#11
sounds to me like the person using the handheld radio is not close enough to
the microphone.......if you're getting the transmission then the radio is reaching your receiver tim wrote in message oups.com... Tim, it's neither. When someone uses the handheld on the ground when I'm flying in my glider, the transmission is very weak. So much so that I have to close all the vents and turn up the volume considerably to hear what they are saying. The radio operates just fine; it's just that it doesn't seem to transmit well. I'm only guessing, but I'd put my money on the antenna as the problem. |
just checking
JRC has a pretty good track record, but one or two bad experiences can be disappointing. YMMV, Frank "BTIZ" wrote in message news:h3O1e.565$ZV5.57@fed1read05... ok... I think we all knew that... but from what I read... ICOM is not JRC... just cause ICOM is "made in Japan".. that does not make it JRC... I did not see any affiliation to JRC in the article... so.. whats your point? BT "F.L. Whiteley" wrote in message ... please read the following http://www.icomamerica.com/downloads/cq-interview.pdf "BTIZ" wrote in message news:ViL1e.543$ZV5.432@fed1read05... Hint,... it's not the antenna... it's the radio... JRC = Japan Radio Corp... Get an ICOM BT wrote in message ups.com... All, I have been using a JRC JHP-500 handheld radio for field communications and have been a bit disappointed with it's performance. It has a standard 6" flex antenna. When I am in the air and someone tries to talk with me using the handheld, the transmission always sounds very weak, even if I am flying right over the top of them at the airport. For all I know, the radio is fine and the real culprit may simply be the antenna. Any suggestions? Any suggestions on other (stock) handheld transceivers that have worked well for others that won't break the bank? |
X-no-archive: yes
In article , Tim Mara writes sounds to me like the person using the handheld radio is not close enough to the microphone.......if you're getting the transmission then the radio is reaching your receiver tim wrote in message roups.com... Tim, it's neither. When someone uses the handheld on the ground when I'm flying in my glider, the transmission is very weak. So much so that I have to close all the vents and turn up the volume considerably to hear what they are saying. The radio operates just fine; it's just that it doesn't seem to transmit well. I'm only guessing, but I'd put my money on the antenna as the problem. The next logical step would seem to be: Attach a RF Power Meter to the radio (using a Dummy Load) and confirm that the RF Power is as per specification. If this is OK: Attach an AM (Not FM) Modulation Meter in place of the Power Meter and confirm that the depth of Modulation is to specification. If these test return OK results then it is probably a User Problem. Tim Newport-Peace "May you be cursed with a chronic anxiety about the weather." John Burroughs (1837-1921). |
JVC= Japan Victor Company, an old subsidiary of RCA - RCA-Victor
Even if you by an American radio it's probably A. Made in Japan or B. Manufactured with Japanese components. But Icon is a good low to mid end radio, but if you're talking about a back-up radio that could be the difference of survival or not a couple dollars in your pocket sure won't do you any good when you're 8-10ft ASL on a some mountaintop! |
All handholds suffer from some Faraday effect when transmitting from inside a vehicle be it a plane a car or whatever. Your best bet is splicing into your external antenna.
Another good idea is to looking into how and why different antennas are made and take a crack at it. If you're lucky enough to survive an aerial catastrophe and all you have is your back-up handheld you can greatly increase the TX distance of your handheld just by using parts of your craft to "MacGyver" a possibly lifesaving antenna. |
Two of us at our club have the Vertex VXA-220, and no problems so far.
https://www.youtube.com/watch?v=PUqve7OchwQ |
On 3/15/2016 7:03 AM, Casey wrote:
Two of us at our club have the Vertex VXA-220, and no problems so far. https://www.youtube.com/watch?v=PUqve7OchwQ Which reminds me. I have a Vertex VXA-150 that has become surplus to my requirements. In very good condition! This one hasn't seen lots of use, but it's light enough that I used to fly with it hanging from my neck on a breakaway lanyard. It was always handy and never adrift or (worse) behind a rudder pedal! http://www.acespilotshop.com/pilot-s...-150-pro-v.htm vaughnsimon at gmail dot com Vaughn |
| Thread Tools | |
| Display Modes | |
| Boosting ICOM IC-A23 Handheld Aviation Radio | CHANGE USERNAME TO westes | Instrument Flight Rules | 23 | June 9th 04 01:41 PM |
| STS Handheld Radio Repair - USA | Ray Lovinggood | Soaring | 3 | April 25th 04 02:33 PM |
| Vertex VXA-150 Pro V handheld radio question | Alan Meyer | Soaring | 2 | April 24th 04 02:42 PM |
| Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 02:10 PM |
| Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 04:30 AM |
