Best coax for aircraft radios
Old January 11th 05, 05:39 PM
ELIPPSE
Sorry that you think this is a marketing ploy. I thought that this was
a forum for information exchange. I just wanted to pass along my
experiences working with all kinds of coax under a lot of extreme
conditions, and the lessons learned from them.
As far as the props, If you had designed a prop that gave performance
so far beyond the others available and this performance was
demonstrated in the best way, wouldn't you want to share that with
others? I don't sell cables or props or ignitions; I leave that to
others. I guess there are some of you who don't care that there is a
revolution in prop design that can give you markedly better
performance. Or coax that will up your radio's performance. Perhaps you
don't also want me to share with you the research I and another have
done to keep your prop bolts tensioned regardless of temperature or
humidity. When all you do is put down others who want to share, you can
suppress that sharing!
Old January 11th 05, 05:41 PM
RST Engineering
I have rarely read such unmitigated horsepuckey in my engineering career.
"ELIPPSE" wrote in message
If you would like to have the finest low-loss, light-weight coax cable
for your aircraft radio installations
Old January 11th 05, 08:55 PM
ELIPPSE wrote:
: DME and the transponder are in the 960MHz to 1215MHz range. At 1GHz,
: RG58 has 17.5dB/100ft., RG142 has 13.0dB/100ft., and FSJ1-50A has
: 6.0dB/100ft. If I was operating under extreme conditions, I would want
: the best performing equipment available to me. Sometimes 1dB can make
: the difference between getting a signal or not! Ask the guys talking to
: the spacecraft out among the planets.
That's a completely different problem than aircraft communication. Most of it
is ancient tech with fairly wide SNR margins, and your 4.5db/100' shinks to only
0.45db for a normal run of 10' in a GA aircraft. That's down in the noise (pun
intended) for signal degredation and about the same loss as putting a connector on the
end. IIRC the main reasons for RG142 are ruggedness (read: bitch to work with),
longevity (won't rot out in 40 years), and materials (RG142 on fire is supposed to be
at least slightly less hazardous than RG58 on fire).
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old January 11th 05, 09:20 PM
Peter Dohm
I really like RG142 as well, especially the low loss and low leakage
in a fairly small and light cable. But for short runs, it is still overkill
for much of anything besides a radio altimeter.
Peter
Andrew Heliax is fine cable - just what you need to run
up a tower (it comes in many sizes). But in an airplane?
Like the man said - it's overkill. I'd recommend RG142.
As for the isolation - engineers have an inside joke that
goes something like this:
Oh say can you see.....
Three Hundred Dee Bee....
This is a range greater than that between the smallest
detectable signal to an unimaginable amount of power.
In other words, it doesn't exist in the natural world.
AFAIK, nobody makes anything with "300 dB of isolation".
Any engineers out there who would care to comment?
David Johnson
Old January 11th 05, 10:02 PM
ELIPPSE
Horsepuckey, unmitigated or otherwise, does not constitute a cogent
review of the technical information presented. It would be much more
enlightening to all if the respondent had replied with a discussion of
the technical merits as he sees them from his own perspective of
theoretical and practical experience, rather than to launch into the
vitriol of an ad hominem attack. This type of attack is often a shield
for the attacker's own ignorance or incompetence! I presented the
specs; he, for his part, should show how and in what way they are not
applicable, along with his own recommendations, especially with
practical examples of received and transmitted power levels and cable
lengths. It would also be interesting to see, from his vantage point,
what testing he has done on the effect of signal leakage in coax on the
their concomitant creation of sidelobes resulting in attenna pattern
distortion and signal dropout. Only in this way may all who are
interested in the proper selection of cabling for their aircraft be
able to intelligently make, what is for them, the proper choice of
cable and connector type based on performance and economics. We report,
they decide!
Old January 11th 05, 11:21 PM
RST Engineering
Double horsepuckey, and I don't appreciate your snide side emails. If you
have something to say to me, have the intestinal fortitude to post it in the
newsgroup.
What you recommended was a howitzer to kill an ant. Showing how and why 300
dB is a meaningless number is meaningless to somebody who doesn't have a
concept of how impossible that is to measure.
Signal leakage distortion of the antenna pattern is possible to measure on
the pattern range. With the coax inside of a metal structure the concept is
meaningless, as is it meaningless when the coax is bundled with other
wires...a 99+% probability.
Plonk.
they decide!
Old January 11th 05, 11:43 PM
Dude
His attack was not ad hominem. I may not be an engineer, but I did take
Latin.
In fact, by usenet standards I would judge his comments as only border line
rude. He likely felt free to snipe because your reputation here is already
poor due to several missteps in ettiquette.
I also took Psych, Communications, and Logic. You made an obvious
statement and that may or may not apply, and then qualified it with "often"
so that you really didn't say anything. Which is good, because as I said
before, I took Latin, and this IS an ad hominem attack.
I presented the
lengths.
Maybe he should, or maybe he doesn't need to. Remember, "they decide".
Interesting to whom? If you don't respect his opinion, why do you care about
his perspective?
they decide!
Actually, I, like many aviators, tend to go with what is tried and true
until I see a desirable benefit that would result from a change. While a
seriously detailed investigation and discussion may bring about new
knowledge, its not like our we are all failing as it is.
You are obviously a bright guy, but there are lots of those folks already
here. Perhaps you should try to avoid any heavy arguments for a bit.
Old January 12th 05, 02:44 AM
UltraJohn
ELIPPSE wrote:
I worked with an X-band extreme-accuracy Atlas guidance radar at
Vandenberg AFB. It was necessaspecializedt least 150dB isolation to
prevent interference in our test simulator. Solid jacket cable was the
only thing that would allow this kind of performance. The Andrew cable
was also the only kind that did not generate noise when flexed or
vibrated, which was very important in our test operations. Remember
that the transponder puts out 100W-400W peak. Leaking cables in close
proximity can cross couple. Cable leakage also effects the apparent
radiation pattern of antennas, generating undesired sidelobes and
cancellations. Consider the 20' long com run from the instrument panel
to the antenna buried in the tip sail of the VariEZ or LongEZ that
passes near the extreme RFI generated by the engine's ignition. Has
anyone ever had spark noise in their com radio?
Your x-band does not compare with homebuilt even when talking about
transponders and dme. Even 20 foot run for a com radio doesn't require that
high a caliber cable. You will probably find that most of the noise from
ignition isn't from the center conductor but from the shield and also then
antenna itself. Most people do not run there coax next to their ignition
wires anyway! Use a little common sense, it's a heck of a lot cheaper!
John
PS my background is in microwave measurements etc that doesn't mean I need
to engineer my homebuilt around top end specialized cable.
Old January 12th 05, 03:06 AM
GeorgeB
On Tue, 11 Jan 2005 15:21:38 -0800, "RST Engineering"
Aw Jim, 0.1 microvolt to 1 Megavolt is "only" 260 dB ... g ...
assuming 50 ohms, that is good receiver sensitivity vs 20 Gigawatt ...
we have Gigahertz, why not Gigawatt ... OH, you mean that a large
power plant turbine-generator is on the order of a Gigawatt ... OH ...
Methinks he doesn't understand large (and small) numbers ...
Old January 12th 05, 11:55 AM
Scott
Quite true, but I'm a low and slow guy. I nver fly THAT high up For
us terrestrial types, I still don't think a dB or two is going to make a
ton of difference. I routinely talk 75 miles from 2000 feet with my
handheld at 1 Watt, through about 15 feet of RG-58 driving one of those
flexible ELT whip antennas.
Scott
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
Switching radios on 1 antenna Nicholas J. Hirsch Home Built 16 June 14th 04 01:49 PM
Tefzel Wire, RG400 Coax, Crimpers, Terminals, etc.. Stein Bruch Home Built 0 September 20th 03 04:35 AM
Military helmet, civilian radios - my solution Dave Hyde Home Built 7 September 16th 03 01:20 AM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
