#21
![]() "stol" wrote in message oups.com... Lean mixture makes the exhaust hotter, not a rich mixture. Up to a point, then it gets cooler... |
![]() stol wrote: My Zenith 801 is running a 347 cu in all aluminum Ford V-8. I detuned it to about 310 hp to keep the plane from breaking in half and on take off I am burning 11.8-12.3 an hour. Ben, This equates to a BSFC of about 0.22 , essentially "impossible". Remember, on aircooled motors they use 30-40 % of the fuel just to cool the heads/cylinders. Please explain the reasoning behind this (IMHO bizarre ) statement. Sid Knox Oklahoma Velocity N199RS Starduster N666SK KR2 N24TC W7QJQ |
On 20 Jan 2005 21:57:24 -0800, wrote:
stol wrote: My Zenith 801 is running a 347 cu in all aluminum Ford V-8. I detuned it to about 310 hp to keep the plane from breaking in half and on take off I am burning 11.8-12.3 an hour. Ben, This equates to a BSFC of about 0.22 , essentially "impossible". Sid, you must have missed the following, it explains a lot: "Let me clear up some things. My plane is tied down in its hangar at almost 7000 feet msl. So the 310 hp is down 22% right off the bat, now it's at 240 or so. The fuel flow for that HP range is damn close. I agree that any motor running below .38-.40 is pushing the limit on thermal dynamics of current technology. I admit that there is some cutting edge stuff in my motor that helps squeeze out more hp per pound of fuel. Ben Haas N801BH Jackson Hole Wyoming" Ben wrote: Remember, on aircooled motors they use 30-40 % of the fuel just to cool the heads/cylinders. Sid asks: Please explain the reasoning behind this (IMHO bizarre ) statement. When properly set up aircooled engines with fixed timing (which describes all of them except for those equipped with electronic aftermarket timing or FADEC) are advanced to full power, the fuel system is designed to produce a strongly overrich mixture in order to prevent detonation and overheating. There may be some confusion as to how an overrich mixture actually achieves this. The answer in depth may be found at: http://www.avweb.com/news/columns/182084-1.html REALLY simplifying the explanation, since the timing is fixed, the only way to vary the timing is by varying the mixture. The speed of combustion within the combustion chamber will vary from very lean to ideal to very rich: going from slow (relatively speaking) to fast and back to slow again respectively. Engineers preset the point of ignition in order for the peak pressure point to occur at 16 degrees after top dead center while at full power and full rich mixture. This is the point where the combustion reached it's maximum pressure during the combustion process. Engineers have long known that the PPP should occur at 16 degrees ATDC for maximum power and cooling. If the mixture is leaned while under full power the combustion will speed up. If the combustion speeds up, the PPP may begin to occur at close to TDC. If the PPP is occurring at TDC, all that pressure has no where to go and pressure and temperatures skyrocket. This is why you do NOT lean the mixture while the at full power and taking off, unless you are at a high altitude airport, which is another story. It's also why you should NOT pull back the throttle in an effort to "save" the engine. Pulling back the throttle slows the engine (fixed prop), which brings the PPP close to TDC (bad). Anyway, the rich mixture for takeoff allows the engine to achieve it's best PPP location at 16 degrees ATDC which allows the engine to produce maximum power and not overheat. It does not cool the engine by hosing down the combustion chamber with excess fuel. Corky Scott |
#24
Please read the followup post I did for an explaination. You seem to
have pasted the SEA level output I quoted, not the real enviorment it is flying . I am SURE the fuel consumption will be a lot higher DOWN there.So Lets see, 12.6 X X 6 is 73 pounds per hour divided by 240 hp gaves a number in the low three range. The main reason I am seeing 12.2 or so GPM is because I don't use FULL power. The whole idea is to have plenty of EXTRA HP and use just what one needs for the task at hand. Maybe one day when I get real crazy I will throttle it up some more, if the plane don't break in half.. After all I only have two feet to push on the right rudder. After 60+ hours on this package it has demonstrated everything I was expecting and more. The motor is WAY smoother then a Lyc or Cont, starts on the first couple of turns everytime and can burn either 100LL or car gas. I do commend you on taking the WRONG numbers to make your calcs with. IMHO you are bizarre in your approach. But what the hell, this is a free country, better yet. Come on out and strap yourself in and see for yourself, is ya promise not to throw up in my plane.. Bring Barnyard Blob anong too..I am betting all three of the planes you list below your name has a aircooled engine in them, Ben Haas |
#25
stol wrote...
After 60+ hours on this package it has demonstrated everything I was expecting and more. I don't doubt that someday someone will build a successful auto conversion. Maybe someone already has. Maybe it's you. But you sure as snot don't know for sure after only "60+ hours" unless that plus adds a zero or two to that 60. Dave 'accelerated service test' Hyde |
#26
On Fri, 21 Jan 2005 15:21:19 GMT, "Dave Hyde" wrote:
I don't doubt that someday someone will build a successful auto conversion. Maybe someone already has. Maybe it's you. But you sure as snot don't know for sure after only "60+ hours" unless that plus adds a zero or two to that 60. Does 2,000+ hours count? There is a Ford V6 STOL that achieved that mark several years ago. The owner/builder reached that time and tore the engine and PSRU down for inspection. He found no discernable wear in the cylinders and the belt appeared still viable. My understanding is that he installed new bearings and replaced the psru's cog belt anyway. Bruce can likely give more detailed information. Bruce can also give numbers on how many of the Ford conversions are over 1,000 hours. Corky Scott PS, I did not see where Ben claimed anything other than that he built the conversion and it is working fine so far. |
#27
Years ago when I lived in PA I watched as a FWF 0-320 was pulled off a
plane at the FBO (can't remember what plane). Just for the information the mechanic weighed the package, wet without the metal prop. The weight came to 420 lbs which was only 20 pounds less than the FWF Ford V-6 installed in the mechanics plane. stol wrote: Morgans wrote: "Blueskies" wrote That is an in-flight adjustable prop, not constant speed but still adjustable. I think the writer is saying the weight compares favorably with a IO-360 with all accessories and a constant speed prop. The only real operational issue is the requirement to watch the prop pitch control vs. manifold pressure and twiddle as necessary to set the power; not quite as easy as a constant speed but configurable never-the-less... Right. I think other people's hesitations about the poster saying the V-8 is lighter, is possibly justified. Nevertheless, the possible heavier weight should be more than offset by the higher HP, and I commend someone giving alternate power a real, (from how it appears) well thought out application, a chance to work. As far as claims of fantastic economy goes, I think that anyone claiming to be getting *substantially* better than .38 lbs/hp/hr, even with a modern liquid cooled engine, are suspect. Good luck to the OP. I wish I were involved in the project. Test test test, before flying! -- Jim in NC Let me clear up some things. My plane is tied down in its hangar at almost 7000 feet msl. So the 310 hp is down 22% right off the bat, now it's at 240 or so. The fuel flow for that HP range is damn close. I agree that any motor running below .38-.40 is pushing the limit on thermal dynamics of current technology. I admit that there is some cutting edge stuff in my motor that helps squeeze out more hp per pound of fuel. For instance my egt is running 1600 + on takeoff but this also has an explanation. my probe is in the collector, not the head pipe so the the egt number looks high for sure. Took me a while to find some trick collector gaskets that can stand that kind of temp. An aircooled motor in the low .40 range is kinda hard to believe. Now if they add some ceramic goodies to their product they might get close. Lyc and Cont are realizing they are so far behind the tech curve that stating the FADEC is the future of their aircooled powerplants is like buying a bridge somewhere. Truth is Horsepower=Heat. The better one converts that to motion is ahead of the pack. I believe Dave Hyde asked the question ,How did a 0-360 gain so much weight.Well, lets add things up. 0-360 "Bare" and dry is 293,, Maybe,, add starter,Flywheel, ringgear, alt, fuel system and pump, fuel lines, shrouds, mags, wiring harness, brackets, exhaust system, mufflers, heat muffs, Scat tubes, clamps, oil filter, oil, oil cooler,oil lines,engine mount, cowling, prop, governor, bolts, nuts, Etc !!!!! I have weighed a Lyc all dressed out and it is alot heavier then most people think. Only in America can one create a better flying mouse trap....God Bless the USA !!!!!!! Ben Haas N801BH Jackson Hole Wyoming -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
#28
Geez. Once again I screwed up and posted my results from my auto
conversion on the wrong web group. You see I was trying to inform all the EXPERIMENTAL people that are " dreaming, thinking about, building or just curious about homebuilt aircraft and dumb me I posted it on the CERTIFIED plane group instead I put it here......... Wait !!!!! late breaking news !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! This is the rec.aviation. HOMEBUILT. newsgroup. Please Dave Hyde find something wrong with this ... Ben' thank god I don't have a certfied Lycoming crank that will break in my plane' Haas. |
#29
Very well explained Corky !!!!!!!!!!!!
#30
Blueskies
Are you saying that if you lean the mixture until engine quits, then the EGT goes down? I'm still alive but lurking ![]() Big John ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~```` On Wed, 19 Jan 2005 23:09:06 GMT, "Blueskies" wrote: "stol" wrote in message oups.com... Lean mixture makes the exhaust hotter, not a rich mixture. Up to a point, then it gets cooler... |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
advanced fuel flow mesurement system using microcontroller | khanindra jyoti deka | Home Built | 4 | January 4th 05 01:18 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
