Does anyone have a diagram of a meter that can be used to determining
the quality of the battery 12volt. Paul |
Are you interested in the current charge state of the battery or it's
ability to provide power for the duration of the day? For the charge state you simply need to use a voltmeter. 12.5 to perhaps 13 volts would be ok. On charge the battery should be getting 13.5 to 13.8 volts. If you want to test your battery's capacity you need to connect the battery directly to a large resistor and monitor the voltage on the battery for a couple hours. A 10 ohm, 25 watt resistor will work and by using a 10 ohm resistor it's easy to compute what the current is by looking at the voltmeter. 12 / 10 = 1.2 Amps. Be careful, this resistor will be hot! The standard "gel cell" should stay above 12 volts for several hours if it's "good". My two cents anyway. Mark Paul Feltz wrote: Does anyone have a diagram of a meter that can be used to determining the quality of the battery 12volt. Paul |
Mark Zivley wrote:
Are you interested in the current charge state of the battery or it's ability to provide power for the duration of the day? For the charge state you simply need to use a voltmeter. 12.5 to perhaps 13 volts would be ok. On charge the battery should be getting 13.5 to 13.8 volts. To elaborate a little on what Mark mentioned: This voltage would be after it's fully charged. With a "good" charger, the voltage should be bit higher, about 14.4 to 14.8, before it drops back to 13.5 or so when charging is complete. If you want to test your battery's capacity you need to connect the battery directly to a large resistor and monitor the voltage on the battery for a couple hours. A 10 ohm, 25 watt resistor will work and by using a 10 ohm resistor it's easy to compute what the current is by looking at the voltmeter. 12 / 10 = 1.2 Amps. Be careful, this resistor will be hot! The standard "gel cell" should stay above 12 volts for several hours if it's "good". My two cents anyway. A good technique, but for the usual 7 AH battery, I'd use a 25 ohm, 10 watt resistor instead, as the load would be closer to the typical current draw in a glider. A fresh battery should stay above 11 volts for about 13-14 hours. Be sure to charge the battery at the end of the test, as it will degrade more rapidly if it sits around uncharged. Your glider's equipment might not function as low as 11 volts, but the test does give you an idea of how good the battery is compared to a new one. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
And to elaborate a bit on both Mark's and Eric's notes.
The modelling fraternity often completes these type of tests on their battery packs, you may find a suitable discharge unit available from their suppliers? (I have one from years ago here in the UK) It is good to create a graph of the results of each battery pack over a typical life span. You will quickly see then if the capacity is changing and how quickly. Remember, over charging is often the killer for all batteries. Malcolm... "Eric Greenwell" wrote in message ... Mark Zivley wrote: Are you interested in the current charge state of the battery or it's ability to provide power for the duration of the day? For the charge state you simply need to use a voltmeter. 12.5 to perhaps 13 volts would be ok. On charge the battery should be getting 13.5 to 13.8 volts. To elaborate a little on what Mark mentioned: This voltage would be after it's fully charged. With a "good" charger, the voltage should be bit higher, about 14.4 to 14.8, before it drops back to 13.5 or so when charging is complete. If you want to test your battery's capacity you need to connect the battery directly to a large resistor and monitor the voltage on the battery for a couple hours. A 10 ohm, 25 watt resistor will work and by using a 10 ohm resistor it's easy to compute what the current is by looking at the voltmeter. 12 / 10 = 1.2 Amps. Be careful, this resistor will be hot! The standard "gel cell" should stay above 12 volts for several hours if it's "good". My two cents anyway. A good technique, but for the usual 7 AH battery, I'd use a 25 ohm, 10 watt resistor instead, as the load would be closer to the typical current draw in a glider. A fresh battery should stay above 11 volts for about 13-14 hours. Be sure to charge the battery at the end of the test, as it will degrade more rapidly if it sits around uncharged. Your glider's equipment might not function as low as 11 volts, but the test does give you an idea of how good the battery is compared to a new one. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
X-no-archive: yes
In article , Malcolm Austin writes And to elaborate a bit on both Mark's and Eric's notes. The modelling fraternity often completes these type of tests on their battery packs, you may find a suitable discharge unit available from their suppliers? (I have one from years ago here in the UK) It is good to create a graph of the results of each battery pack over a typical life span. You will quickly see then if the capacity is changing and how quickly. Remember, over charging is often the killer for all batteries. Malcolm... "Eric Greenwell" wrote in message ... Mark Zivley wrote: Are you interested in the current charge state of the battery or it's ability to provide power for the duration of the day? For the charge state you simply need to use a voltmeter. 12.5 to perhaps 13 volts would be ok. On charge the battery should be getting 13.5 to 13.8 volts. To elaborate a little on what Mark mentioned: This voltage would be after it's fully charged. With a "good" charger, the voltage should be bit higher, about 14.4 to 14.8, before it drops back to 13.5 or so when charging is complete. If you want to test your battery's capacity you need to connect the battery directly to a large resistor and monitor the voltage on the battery for a couple hours. A 10 ohm, 25 watt resistor will work and by using a 10 ohm resistor it's easy to compute what the current is by looking at the voltmeter. 12 / 10 = 1.2 Amps. Be careful, this resistor will be hot! The standard "gel cell" should stay above 12 volts for several hours if it's "good". My two cents anyway. A good technique, but for the usual 7 AH battery, I'd use a 25 ohm, 10 watt resistor instead, as the load would be closer to the typical current draw in a glider. A fresh battery should stay above 11 volts for about 13-14 hours. Be sure to charge the battery at the end of the test, as it will degrade more rapidly if it sits around uncharged. Your glider's equipment might not function as low as 11 volts, but the test does give you an idea of how good the battery is compared to a new one. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA The is available an 'intelligent battery tester' that will quickly measure battery capacity without the need to do a measured discharge. Visit www.actmeters.com. The model I use is ACT-IBT, although the price may put some people off (web site has prices in pounds and dollars). Best regards, Tim Newport-Peace (No commection with ACT meters except as a user). |
"Tim Newport-Peace" ] wrote in message ... X-no-archive: yes In article , Malcolm Austin writes And to elaborate a bit on both Mark's and Eric's notes. The modelling fraternity often completes these type of tests on their battery packs, you may find a suitable discharge unit available from their suppliers? (I have one from years ago here in the UK) It is good to create a graph of the results of each battery pack over a typical life span. You will quickly see then if the capacity is changing and how quickly. Remember, over charging is often the killer for all batteries. Malcolm... "Eric Greenwell" wrote in message ... Mark Zivley wrote: Are you interested in the current charge state of the battery or it's ability to provide power for the duration of the day? For the charge state you simply need to use a voltmeter. 12.5 to perhaps 13 volts would be ok. On charge the battery should be getting 13.5 to 13.8 volts. To elaborate a little on what Mark mentioned: This voltage would be after it's fully charged. With a "good" charger, the voltage should be bit higher, about 14.4 to 14.8, before it drops back to 13.5 or so when charging is complete. If you want to test your battery's capacity you need to connect the battery directly to a large resistor and monitor the voltage on the battery for a couple hours. A 10 ohm, 25 watt resistor will work and by using a 10 ohm resistor it's easy to compute what the current is by looking at the voltmeter. 12 / 10 = 1.2 Amps. Be careful, this resistor will be hot! The standard "gel cell" should stay above 12 volts for several hours if it's "good". My two cents anyway. A good technique, but for the usual 7 AH battery, I'd use a 25 ohm, 10 watt resistor instead, as the load would be closer to the typical current draw in a glider. A fresh battery should stay above 11 volts for about 13-14 hours. Be sure to charge the battery at the end of the test, as it will degrade more rapidly if it sits around uncharged. Your glider's equipment might not function as low as 11 volts, but the test does give you an idea of how good the battery is compared to a new one. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA The is available an 'intelligent battery tester' that will quickly measure battery capacity without the need to do a measured discharge. Visit www.actmeters.com. The model I use is ACT-IBT, although the price may put some people off (web site has prices in pounds and dollars). Best regards, Tim Newport-Peace (No commection with ACT meters except as a user). It looks like there's an opportunity for a data logger update here. The logger is already in the aircraft. It's generally connected to the battery. An 8 bit A/D would give an accuracy of 20 mV across the 10-15V range. Sampling once per minute or so should be adequate. Post-flight analysis should give you a pretty accurate idea of the health of the battery.. Battery health information doesn't really need to be real time, since you're probably not going to be able to replace it in the middle of a task, anyway. Tim Ward Tim Ward |
"Tim Ward" wrote in message ... It looks like there's an opportunity for a data logger update here. The logger is already in the aircraft. It's generally connected to the battery. An 8 bit A/D would give an accuracy of 20 mV across the 10-15V range. Sampling once per minute or so should be adequate. Post-flight analysis should give you a pretty accurate idea of the health of the battery.. Battery health information doesn't really need to be real time, since you're probably not going to be able to replace it in the middle of a task, anyway. Tim Ward Tim Ward But it would be nice to know that you are flying with a failing battery. You can then limit the use of power hungry devices ( Personal stereo, head-up gunsight or electric shaver ) or simply cut the flight short before the battery goes duff. Maxim and others produce 'digital fuel gauges' or coulomb counters that are compatible with modern battery technologies. These basically measure the charge put in and power taken out of a battery whilst in-circuit with around 1% accuracy. Laptop and consumer electronics have these built into the packs these days. It would be simple to read the DFG using your navigational iPaq but the drawbacks are probably not worth the benefits. ( google Maxim MAX1660 for more info ) Ian |
X-no-archive: yes
In article , Tim Ward writes It looks like there's an opportunity for a data logger update here. The logger is already in the aircraft. It's generally connected to the battery. An 8 bit A/D would give an accuracy of 20 mV across the 10-15V range. Sampling once per minute or so should be adequate. Post-flight analysis should give you a pretty accurate idea of the health of the battery.. Battery health information doesn't really need to be real time, since you're probably not going to be able to replace it in the middle of a task, anyway. Tim Ward Tim Ward Sampling the voltage will only give the percentage discharge. As a battery ages, it's capacity drops. Thus for a new 7AH battery 50 percent charge is 3.5AH, but for an old battery with a remaining capacity of (say) 3AH will only have 1.5AH left at the 50 percent point. Tim Newport-Peace "Indecision is the Key to Flexibility." |
Since battery discharge is at a linear rate, you can usually begin the
discharge with a resistor and closely monitor the voltage for say one half hour. You can make a graph from the first half hour, monitored every 10 minutes or so, and extend the line created on a graph. It is a lot quicker than waiting for the entire discharge. Since capacity is the ability to resist change of voltage, you can also determine the capacity by monitoring how quickly the voltage changes on charge. Older batteries without the ability to hold a charge will also charge much quicker (compared to other batteries that are full capacity). This would be a useful test for a constant current charger rather than a constant voltage type. Colin Lamb N12HS --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04 |
"Tim Newport-Peace" ] wrote in message ... X-no-archive: yes In article , Tim Ward writes It looks like there's an opportunity for a data logger update here. The logger is already in the aircraft. It's generally connected to the battery. An 8 bit A/D would give an accuracy of 20 mV across the 10-15V range. Sampling once per minute or so should be adequate. Post-flight analysis should give you a pretty accurate idea of the health of the battery.. Battery health information doesn't really need to be real time, since you're probably not going to be able to replace it in the middle of a task, anyway. Tim Ward Tim Ward Sampling the voltage will only give the percentage discharge. As a battery ages, it's capacity drops. Thus for a new 7AH battery 50 percent charge is 3.5AH, but for an old battery with a remaining capacity of (say) 3AH will only have 1.5AH left at the 50 percent point. Tim Newport-Peace "Indecision is the Key to Flexibility." Yep. By post-processing the collected data, you could compare the discharge curves of the same battery with the same load, from flight to flight and see how it was holding up. If it's not holding up well, buy a new battery before you go flying again. Tim Ward |
| Thread Tools | |
| Display Modes | |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
