#11
An additional concern to those who dive to go into ground effect is that you
are giving up the ability to choose a touchdown point. Once in ground effect, the pilot loses the ability to turn and must touch down straight ahead. Altitude, however, gives the pilot the option of turning slightly to avoid something hard. If you cannot make the airport, pilots must select the best option as soon as possible, using the aircraft as a bargaining chip. Walking away is the concern rather than making the airport. From that standpoint, altitude gives us the most options for the longest time. Colin N12HS --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/04 |
First a disclaimer: I understand the security issues involved
in the following and would not encourage anyone to try this at home, but I am interested in the theoretical side of it. Imagine you get things wrong and are caught out low on final, still a fair distance out, and it looks marginal whether you are going to reach the runway or not. One technique I have sometimes heard described is to dive for the deck and complete the remaining distance in ground effect. For the sake of the argument we can assume fairly flat ground, free of obstacles, though not necessarily landable. The advantages claimed are usually better glide performance in ground effect and less headwind and absence of downdrafts close to the ground. On the other hand you'll be travelling at higher than optimal airspeed for most of the distance. I am wondering how much truth there actually is to this technique. Would it significantly increase your range and improve your chances of reaching the field or not ? Would it perhaps work better against a strong wind gradient (as I suspect it might), and maybe not help a lot in calm conditions ? I'd be interested in any hard data/analysis or otherwise enlightening comments on this. Please note though, that I am not talking about high-speed competition finishes, rounded off with a beatup and a sharp pullup and all the dangers and other issues involved in that. Cheers CV CV, a group of test pilot trainees at Edwards AFB did an exhaustive test on ground effect versus distance as a project during their course; it was reported in the Feb 1990 SOARING magazine. IIRC, they found that one had to fly a very precise profile - 0.95g push followed by 1.05g pull, to a precise height - to see any measurable effect, and concluded that it was better for the casual flier to fly best lift/drag speed instead... I think they used a G103. The notation from the index is: Hadfield, Chris; with Chuck Louie, Ken Green, Rick Husband and Nate Jones Is Ground Effect Worth It? [Aerodynamics], February, page 33 Chris Hadfield was a Canadian mission specialist on the Shuttle; two flights, two spacewalks; top test pilot of his class at Edwards; and US Navy Test Pilot of the Year for a F/A-18 out of control recovery test program; Rick Husband was the crew commander on Columbia which was destroyed on re-entry in Feb 2003, his second shuttle flight. It might be worth getting the article reprint if you're interested in the theory, or e-mail Edwards Test Pilot School for the report; I bet it's swimming in math! IF you do, let us know how good my memory held up. DD |
nafod40 wrote:
Interesting observation. Flying in ground effect places the center of pressure of the wing at about mid-chord, while out of ground effect the Are you sure? Note that a forward CG implies a pitch down moment which would have to be compensated by negative lift on the tail. Hence performance degradtation, contrary to what ground effect is supposed to create. I'm still searching for a good explanation of ground effect :-) Cheers -Gerhard -- Gerhard Wesp o o Tel.: +41 (0) 43 5347636 Bachtobelstrasse 56 | http://www.cosy.sbg.ac.at/~gwesp/ CH-8045 Zuerich \_/ See homepage for email address! |
FWIW Earlier I said this effect worked better with
low wing gliders. Bill Daniels queried low wing, Bill I stand corrected! My only experiences are with Ask 4's and Ask7(high wing) many years ago and later ASK13, Grob and Puchacz. As Bill correctly says these later ones are mid wing rather than low wing, however the effect appears more marked with the mid wing gliders than the higher ones. Gethard, for a better explanation see http://www.se-technology.com/wig/index.php where there is both a description and pictures. At 11:06 19 October 2004, Gerhard Wesp wrote: nafod40 wrote: Interesting observation. Flying in ground effect places the center of pressure of the wing at about mid-chord, while out of ground effect the Are you sure? Note that a forward CG implies a pitch down moment which would have to be compensated by negative lift on the tail. Hence performance degradtation, contrary to what ground effect is supposed to create. I'm still searching for a good explanation of ground effect :-) Cheers -Gerhard -- Gerhard Wesp o o Tel.: +41 (0) 43 5347636 Bachtobelstrasse 56 | http://www.cosy.sbg.ac.at/~gwesp / CH-8045 Zuerich \_/ See homepage for email address! |
Gerhard Wesp wrote:
nafod40 wrote: Interesting observation. Flying in ground effect places the center of pressure of the wing at about mid-chord, while out of ground effect the Are you sure? Note that a forward CG implies a pitch down moment which would have to be compensated by negative lift on the tail. Hence performance degradtation, contrary to what ground effect is supposed to create. That part would be minor, more than compensated for by decrease in induced drag and increase in lift. I'm still searching for a good explanation of ground effect :-) Here's a killer page describing the aerodynamics of it. Follwoing is a short excerpt from the page. http://www.se-technology.com/wig/htm...en=aero&code=0 Two phenomena are involved when a wing approaches the ground. Ground effect is one name for both effects which is sometimes confusing. The two phenomena are sometimes referred to as span dominated and chord dominated ground effect. The former results in a reduction of induced drag (D) and the latter in an increase of lift (L). The overall effect is an increase of the L/D ratio. This ratio is a measure for the efficiency of an aircraft which can be expressed as the amount of power (thrust) that is required to propell an aircraft of a certain weight. Since thrust is equal to drag and weight is equal to lift in stationary flight this efficiency can be expressed as the L/D ratio. As the L/D of a wing increases with decreasing ground clearance the craft becomes more efficient in ground effect. |
The Hughes HK-1 Flying Boat (commonly and mistakenly called the Spruce Goose
since those closer to the project called it the Birch Bitch) was designed to fly the entire flight in ground effect. It is displayed a short distance from my home. When first acquired by Evergreen Museum, consideration was given to fly it to the new home. However, the local fire marshall had required a fire retardant to be sprayed on the aircraft before it was originally put on display and that forever destroyed the ability to fly. Now that would have been a sight to behold - the HK-1 soaring the Sierra Nevadas in a Wave. Colin N12HS --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/04 |
![]() "COLIN LAMB" wrote in message nk.net... The Hughes HK-1 Flying Boat (commonly and mistakenly called the Spruce Goose since those closer to the project called it the Birch Bitch) was designed to fly the entire flight in ground effect. It is displayed a short distance from my home. When first acquired by Evergreen Museum, consideration was given to fly it to the new home. However, the local fire marshall had required a fire retardant to be sprayed on the aircraft before it was originally put on display and that forever destroyed the ability to fly. Now that would have been a sight to behold - the HK-1 soaring the Sierra Nevadas in a Wave. Colin N12HS Actually, Hughes wanted the HK-1 to use 8 Lycoming R-7755's but was forced by the government to use much less powerful Pratt & Whitney R-4360's. With 8 7000 HP Lyc's the HK-1 would have cruised in the stratosphere at a very respectable speed for the time. With the Pratts, all it could do was fly in ground effect. The Northrop B-35 flying wing was also supposed to get the R-7755 but the then Secretary of War owned a huge block of stock in P&W. The Smithsonian Air & Space Museum has placed the only remaining R-7755 on prominent display at Udvar-Hazy Center without political comment. The Lycoming engineers were confident that the R-7755 could be developed to produce 10,000 HP. Bill Daniels Bill Daniels |
Bill,
If memory serves me right the 4360 had 4 rows of 9 cylinders for a total of 36 jugs. The aft rows were spiraled to allow cooling to the rear rows, but even so, the fourth row would run hotter. (KC-97F --circa 1952) What was the configuration of the 7755? At 13:48 19 October 2004, Bill Lycoming engineers were confident that the R-7755 could be developed to produce 10,000 HP. |
![]() Uh-Oh! We've just discovered this winter's discussion topic. For what it's worth, Gale Craig, a physicist in Anderson, IN, has written a book titled, I believe, Why Airplanes Fly, in which he analyzes ground effect. He derives his theories from Newton rather than from Bernouilli. It is an interesting read. A second edition had the title changed to something like, Don't Abuse Bernouilli. The book is published privately and has been reviewed on the web. I can supply an address and telephone number to anyone interested. At 11:06 19 October 2004, Gerhard Wesp wrote: nafod40 wrote: Interesting observation. Flying in ground effect places the center of pressure of the wing at about mid-chord, while out of ground effect the Are you sure? Note that a forward CG implies a pitch down moment which would have to be compensated by negative lift on the tail. Hence performance degradtation, contrary to what ground effect is supposed to create. I'm still searching for a good explanation of ground effect :-) Cheers -Gerhard -- Gerhard Wesp o o Tel.: +41 (0) 43 5347636 Bachtobelstrasse 56 | http://www.cosy.sbg.ac.at/~gwesp / CH-8045 Zuerich \_/ See homepage for email address! |
John Sinclair wrote in message ...
Bill, If memory serves me right the 4360 had 4 rows of 9 cylinders for a total of 36 jugs. The aft rows were spiraled to allow cooling to the rear rows, but even so, the fourth row would run hotter. (KC-97F --circa 1952) What was the configuration of the 7755? http://www.aviation-history.com/engines/xr-7755.html -Dan |
The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 04:01 PM |
Toronto Area Glider Pilot Ground School Starts Thu. March 25, 2004 | Ulf | Soaring | 0 | March 3rd 04 05:02 PM |
Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 05:11 AM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
