#51
[Warning: somewhat long off-topic ramble ahead]
Earlier, Doug Hoffman wrote: The V-Tail setup is less likely to cause fuse damage in a ground loop. That's my experience as well, but I think that it has more to do with the lightweight-yet-rugged aluminum semi-monocoque aft fuselages that Dick Schreder hung on his gliders. ![]() Schreder aft fuselage crumpled aft of about the wing root; and yet I've seen plenty of composite tailbooms broken at or near the fin root. One of the substantial issues is how you mass-balance the controls, and how much. It's easy to look at the centroids of a pair of diagonal surfaces, and note that it is closer to the fuselage axis than the centroid of a pair of T-tail surfaces. However, the weight of the actual tail surfaces often has very little correspondence with the centroid. With the Schreder V-tail surfaces in particular, the chunks of mass-balance lead on the ruddervator end plates move the center of mass of the combined stabilizer/ruddervator pretty far from the axis of the fuselage. With a T-tail, the envelope of the vertical fin gives you some good opportunities to move the balance masses closer to the axis of the fuselage. With the rudder, you can concentrate the mass near the lower hinge. And for the elevator you can either locate the mass balance at the bellcrank at the fin root, or as in the case of the later LS gliders just use the elevator push-pull tube itself as the mass balance. Of course, the most effective (some might say the only effective) mass balance is to distribute the counterweight along the hinge line of the surface. However, the practical experience of the European manufacturers seems to be that concentrated mass balances can be adequate if implemented correctly on relatively stiff control surfaces. On the other hand, and I think this is what Doug is pointing out, the thing to watch out for is not necessarily the distance between the center of mass of the tail surfaces and the fuselage axis. For groundloop resistance, the distance between the center of mass of the tail surfaces and the plane of the waterline of the fuselage gets important. That's the plane (plus and minus a few degrees for dihedral and wing flex, of course) in which lateral groundloop forces are applied to the tailwheel. And with a V-tail, the center of mass will be closer to the waterline plane than to the fuselage axis (by a factor of .707 for a 90-degree included angle like Dick always used). As an aside, when Stan Hall located the balance masses at the outboard ends of the tail surfaces on his pretty little Ibex, he experienced a flutter mode in which the slender tailboom flexed in torsion. Since he was using all-moving tail surfaces, he was able to fix the problem by moving the mass balance weights to the inboard ends of the stabilizers. His tailboom was more slender than Dick's RS-15 boom, and much more slender than Dick's semi-monocoque tails, though, so I don't consider his experience to be particular cause for worry in the HP world. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
#53
Doug Haluza wrote:
A wake vortex is generated at each end of a wing generating lift in a free flow. So the vortex is generated at both ends of the fin, not just the "tip". Therefore, the T-tail does not produce one less vortex. Also, since the vertical stab is usually at zero angle of attack (except when maneuvering or flying with one wing low) there is no vortex most of the time, anyway. So this is not a factor at all. The Fundamentals of Sailplane design (pages 147-148) has a discussion of the empennage types. A selective summary of this is.. * the conventional tail (fuselage mounted) isn't used because of poor ground clearance * the cruciform tail (ASW-17, Liable) improves the clearance but creates increased interference drag due to the four corners created at the intersection of the horizontal and vertical stabilizers * the Vee tail is the most difficult to achieve the desired spin and other control responses and tends to have higher induced drag * the T-tail avoids all the above, with the high placed weight of the horizontal surface being the main challenge Not addressed in the FOSD book, but as Bob K mentions (and Waibel and others), other factors affect the designers choices, such as aesthetics and manufacturing costs. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#54
Hi,
So why did you say it! To fill the white space at the bottom of postings, to waste bandwidth and to confuse readers. Oh, and it is somewhat on topic because I got it from http://www.mountainflying.com/mountology.htm Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn. Fon +49 228 624013, Fax +49 228 624031. http://www.marian-aldenhoevel.de "I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant." |
#55
![]() "I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant." So why did you say it! ![]() sorry couldn't resist... Gail |
#56
Udo Rumpf wrote:
Hi, Thank you all, I have learned a lot. I have also come up with two more things to consider, both rather minor I suspect: - The control linkages are propably more complicated in a T-Tail (con). - With a T-Tail you can build the elevator in one piece so you can rig and derig more easily (pro). Now why are we not seeing more V-Tails? The main pro for T-Tails seem to be: - Good ground clearance - Less drag - Operates in clean undisturbed air How does a V-Tail stand up against that? Ground clearance is not an issue (I speak from experience) It is questionable as to it having less drag. The theory says yes. In practise it is not as easy to design a V tail that can match the T tail. The lower part of the vertical stab on a T tail is in disturb air as well. In case of the V tail you would have two surfaces in the disturb air. The mixer is a simple and light weight mechanical device. If built and installed right cross interference is minimal. Udo The V-tail is inherently less efficient than tails with separate horizontal and vertical surfaces (conventional and T tails) as a pitch stabilizer. For any speed except maybe just one, the horizontal stabiliser has to provide some vertical force in order that the glider remain trimmed. But in order to obtain the same vertical force from a V-tail, the normal forces on both surfaces need to be higher than the half of the total vertical force, because only their vertical component is useful, there are also horizontal components which cancel each other. But this increased normal force is lift and so produces an increased induced drag. Not very important if the V is very flat, but then the efficiency in yaw control, i.e. as a rudder and fin, is poor and a similar argument may be developed: now we are interested in the horizontal component and the vertical (higher) components are a nuisance increasing induced drag. However no such component exists in steady straight flight, so the inconvenience is less important. It may happen that in a very well suited situation of steady turn the above argument may be reversed in favor of V-tails: other tails need down elevator forces and outside turn rudder force, the resulting force being closer to the horizontal direction than both the preceding one could be provided with less induced drag by just one of the ruddervators if properly oriented. But I think that in performance oriented designs the priority is to minimize the drag in straight flight, and anyway this would be in favor of V-tail just for (some range around) some very well suited bank angle and speed. , |
#57
At 11:24 02 November 2004, Marian_Aldenhövel wrote:
Hi, So why did you say it! To fill the white space at the bottom of postings, to waste bandwidth and to confuse readers. Sorry! That's the wrong 'it.' The 'it' in question is the hypothetical 'it' referred to in your quote rather than the quote itself. I'd guess the answer is because you didn't run the hypothetical statement past the 'hypothetical' editor in your mind before you uttered it -- an all too common failing. grin Oh, and it is somewhat on topic because I got it from http://www.mountainflying.com/mountology.htm Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn. Fon +49 228 624013, Fax +49 228 624031. http://www.marian-aldenhoevel.de 'I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.' |
#58
![]() "Robert Ehrlich" wrote in message ... Udo Rumpf wrote: Hi, Thank you all, I have learned a lot. I have also come up with two more things to consider, both rather minor I suspect: - The control linkages are propably more complicated in a T-Tail (con). - With a T-Tail you can build the elevator in one piece so you can rig and derig more easily (pro). Now why are we not seeing more V-Tails? The main pro for T-Tails seem to be: - Good ground clearance - Less drag - Operates in clean undisturbed air How does a V-Tail stand up against that? Ground clearance is not an issue (I speak from experience) It is questionable as to it having less drag. The theory says yes. In practise it is not as easy to design a V tail that can match the T tail. The lower part of the vertical stab on a T tail is in disturb air as well. In case of the V tail you would have two surfaces in the disturb air. The mixer is a simple and light weight mechanical device. If built and installed right cross interference is minimal. Udo The V-tail is inherently less efficient than tails with separate horizontal and vertical surfaces (conventional and T tails) as a pitch stabilizer. For any speed except maybe just one, the horizontal stabiliser has to provide some vertical force in order that the glider remain trimmed. But in order to obtain the same vertical force from a V-tail, the normal forces on both surfaces need to be higher than the half of the total vertical force, because only their vertical component is useful, there are also horizontal components which cancel each other. But this increased normal force is lift and so produces an increased induced drag. Not very important if the V is very flat, but then the efficiency in yaw control, i.e. as a rudder and fin, is poor and a similar argument may be developed: now we are interested in the horizontal component and the vertical (higher) components are a nuisance increasing induced drag. However no such component exists in steady straight flight, so the inconvenience is less important. It may happen that in a very well suited situation of steady turn the above argument may be reversed in favor of V-tails: other tails need down elevator forces and outside turn rudder force, the resulting force being closer to the horizontal direction than both the preceding one could be provided with less induced drag by just one of the ruddervators if properly oriented. But I think that in performance oriented designs the priority is to minimize the drag in straight flight, and anyway this would be in favor of V-tail just for (some range around) some very well suited bank angle and speed. Robert You are right on all counts. I think it is still worse due to the fact the elevator and rudder action has to be combined. The elevator/rudder chord for the HP V Tail, for example, is 55% chord at the tip and 45% at the root. The size is dictated due to the combined controls when max deflexion is required for both controls, as deflection has to stay around 25 to 30 deg. To compare the elevator and ruder of a modern T tail which has only 25% chord and 30% respectively, which allows for a substantial laminar flow region on both fixed surfaces. There is also no question as to the superiority of the T tail regarding the interference drag. The T juncture on a T tail is more efficient then the V juncture, due to the T tail surfaces being aerodynamically off set, also the total wetted area is less. Regards Udo |
Tail Skid Help / Advice | Ray Lovinggood | Soaring | 3 | January 2nd 04 08:16 PM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Owning | 1 | July 26th 03 11:34 AM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Piloting | 1 | July 26th 03 11:34 AM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
