailed gliders and this configuration offers many pratical benifits. Robert Mudd |
| Thread Tools | |
| Display Modes | |
| Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 01:29 AM |
| World Class: Recent Great News | Charles Yeates | Soaring | 58 | March 19th 04 07:58 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Standard Class Natl's. low turnout? | Burt Compton | Soaring | 10 | August 24th 03 01:15 AM |
