#11
K.P. Termaat wrote:
"Eric Greenwell" schreef in bericht ... Snip .. The start and finish are not "post-declared" but are the release and landing. Hello Eric, Do you understand "This course must be declared" in 1.4.5.b. where it also says "The TURN POINTS may be claimed once, in any sequence, or not at all. You snipped too much of my posting. Here it is more of it: 1 - How does one electronically declare a task with post declared start and finish (such as 1000km diploma where the start and finish do not need to be declared No action is required for courses that do not need a declaration. The start and finish are not "post-declared" but are the release and landing. 1.4.5.b refers to courses with turnpoints, which must be declared. I was referring to 1.4.5.a when I said "courses that do not need a declaration". I should have referenced 1.4.5.a to eliminate any confusion, especially since there is only one course (straight distance) that doesn't have to be declared for badges. Several undeclared courses are available for records, which is where my confusion came from. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Ramy Yanetz wrote:
"Eric Greenwell" wrote in message ... Ramy Yanetz wrote: I'll add couple more questions: 1 - How does one electronically declare a task with post declared start and finish (such as 1000km diploma where the start and finish do not need to be declared No action is required for courses that do not need a declaration. The start and finish are not "post-declared" but are the release and landing. 1000km diploma require declaration of turnpoints only. Start and finish can indeed be the release and landing. without the logger automatically assign the first and last turnpoints as start/finish? The logger doesn't automatically do anything - it just lists the turnpoints. You might see some kind of assignment for takeoff and landing on flight display programs like SeeYou, but that is not the logger. What logger are you using? I am using winpilot declaration for volkslogger. It automatically assigns the first turnpoint as start point and the last as finish, so the declared task distance is much shorter. Will the release/landing still be considered as start/finish even if other turnpoints are declared as such? We've exceeded my knowledge of specific logger declaration methods, as I'm most familiar with the Cambridge units. Is it possible to use Volkslogger software to declare things differently? Or is there some way to select "release" and "landing" as part of the declaration, so the turnpoints don't get used for start/finish? There must be a way, since release and landing are common features in badge and record flights. As a workaround, you could use a paper declaration, but that is not very satisfactory. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Understand what you mean. Confusion is my problem too; it probably bothers
me even more than you at the moment. I guess in 1.4.5.b it is not necessary either to declare startpoint and finishpoint, but it may be done (not sure though). Turnpoints must be declared. Lets say they appear on the declaration sheet (or in the logger) as A, B and C and in that order. After take off a pilot decides to go for a task St - C - A - Fin because he finds promising weather conditions while "en route". He uses declared turn points in a certain "sequence or not at all" and this is exactly what 1.4.5.b. allows. Now what about "This course must be decared" ? as the rule states as its last "informational remark". Is that post declared or what. I can't see how a course can be (pre-)declared before the flight when turnpoints may be visited "in any sequence or not at all". In my example of three declared turnpoints one can have 22 courses when "in any sequence or not at all" applies. Karel, NL (not a lawyer yet) "Eric Greenwell" schreef in bericht ... K.P. Termaat wrote: "Eric Greenwell" schreef in bericht ... Snip .. The start and finish are not "post-declared" but are the release and landing. Hello Eric, Do you understand "This course must be declared" in 1.4.5.b. where it also says "The TURN POINTS may be claimed once, in any sequence, or not at all. You snipped too much of my posting. Here it is more of it: 1 - How does one electronically declare a task with post declared start and finish (such as 1000km diploma where the start and finish do not need to be declared No action is required for courses that do not need a declaration. The start and finish are not "post-declared" but are the release and landing. 1.4.5.b refers to courses with turnpoints, which must be declared. I was referring to 1.4.5.a when I said "courses that do not need a declaration". I should have referenced 1.4.5.a to eliminate any confusion, especially since there is only one course (straight distance) that doesn't have to be declared for badges. Several undeclared courses are available for records, which is where my confusion came from. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Naval Aviation | 0 | April 30th 04 09:45 PM |
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA | Otis Willie | Military Aviation | 0 | April 30th 04 09:45 PM |
Future Electronic Attack Aircraft | Mike P. | Military Aviation | 1 | April 22nd 04 01:30 AM |
Electronic Ignition | Andre | Home Built | 1 | September 5th 03 06:15 PM |
Silver Badge Fun (?) | Mark Zivley | Soaring | 43 | July 14th 03 07:52 PM |
