Why the T-Tail?
Old October 29th 04, 02:00 AM
Doug Hoffman
Marian Aldenhövel wrote:
Hi,
Thank you all, I have learned a lot. I have also come up
with two more things to consider, both rather minor I suspect:
- The control linkages are propably more complicated
in a T-Tail (con).
- With a T-Tail you can build the elevator in one piece so you
can rig and derig more easily (pro).
Now why are we not seeing more V-Tails? The main pro for T-Tails
seem to be:
- Good ground clearance
- Less drag
- Operates in clean undisturbed air
How does a V-Tail stand up against that?
The V-Tail setup is less likely to cause fuse damage in a ground loop.
Regards,
-Doug
  #43
Old October 29th 04, 04:19 AM
Eric Greenwell
Hi,
in a T-Tail (con).
seem to be:
- Less drag
Couldn't the T-tail designer just make the fuselage stronger? Or the
V-tail designer make the fuselage lighter to take more advantage of the
lower tail CG, so they both withstand a ground loop just as well?
Maybe JJ or some other glider repairer can tell us how tail booms
commonly fail - torsion or bending, and if there seems to be a
difference in types of failure between the tail types.
Eric Greenwell
Washington State
USA
  #44
Old October 29th 04, 04:27 AM
Jim Vincent
Actually Steve, it was a V Tail ;-)
Was the Airbus that broke up over NY in 2001, according to the just released
NTSB report, from "Improper use of the rudder", a T tail?
Steve
Jim Vincent
N483SZ
illspam
  #45
Old October 29th 04, 04:31 AM
Jim Vincent
The designer could make the fuselage so strong that it would never break, no
matter how fast the ground loop of snap roll. But then the fuselage would be
twice the area, four times the weight, and the glider would never get off the
ground.It is all a trade off in strength to performance.
It is not a given that the tail will break in a ground loop. Most gliders are
designed to survive ground loops with no damange, 'cept maybe a dizzy pilot.
Jim Vincent
N483SZ
illspam
  #46
Old October 29th 04, 06:47 AM
F.L. Whiteley
Hi,
in a T-Tail (con).
seem to be:
- Less drag
Lotsa Libelle booms have been broken, but then the shape may have something
to do with that, or just the sheer numbers of Libelles built skews the
sample.
Several PIK-20 tail booms have unzipped along the lower fuselage seam from
ground loops. No idea how that compares to those that actually broke the
boom. From what I've heard, once repaired, they don't unzip again.
What about those booms that break in two places? Peculiar to make, or type
of accident?
Frank Whiteley
  #47
Old October 29th 04, 06:58 AM
F.L. Whiteley
Mis-rigging could happen to any type. A school teacher was killed in Wales
one day while I was soaring due to mis-rigging one of the ruddervator
control guides on his v-tailed BG-135, diving in from the top of the winch
launch (his second of the day). It was only the second occasion he'd rigged
the glider IIRC. Could have been a t-tail.
I flew a v-tailed SHK for four years. The rigging of the control guides was
very similar and held the same potential for being mis-rigged as the
aforementioned BG-135. The sad part is that the guide is clearly in view
during control deflection. This is one very specific instance where a PCC
might not have detected the problem, but a visual inspection would. The
fact that he made the first flight successfully attests to this. The actual
disconnect probably happened during ground handling or during he landing
role and wasn't noticed before the second flight.
Frank Whiteley
"Mark James Boyd" wrote in message
news:41818446$1@darkstar...
This is the only fatality I am aware of at Avenal, and the
only ruddervator mechanism-related T-tail fatality I have read.
NTSB Identification: LAX92LA393 .
The docket is stored on NTSB microfiche number 48074.
14 CFR Part 91: General Aviation
Accident occurred Friday, September 18, 1992 in AVENAL, CA
Probable Cause Approval Date: 9/14/1993
Aircraft: SPARKS-SCHREDER HP-140V, registration: N704B
Injuries: 1 Fatal.
Prob cause:
" THE LOSS OF PITCH AND YAW CONTROL DUE TO THE SEPARATION OF THE
RUDDERVATOR CONTROL CABLE FROM ITS CLEVIS FORK DUE TO IMPROPER
INSTALLATION."
Peter Wyld wrote:
At 08:54 28 October 2004, Marian_Aldenhövel wrote:
Hi,
up
I suspect:
in a T-Tail (con).
piece so you
for T-Tails
seem to be:
- Less drag
Complicated mixing box required for elevator/rudder
control.
Mark J. Boyd
  #48
Old October 29th 04, 07:23 AM
Bruce Greeff
John Giddy wrote:
On Thu, 28 Oct 2004 08:07:07 +0200, Bruce Greeff wrote:
John Giddy wrote:
On 28 Oct 2004 02:44:06 GMT, Jim Vincent wrote:
Jim,
Why does the elevator have more translation on a T-Tail than on a
conventional one please ? (I presume you are referring to translation
in a direction normal to the tailplane surface)
Bemused John G.
John,
If the stab is mounted at the fuselage, if there is roll, the stab only
experiences a rotation around the center of the stab.
If the stab is T, then not only is it rotating, it is also moving in a circle
with a diameter of the rudder fin. Does that make sense?
Also, with a T, if you go full rudder in one direction then another, the fin
adds the inertia of the stab mounted at the top of the rudder...a torsion from
yaw too!
Jim Vincent
N483SZ
OK Jim,
I agree. I was thinking of normal elevator operation, and movement in
the pitch direction, which is the same for both arrangements.
Cheers, John G.
The one that tends to break them is the torque resulting from rapid translation
acceleration. With a T-tail the moment of inertia is far greater, so when you
ground loop, or perform a flick maneuver the lateral acceleration of the
elevator imposes large loads on the structure.
Agreed, except that it is not just the elevator. It is the whole
tailplane.
Cheers, John G.
I stand corrected - Cirrus drivers sometimes forget that there are sailplanes
that have fixed horisontal stabilisers... ;-)
  #50
Old October 29th 04, 09:07 AM
John Giddy
On Fri, 29 Oct 2004 08:23:18 +0200, Bruce Greeff wrote:
Jim,
Bemused John G.
John,
yaw too!
Jim Vincent
N483SZ
OK Jim,
Cheers, John G.
tailplane.
Cheers, John G.
That thought had crossed my mind, but I resisted the chance to point
it out :-)
Cheers, John G. (Std Cirrus Ser: 6720
Tail Skid Help / Advice Ray Lovinggood Soaring 3 January 2nd 04 08:16 PM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
