Interesting thread in Rec.av.homebuilt about using plywood to formglider
Old April 11th 05, 01:36 PM
nafod40
Default Interesting thread in Rec.av.homebuilt about using plywood to formglider
Might be worth a gander, to see what they're saying.
Old April 11th 05, 05:39 PM
Bob Kuykendall
Here's a link to it on Google:
http://groups-beta.google.com/group/...3509d2feb44754
Old April 11th 05, 07:08 PM
Shawn
Didn't JJ have a write-up in Soaring recently about his Baby Bowlus
project? Didn't notice any reference in the thread.
Shawn
Old April 11th 05, 08:16 PM
Bob Kuykendall
about his Baby Bowlus project? Didn't notice
The way JJ made the pod for his Super Albatross is very different from
the method employed in the production Baby pods. The production pods
were molded plywood veneer made in a mold, while what JJ did was to
skin a series of bulkheads using handcut planks like barrel staves.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old April 11th 05, 10:01 PM
Bob Kuykendall
Longitudanally?
Yes, longitudinal planks.
Not like the prototypes, then, which
were scarfed rings, then?
I don't know about that. The production Baby pods I've seen seemed to
be made of fairly large pieces. I know the right and left halves are
scarfed together, but I don't recall how many longitudinal sections
there were. I think it might have been one big piece except for the
aluminum nose bowl and the little stinger below the boom. I do know
from photos that the pylon connecting the pod to the wing and boom was
left to be skinned by the kit builder.
Again, your best bet for the real deal is Jeff Byard. He has photos of
the Baby gliders under production; it should be pretty easy to figure
out specific construction details from the photos.
Oh - and if you're serious, I have aluminum booms from RS-15 kit
production that might do for you. They're 6" dia, which is larger tha
the Bowlus booms I've seen, but probably reasonable for that
application.
Thanks again, Bob K.
Old April 12th 05, 02:31 AM
As I understand it, Bowlus made the first Baby Albatross with scarfed
skins (12" rings), he then carved a wood plug and made left and right
concrete female molds, followed by 2 concrete male plugs. The veneer
sections would then be fitted and placed in the mold (3 ply), don't
know if heat was applied, but everything was glued up and then the
concrete plug was lowered into the female form. After curing the two
halves were joined. Howley Bowlus was doing with wood, what we would
all see 25 years later in our fiberglass sailplanes.
JJ
Bob Kuykendall wrote:
Longitudanally?
Old April 12th 05, 01:36 PM
JJ
Longitudanally?
To do one glider , it would make the most sense to do as was done on
serial #1-3 which is to use scarfed segments. Those were as pretty as
the later ones and would not require any special tooling.
The molded pods used 2 plys of poplar with external ply of mohogany. To
do this requires not only the mold, but a whole series of patterns for
the laminations so they fit properly together.
I have one of the "California" Babys that had the pod replaced by a
steel tube inner frame with fiberglass shell which appears to have been
pulled from an original pod. Not sure whether I'll restore that way or
do original inner structure and use shell with veneered exterior. Will
have to wait till I have more time to devote to it.
Nice to see that someone is seriously interested in thi wonderful old
glider.
UH
Old June 21st 05, 01:24 AM
10kDA 10kDA is offline
Junior Member
First recorded activity by AviationBanter: Jun 2005
The way Lockheed did it with the plywood shells of the Vega, Sirius, Altair etc. was to break down the parabolic shape to a series of 2-dimensional segments, long and narrow for one longitudinal ply, then short (longitudinally) and comparatively wide segments for the 90 degree ply, another long & narrow group, etc. These cut segments of plywood were taped edge to edge at their widest points and folded together for storage until needed in the mold. Air pressure was applied to a shaped rubber diaphragm which expanded to form the male form of the mold. The pressure during cure forced the plywood or veneer into a compound curve. I tend to believe Bowlus broke down the teardrop shape into similar plywood segments to create the molded BA shells. I understand Bowlus was able to reduce the number of laminated framing rings in the BA pod when he went to the molded skin. Creating these 2D skin shapes would be fairly easy to do using a CAD program which would most likely be able to represent a curved parabolic surface as a series of equal "facets" with single curvature, joined edge to edge like a molded canoe. Yes, I'm working on it - My project will be a scaled down Loughead S-1 biplane, a Jack Northrop design. If it works out I'll try a Bowlus BA shell. As far as scarfed rings, been there, done that, it works out very nicely too.
10kDA
JJ
Longitudanally?
glider.
UH
Old June 21st 05, 09:41 PM
Robin Birch
This is very similar to how the inner skins of the De-Haviland Mosquito
and I guess the Hornet were built with ply formed over a male plug.
Reading my copy of ANC-19 it describes how plywood can be moulded to
compound shapes by bag moulding or laying up veneer strips so I guess
the method is as old as the use of ply in aircraft.
Robin
In message , 10kDA
writes
10kDA
Wrote:
wrote:-
JJ
Bob Kuykendall wrote:--
Longitudanally?-
Yes, longitudinal planks.--
To
been
glider.
UH--
10kDA
Robin Birch
A new direction for an old thread: Crosswind landings [email protected] Soaring 96 March 4th 05 01:22 AM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Kerry -- WAY WAY OFF THREAD BUT INTERESTING. Big John Piloting 38 February 18th 04 01:57 PM
interesting thread today on rec.aviation.military Chris Spierings Military Aviation 0 November 12th 03 05:17 PM
Sad But Interesting Historic Photos Wayne Sagar Restoration 0 August 5th 03 12:25 AM
