After my nice flight last month in Mt. Rainier wave to 24k, my wings have
turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
A number of years ago I had a serious dose of blistering
on a Discus fuselage. I asked around several UK repair shops and the only one who had a repair plan beyond just sanding and refinishing was Bob McLean (the UK DG agent) who said what he recommended was to sand off the gel to the glass cloth, leave the exposed area to dry off under controlled warming for a few days until it was bone dry, then paint the surface of the glass cloth with a thin layer of resin to seal it and let it dry and then refinish with gelcoat and reweigh. He did a beatiful job and we never got another single blister in the repaired area. John Galloway At 23:01 02 December 2004, Steve Hill wrote: After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015' tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...aga in, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
The Gelcoat itself is slightly hygroscopic (sp?) and will therefore
absorb and retain some amount of water. If you refinish with Urethane that issue should go away and you shouldn't need to worry about moisture permeating the composite structure. Good luck, Mark Steve Hill wrote: After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
Steve:
Don't be in a hurry to do anything quick - except get the glider into a warm dry environment and leave it alone for a while. I saw this problem on some of the control surfaces of my old ASW-17 (which had been refinished years earlier with Prestec). By the time I had finished re-doing one aileron - the bubbles on the other one disappeared! The problem seems to be related to a combination of cold + moisture - but the bubbles (at least the tiny ones) are not necessarily permanent. Good luck Roy |
If Steve normally keeps his DG in Western Washington, be aware that average
annual AM humidity is around 83% and average annual PM humidity is around 62% around Puget Sound. GRP will also accept moisture via osmosis and there's no gel or moisture barrier inside. Long term I suspect gliders may achieve some sort of equilibrium with their surroundings WRT to moisture content. It would be interesting if someone has done an accurate W&B on the same glider that's been at one of the more arid sites (=10% average relative humidity) for say 5 years, then moved to somewhere like western Washington for 5 years and noted if there's any measurable change. Depending on the airframe size and contruction type, I wouldn't be surprised to see variances of 2-10lbs due to moisture content. I found a moisture detection meter sites that indicate that 3% (not clear whether by mass or volume) is high moisture content in GRP substrate. GRP type products typically have a SG range of 1.2-1.9. FWIW, I've seen a couple of gliders exhibit small localized bumps from soaking wet trailer pads that vanished within 24 hours when dried, so unless there's obvious permanent deformation or checking, it may not mean there's debonding. I'm also aware of gliders that have had the gel severely damaged by cold soaking followed thermal shock in a humid locale. I suppose if the moisture goes through rapid phase state changes it could be damaging. I found this interesting http://www.cerf.org/pdfs/collab/durability/3.pdf Frank Whiteley "Mark Zivley" wrote in message . com... The Gelcoat itself is slightly hygroscopic (sp?) and will therefore absorb and retain some amount of water. If you refinish with Urethane that issue should go away and you shouldn't need to worry about moisture permeating the composite structure. Good luck, Mark Steve Hill wrote: After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
I've got the same problem Steve does with my Apis. This is a brand new
glider with a brand new Prestec finish. We sprayed it on during the winter of 2002, and by the winter of 2003 it had developed a nasty rash of bubbles all along the LE of the wings and all over the stabilizer. They mostly dissapeared the following summer, but are starting to reappear now that the winter is here. Oh well.......sigh.......! Brad 199AP "F.L. Whiteley" wrote in message ... If Steve normally keeps his DG in Western Washington, be aware that average annual AM humidity is around 83% and average annual PM humidity is around 62% around Puget Sound. GRP will also accept moisture via osmosis and there's no gel or moisture barrier inside. Long term I suspect gliders may achieve some sort of equilibrium with their surroundings WRT to moisture content. It would be interesting if someone has done an accurate W&B on the same glider that's been at one of the more arid sites (=10% average relative humidity) for say 5 years, then moved to somewhere like western Washington for 5 years and noted if there's any measurable change. Depending on the airframe size and contruction type, I wouldn't be surprised to see variances of 2-10lbs due to moisture content. I found a moisture detection meter sites that indicate that 3% (not clear whether by mass or volume) is high moisture content in GRP substrate. GRP type products typically have a SG range of 1.2-1.9. FWIW, I've seen a couple of gliders exhibit small localized bumps from soaking wet trailer pads that vanished within 24 hours when dried, so unless there's obvious permanent deformation or checking, it may not mean there's debonding. I'm also aware of gliders that have had the gel severely damaged by cold soaking followed thermal shock in a humid locale. I suppose if the moisture goes through rapid phase state changes it could be damaging. I found this interesting http://www.cerf.org/pdfs/collab/durability/3.pdf Frank Whiteley "Mark Zivley" wrote in message . com... The Gelcoat itself is slightly hygroscopic (sp?) and will therefore absorb and retain some amount of water. If you refinish with Urethane that issue should go away and you shouldn't need to worry about moisture permeating the composite structure. Good luck, Mark Steve Hill wrote: After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
I have had a glider that when it got below 32 it developed goose bumps all over
the wings. This was during the early 80's. The factory sent over folks to see this after they saw the pictures. It was found that when they sprayed the gel coat into the wing molds that mosture was present in the air compressure and the filtering system they were using was not getting all the mosture out. They took the glider back, and I got a brand new one. One of the few times that the factory stood up for its product. Thermal tight, Soar high, Fly safe, # 711. |
The way to fix them down is to drill a tiny hole at each end of the
bubble just big enough to allow a hyperdermic syringe with resin in ,inject resin in one end till it comes out the other ,put a small bag of sand over a piece of peel ply cloth (to absorb excess resin )over the bubble. when set,remove peelply and fine sand any residual resin. This should permanently adhere the skin surface down to the substrate gary "Steve Hill" wrote in message ... After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. |
On a slightly different note, it's been seen several times at our club
that it's really BAD to move a glider that's been in a very dry climate to a very humid climate, particularly if it's older gelcoat. The absorption of moisture seems to be the key to having the gel coat come off in LARGE chunks during the year or so after it's been in the moist environment. |
For what it's worth
We have an on going discussion in my club (in the UK where in winter it is cold and DAMP) about storing aircraft to avoid osmosis and bumps. One of our club syndicates have kept a discus for some years and are now keeping a ventus without any trouble by completely sealing a the trailer vents and installing an industrial grade de-humidifier within the trailer. This is permanently connected to power, it only uses a few pounds worth of electric every year and so is well worth the cost. Regards Robin In message , Steve Hill writes After my nice flight last month in Mt. Rainier wave to 24k, my wings have turned into a blistered nightmare on the DG-400. I probably have 2,000 small bubbles ranging from .005 to .015" tall...I've been sanding the gelcoat down in an effort to see if I can break through them, but I am nervous as hell if what I'm doing is a bad idea...Is there any chemical that will remove Gelcoat and not hurt the substrate, or is the best method to actually just sand till ya can't sand no more??? Anyway...my thought is to sand the wings down, but then I'm not really clear on what's going to keep the moisture from returning for good...it seems like baking the wings is a decent idea, though for now I'm not exactly sure how and at what temperature...Anyone's input will be appreciated...again, the worry is that if you go to all the trouble to sand things down to bare material, is there a way to assure that the bubbles don't come back in the future. My plan would be to re-finish with one of the PolyUrethane systems...So, time, temp, advice or chemicals!!!! Thanks Steve. -- Robin Birch |
| Humpback whales - a source of new aerodynamics? | Martin Gregorie | Soaring | 6 | May 28th 04 09:47 PM |
| Thermal mapping | John | Soaring | 35 | April 27th 04 05:29 PM |
| DuoDiscus Wing | Duane Eisenbeiss | Soaring | 27 | October 31st 03 03:34 AM |
| Restoring bubbles... | The Raven | Restoration | 4 | July 7th 03 07:07 PM |
