Winch accident in New Zealand, can low time student pilot be blamed?
Old December 3rd 04, 11:15 PM
Andre Volant
Default Winch accident in New Zealand, can low time student pilot be blamed?
http://www.glidingmagazine.com/NewsArticle.asp?id=1371
Correct "CG" release was used, which on PW5 is offsett forward of the
CG.
I was told that the nose hook is not allowed for winch towing of PW5.
That's what manual sais, but who knows why?
Which other gliders are not allowed to be winched by the nose?
I was told that PW5 has front and rear ballast weights, how
complicated is it?
Who is resposible for checking weight and ballance, if for example
student pilot has 3 hours (40 flights X 5min) of flight experience?
When does resposibility of flight instructor end?
Andre
Old December 4th 04, 12:21 AM
Bill Daniels
"Andre Volant" wrote in message
om...
CG.
As is supposed to be the case.
Because winching with a nose hook causes a glider to porpoise.
Any glider with a CG hook. Many gliders are equipped with ONLY a CG hook.
complicated is it?
Probably not complicated at all.
There was nothing in the Gliding Magazine story about this level of
experience. However, 40 flights and 3:20 of instruction should have been
plenty for a rated pilot to make the transition to winch launch.
The pilot in command is always responsible for weight and balance.
This post and the Gliding Magazine story seems to suggest that there is
something wrong with the use of a CG hook. In fact, there is a great deal
wrong with NOT using a CG hook for winch launch.
A very FEW older gliders exhibit a behavior where the nose will pitch up
uncontrollably if the winch acceleration is too strong. These gliders
usually have high CG's, low CG hooks and small tail surfaces and/or all
moving tails that limit down elevator authority. Good winch drivers know
about them and reduce acceleration accordingly. I don't know if the PeeWee
exhibits these characteristics - since it is a modern design, I doubt that
it does.
The usual cause for accidents of this type is a pilot who starts a climb
before the glider achieves a safe airspeed. This can be compounded in
modern gliders which often require NO back pressure to enter the climb. If
the pilot in under the impression that a strong pull on the stick is
required to enter the climb, problems of this sort may result.
We need to wait the results of the investigation. Rushing to blame the
glider design is almost always the wrong thing to do.
Bill Daniels
Old December 4th 04, 01:30 AM
Mal
I had a Hornet kite on me one time the winch driver saw it and gave it to
the winch.
The trim went to full back as I rotated as the aircraft has the stupidest
spring loaded trim system in the world for winch launching DANGER !
Does the PW5 have the same trim system says the guy was Asian so most of
them are light weights to add to his C of G problems.
Mal
"Bill Daniels" wrote in message
news:dy6sd.186163$HA.103320@attbi_s01...
om...
CG.
complicated is it?
PeeWee
it does.
If
Bill Daniels
Old December 4th 04, 03:45 AM
goneill
I belong to the club where this happened .
The inquiry is still going on but from comments made by
people actually there when it happened.
The pilot had already flown earlier in the day in the same glider.
The witnesses said the pilot rotated early and was a bit steep in the
initial climb but then started to turn right when in full climb
at around 300 ft, the deviation to the right continued until back release
occurred when the PW5 promptly rolled into a spin.
Partial recovery seemed to happen and the PW5 landed straddling a
driveway. The farm type 7 wire fences on either side of that driveway
acted like arrestor wires.The pilot has 2 broken ankles a
broken arm and other minor injuries.The pilot I think is from Hong Kong
and I believe has already been flown home.
The PW5 is known to want to go to full climb quickly if not prevented
but I know a Nimbus 2 will do exactly the same if winched a bit quick so
don't blame the glider ,this accident has the look of pilot error.
A lot of the training here is on the 2 seat PW6 so type conversion problems
are likely not an issue.
gary
om...
CG.
complicated is it?
Andre
Old December 4th 04, 01:22 PM
Stefan
Judging from my lawn-chair, I'm tempted to say: Watch your airspeed!
Stefan
Old December 4th 04, 03:39 PM
Chris OCallaghan
Andre,
Cg hooks require more pilot attention as the tow line/wire does not
provide any additional stability as is the case with a nose hook. In
fact, it can severly aggrevate misuse of the controls. This is why a
nose hook is always preferred for aerotow.
For ground launches using a nose hook, the principal problem would
appear to be overpowering the elevator. The higher your angle of
climb, the more elevator would be required to keep the cable from
pitching the nose down. (A cg hook would not affect stick pressures
since the force vector is through the glider's cg, ie, no/little
forward pitch moment). Aside from load and structure problems, here's
the real killer. If the cable breaks, you have nearly full rear stick
applied. If not release immediataley, you are likely to enter a low
altitude, accelerated stall. Bad news.
I suspect that the problem related in the article was an acceleratated
stall while still on the cable. This would explain loss of control and
back release. It's not hard to see how an inexperienced pilot might
abuse the controls during launch and wind up in just such a situation.
(Andre Volant) wrote in message . com...
CG.
complicated is it?
Andre
Old December 4th 04, 06:10 PM
Mark James Boyd
On aerotow, my top two critical items on the PW-5 were
trim set forward
spoilers locked
I'd love to know where this PW-5 trim was set. Anyone look at it after the
accident? I used to set 3 for launch, and use 7 or 8 (edge of stall) for
thermalling only.
gary
. com...
CG.
complicated is it?
Andre
Mark J. Boyd
Old December 4th 04, 10:40 PM
Robert Ehrlich
Dans l'article , Stefan
Not only the airspeed. As the load factor may be high despite the pilot
doesn't feel it, the angle of attack may be near the stall angle with a
speed well over the normal 1g stall speed. Maybe the only symptom of the
near stall angle of attack in this case is the loss of roll damping and
the ensuing tendancy to drop a wing which is much more easily countered
with the rudder than the elevator. The fact that the glider involved in
the accident started to bank to the right may be an indication that this
was the case.
Old December 5th 04, 02:17 AM
Charles Yeates
Agree --
In Nova Scotia, at a winch only club with 20+ years experience, a fatal
accident occurred during a launch. The pilot accelerated and took off
normally, then rotated toward full climb sooner than we teach. The HP18
had a high speed stall and spun rapidly on the wire and into the ground
from no more than 300 feet. This was the pilot's second launch of the
day. The first was normal. Too steep too soon can result in a high speed
stall.
I winch launched my PW5 at this home club for five years -- no problems
but I paid close attention to maintaining control of the flight
attitude and launch profile -- as I did on all the other ships that the
club operates.
The club Ka8 was noticeably harder to control at the begining of a
launch but we never had a launch accident with either glider type.
Old December 5th 04, 08:12 AM
John Giddy
om...
CG.
complicated is it?
it does.
There have been a couple of incidents in OZ with PW-5s responding
badly to aggressive winch acceleration. I don't know the details
though.
Cheers, John G.
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 06:40 PM
Who's At Fault in UAV/Part91 MAC? Larry Dighera Instrument Flight Rules 24 April 29th 04 04:08 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 06:39 AM
