Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
FAR Q: "IR" needed for IFR in an N-reg aircraft?
Old March 5th 05, 12:05 PM
Julian Scarfe
Default FAR Q: "IR" needed for IFR in an N-reg aircraft?
"Peter" wrote in message
I have the FAR/AIM 2005 and while this should be in there somewhere, I
can't find it.
The rule I am looking for is that an "instrument rating" is required
to operate an N registered aircraft under IFR, and this rule applies
worldwide.
FAR 61.3
"(a) Pilot certificate. A person may not act as pilot in command or
in any other capacity as a required pilot flight crewmember of a civil
aircraft of U.S. registry, unless that person--
(1) Has a valid pilot certificate or special purpose pilot
authorization issued under this part in that person's physical
possession or readily accessible in the aircraft when exercising the
privileges of that pilot certificate or authorization. However, when the
aircraft is operated within a foreign country, a current pilot license
issued by the country in which the aircraft is operated may be used;
(e) Instrument rating. No person may act as pilot in command of a
civil aircraft under IFR or in weather conditions less than the minimums
prescribed for VFR flight unless that person holds:
(1) The appropriate aircraft category, class, type (if required),
and instrument rating on that person's pilot certificate for any
airplane, helicopter, or powered-lift being flown;"
There's no territorial limitation mentioned. Whether the US has
extraterritorial jurisdiction over foreign nationals is another issue, but
most states, including the UK, delegate the requirement to the state of
registry, which makes it applicable.
Also, if it is in there, can anyone offer opinions on whether
"instrument rating" means an FAA IR, any ICAO IR, or that this is not
clearly specified.
My belief is that it would be a reasonable interpretation of 61.3(e) that if
the pilot's licence used is a foreign one, the IR may be on that licence.
Julian
Old March 5th 05, 03:30 PM
Chris
clearly specified.
if
Thank you Julian - I am sure you can see what I am getting at. The UK
IMC Rating is an "instrument rating" but it is non-ICAO and it
excludes Class A.
I have it in writing from the CAA that the validity of the IMC-R is
not limited to G-reg aircraft but they say the FAA might object. The
question is whether an N-reg plane flown in the UK by a UK PPL with an
IMC-R would be OK.
Some people have offered a view that the "instrument rating" mentioned
in the FARs must be an ICAO one, but I am not sure where exactly that
interpretation comes from, especially as the flight in question
*would* be legal in a G-reg aircraft.
The Instrument Rating referred to in the FAR is either the ICAO one or the
FAA one. However to use the ICAO rating in the US and have it included on
your FAA 61.75 certificate means taking the appropriate knowledge test for
ICAO holders. Outside the US the conditions of using the IR might vary
depending on the rules of the specific territory you are flying in. So
using a N reg aircraft in Singapore say with JAR certificates might be
difficult, but then it might be OK.
The UK IMC rating is not an instrument rating. The simple test is whether
the IMC confers the same privileges of the IR and it does not. Specifically
IMC holders cannot fly in Class A airspace.
The definitions of flying IFR vary between the US and the UK anyway. A basic
PPL can fly IFR but he cannot fly IMC. In the UK IFR only refers to the
flight rules not about weather conditions so that means setting the
altimeter to 1013mb above 3000 ft , the quadrantal rules, obstacle clearance
requirements etc.
Old March 5th 05, 08:27 PM
Julian Scarfe
excludes Class A.
No, I didn't figure out that that was what you were getting at. I though it
was about whether a JAA/IR holder could exercise the IR privileges on an
N-reg.
IMC-R would be OK.
I don't think there's much doubt that an IMC rating does not satisfy the
requirements of 61.3(e). However, there's an issue of whether or not
61.3(e) is relevant. It could certainly be argued that 61.3(a) permits you
to use a foreign licence including its full privileges when flying in that
foreign country. And there remains the issue of whether the FARs apply to
non-US nationals in their own territory except as delegated by local law.
(Nigel would argue that they do, I think.)
Julian
Old March 6th 05, 07:54 PM
Ron Rosenfeld
On Sat, 5 Mar 2005 14:30:18 -0000, "Chris" wrote:
A basic PPL can fly IFR but he cannot fly IMC.
Not under US rules.
Old March 6th 05, 09:58 PM
Chris
"Ron Rosenfeld" wrote in message
Not under US rules.
If your read the rest of the post you would have seen that I specifically
excluded the US
Old March 7th 05, 12:54 AM
Ron Rosenfeld
excluded the US
I did read your entire post, but the country to which you referred was not
clear to me when you wrote "A basic PPL can fly IFR but he cannot fly IMC",
so just a bit of clarification, in case others were also confused.
Co-Pilot/Crew needed for Parowan Contest Michael I Green Soaring 2 June 16th 04 05:42 AM
HA-6 Carburetor Info needed Stu & Kathy Fields Home Built 0 May 13th 04 07:05 PM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 05:28 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 05:32 AM
