After seeing first hand the eggshell strength properties
of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
I think that the ASW-24 and -28 (maybe the -27 as well) are built with a
kevlar layer in the cockpit. It does not improve strenght, but provides splinter protection when the cockpit shatters. Fiberglass when broken is extremely sharp, so the kevlar makes the shell stay together and not splinter. I may be wrong, so anyone with more knowledge feel free to correct me! Good flights (winters almost over...) Jose M. "Stewart Kissel" escribió en el mensaje ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
And Schempp-Hirth gliders for many years. Apart fom
Kevlar material issues the modern German cockpits all have structural features to improving impact performance. Having had 2 syndicate partner's over the years who had major cockpit destroying impacts in our all glass-fibre gliders I think that the safety concerns are very real. To design, manufacture, prove and get the approvals for retrospective structural modifications to the cockpit might be very difficult and would likely cost more to an individual than changing gliders. John Galloway At 09:30 19 January 2005, J.A.M. wrote: I think that the ASW-24 and -28 (maybe the -27 as well) are built with a kevlar layer in the cockpit. It does not improve strenght, but provides splinter protection when the cockpit shatters. Fiberglass when broken is extremely sharp, so the kevlar makes the shell stay together and not splinter. I may be wrong, so anyone with more knowledge feel free to correct me! Good flights (winters almost over...) Jose M. 'Stewart Kissel' escribió en el mensaje ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
Kevlar, or other fibers(Spectra) have been added to cockpits and other
parts of fuselages for many years. The benefit of Kevlar is that it stretches a long way before it fails. This can extend the deceleration distance during impact and prevent, or reduce the secondary impulse that occurs when the structure fails. It also can serve to contain other broken fragments. A common structure now incorporates carbon fiber( very strong and stiff but fails catastrophically) with Kevlar or other material of similar characteristics which fail at longer extension to provide a stiff, strong and progressively failing structure. I think it is safe to say we can thank Gerhard Waibel for leading this innovation. Others now incorporate these improvements. As to "home improvement", that would obviously depend on the weak points of the subject glider and experience and capability of the person working on it. Long answer with no firm conclusion. UH J=2EA.M. wrote: I think that the ASW-24 and -28 (maybe the -27 as well) are built with a kevlar layer in the cockpit. It does not improve strenght, but provides splinter protection when the cockpit shatters. Fiberglass when broken is extremely sharp, so the kevlar makes the shell stay together and not splinter. I may be wrong, so anyone with more knowledge feel free to correct me! Good flights (winters almost over...) Jose M. "Stewart Kissel" escribi=F3 en el mensaje ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
John is correct in his points. To add just a bit of detail to the
current contruction technique that I'm aware of. In the cockpit, SH uses a weave that looks to be about 50/50 carbon fiber woven with Kevlar. The plan is that the carbon fibre gives very high strength and the Kevlar gives good toughness so that if the strength of the carbon is exceeded that the kevlar will hold things together. I'd be guessing, since I haven't actually seen it, but I wouldn't be surprised if all the major manufacturers were using this same materal in the cockpit areas. John Galloway wrote: And Schempp-Hirth gliders for many years. Apart fom Kevlar material issues the modern German cockpits all have structural features to improving impact performance. Having had 2 syndicate partner's over the years who had major cockpit destroying impacts in our all glass-fibre gliders I think that the safety concerns are very real. To design, manufacture, prove and get the approvals for retrospective structural modifications to the cockpit might be very difficult and would likely cost more to an individual than changing gliders. John Galloway At 09:30 19 January 2005, J.A.M. wrote: I think that the ASW-24 and -28 (maybe the -27 as well) are built with a kevlar layer in the cockpit. It does not improve strenght, but provides splinter protection when the cockpit shatters. Fiberglass when broken is extremely sharp, so the kevlar makes the shell stay together and not splinter. I may be wrong, so anyone with more knowledge feel free to correct me! Good flights (winters almost over...) Jose M. 'Stewart Kissel' escribió en el mensaje ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
carb.com has some visual samples of a carbon/kevlar hybrid cloth. The
kevlar part can be yellow, blue or red and looks quite appealing. I plan on using as the inside ply one layer of this material when I build my HP-24. Cheers, Brad |
So if one layer of that was glassed on to the floor...would
it perform as well as an inside ply? Or does it gain strength inside the sandwich...ie plywood? At 17:01 19 January 2005, Brad wrote: carb.com has some visual samples of a carbon/kevlar hybrid cloth. The kevlar part can be yellow, blue or red and looks quite appealing. I plan on using as the inside ply one layer of this material when I build my HP-24. Cheers, Brad |
this is avialable on HpH 304C/CZ gliders already
tim "Stewart Kissel" wrote in message ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
This seems to be at odds with a recent edict by the
BGA who have banned the use of carbon fibre and kevlar instrument panels because of the danger when they break. Both materials break with sharp jagged edges they say. At 09:30 19 January 2005, J.A.M. wrote: I think that the ASW-24 and -28 (maybe the -27 as well) are built with a kevlar layer in the cockpit. It does not improve strenght, but provides splinter protection when the cockpit shatters. Fiberglass when broken is extremely sharp, so the kevlar makes the shell stay together and not splinter. I may be wrong, so anyone with more knowledge feel free to correct me! Good flights (winters almost over...) Jose M. 'Stewart Kissel' escribió en el mensaje ... After seeing first hand the eggshell strength properties of glass cockpits when they hit objects, I have been thinking about how much protection I don't have between my spine and terra-firma. I have the astronaut foam, and otherwise it is just the seatpan and glass. I was chatting with my A+P about this while we had the seatpan out during my annual. Has anyone contemplated and/or added kevlar to their cockpits? Or is this just a nutty idea? I assume their would be a weight and balance issue, and also determining if the layup would in fact to any good. Comments? |
Earlier, Stewart Kissel wrote:
So if one layer of that was glassed on to the floor...would it perform as well as an inside ply? Or does it gain strength inside the sandwich...ie plywood? Dunno how relevant this is, but in no particular order: Kevlar can be nasty stuff to work with. The fibers are very tough, and you need special scissors to cut it effectively. It's not so bad to lay up and laminate. But once it's laminated and cured, it is troublesome to drill or sand - what you get is a fuzzy hole or a fuzzy edge. And then you have to deal with that fuzz. If you just throw resin at it, it's easy to end up with tough little Kevlar-cored resin spikes that stick out and poke you. I'd guess that one layer of Kevlar inside a cockpit tub won't do you much good in terms of raw impact protection. However, I think it will help keep all the rest of the bits of the cockpit stuck together, and that can help in a crash. It also might hurt. Crash sequences are very hard to predict, so beyond general guidelines it's pretty much a roll of the dice. But of course, kudos to Gerhard Waibel for his work in evaluating and implementing meaningful crashworthiness improvements backed up by actual test results. If you do consider adding a layer of Kevlar, I'd suggest you add a layer of glass on top of it to encapsulate it. Also, consider carefully the weight you're adding, and that it would be very difficult to remove. You're probably looking at about 2 square yards of coverage; with 5 oz kevlar and 8 oz glass and then doubling the fiber weight to account for the resin you're looking at the ballpark of 3 lbs. That might not sound like a lot, but you'll definitely be thinking of it on your next carry-out retrieve. One more thing, in my experience stuff like this tends to look easier than it is. Add two layers of stuff to an established concavity? No problem - right? That is, until you consider that the surface has all sorts of detail contours you'd have to work around. There are mounting provisions for the seat and seat pan and control stick, there are rudder cable tunnels and fixtures, the list goes on. I mean, it's doable, but it can get to be a lot harder than you might expect. Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
| Thread Tools | |
| Display Modes | |
| backup cockpit lighting | Josef Burger | Instrument Flight Rules | 35 | January 2nd 05 02:23 AM |
| Cat in the cockpit forces emergency landing | John Ousterhout | Piloting | 7 | August 15th 04 12:10 AM |
| Antonov vs Galaxy cockpit | Emilio | Military Aviation | 13 | July 2nd 04 07:15 AM |
| Cockpit sizes of standard Jantar | goneill | Soaring | 2 | December 28th 03 12:29 PM |
| Bell Jetranger cockpit dimensions | HW | Rotorcraft | 1 | September 16th 03 11:49 AM |
