Ralph Jones wrote:
	Check this out: http://kcbsimg.dayport.com/htm/cbs2p...elly%20Landing rj Check what out? A site that doesn't load?  |
Use Internet Explorer and it should load - B17 Gear collapse at slow
	speed after landing at Van Nuys on news chopper video. Shawn Curry wrote: Ralph Jones wrote: Check this out: http://kcbsimg.dayport.com/htm/cbs2p...elly%20Landing rj Check what out? A site that doesn't load?  |
Loaded fine for me, bummer a restored B17 having a
	gear collapse on roll out. At 19:54 07 May 2004, Shawn Curry wrote: Ralph Jones wrote: Check this out: http://kcbsimg.dayport.com/htm/cbs2p...D=2643&tf=Worl d%20War%20II%20Bomber%20Slides%20To%20Safe%20Ha lt%20In%20Van%20Nuy s%20Belly%20Landing rj Check what out? A site that doesn't load?  |
Very interesting that both mains collapsed at the exact same time.  I'm
	not familiar w/ the B17 design, but I'd guess that they are independant mechanical mechanisms so I'd be suspicious of a control failure or uncommanded or accidentally commanded retraction. I don't know if jamming on the brakes could be a factor, but it didn't look like the plane was moving in a manner that would have called for a sudden brake application. Ralph Jones wrote: Check this out: http://kcbsimg.dayport.com/htm/cbs2p...elly%20Landing rj  |
Apparently the B-17 uses the same gear mechanism as the LS 3/4.  Who knew.
	Hope nobody was riding in the belly turret. Mark Zivley wrote in message . com... Very interesting that both mains collapsed at the exact same time. I'm not familiar w/ the B17 design, but I'd guess that they are independant mechanical mechanisms so I'd be suspicious of a control failure or uncommanded or accidentally commanded retraction. I don't know if jamming on the brakes could be a factor, but it didn't look like the plane was moving in a manner that would have called for a sudden brake application. Ralph Jones wrote: Check this out: http://kcbsimg.dayport.com/htm/cbs2p...elly%20Landing rj  |
	not familiar w/ the B17 design, but I'd guess that they are independant mechanical mechanisms so I'd be suspicious of a control failure or uncommanded or accidentally commanded retraction. B-17 has a large electric (DC) motor with an angle drive gearbox on the end driving the gear retraction/extension mechanism, if I recall correctly (it's been about 20 years now) there's one in each gear well. For both to retract as nicely as that, I would suspect an electrical malfunction, maybe a relay or a short or some such thing - can't remember how the electrics runs on those. They were used them in the air tanker/spraying bidness right into the early '80's. Jim  |
The B-17 has gear and flap switches side by side...not in the least
	difficult to flip the wrong one. rj On Sat, 08 May 2004 13:23:55 GMT, Mark Zivley wrote: Very interesting that both mains collapsed at the exact same time. I'm not familiar w/ the B17 design, but I'd guess that they are independant mechanical mechanisms so I'd be suspicious of a control failure or uncommanded or accidentally commanded retraction. I don't know if jamming on the brakes could be a factor, but it didn't look like the plane was moving in a manner that would have called for a sudden brake application. Ralph Jones wrote: Check this out: http://kcbsimg.dayport.com/htm/cbs2p...elly%20Landing rj  |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 04:22 AM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
| Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 08:45 PM |
