Okay, here is my aircraft.  Now, does anybody have a 0% APR loan with
	120 mos differed payments? MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced performance of a constant speed propeller. $136,230.00 Base Price w/ standard equipment $800 Paint Option: Gull Gray Base 2015, Midnight Blue Primary Stripe 2013, Dark Charcoal Velour 3703-44 $2125.00 Complete Berkshire Elephant leather seat and side panel centers and door pockets., including the sides, back and pockets on pilot and copilot seats. Complete leather passenger seats. $300 Lowes Grey Instrument Panel $500 28 Volt System Upgrade for IFR Packages $10,233.00 S-Tec System 50 Autopilot $995 Bose Aviation Headset X (Triport Technology - ANR) $995 Bose Aviation Headset X (Triport Technology - ANR) $65 Bose Install Harness (each headset) $65 Bose Install Harness (each headset) $221 Tires and Tubes 8.50x6 - Tailwheel Models Only $200 Clear Windshield $686 Observation Doors $686 Observation Windows $2900 Super Sky Light w/ Cover $627 Swing-Out Window - Copilot $700 Auxiliary Fuel Tanks (85 gallons total) $390 Dynamic Balancing for Propeller $259 Grab Handles on Fuselage (L/R) $450 Ground Service Plug $210 Hour Meter $251 Landing Light - Right Wing $1834 Shoulder Harness Set (4 point) (Pilot and Copilot) --------------- $161,722.00 Sub Total $12,533.4550 Tax =============== $174,255.4550 GRAND TOTAL Sorry just having fun. Carl  |
I'd like the same financing options for a new Maverick jet, though the cost
	is roughly 2 million :-) Max Cruise - 412 kts. Max Range - 1,508 nm. Ceiling - 31,000 ft. Rate of Climb - 3,000 ft./min Rate of Climb (Single Engine) - 1,300 ft./min. Take-off Distance (Std. Gross Wgt.) - 1,800 ft. Landing Distance (flaps) - 1,900 ft. Stall Speed (Gross Wgt.) - 78 kts. Stall Speed (Empty Wgt.) - 70 kts. Empty Weight - 2,900 lbs. Gross Weight - 5,800 lbs. Useful Load - 2,900 lbs. Length - 28.5 ft. Wingspan - 33.25 ft. Height - 9 ft. Wing Area - 144.6 sq. ft. Wing Loading - 36 lbs./sq.ft. Fuel Capacity - 380 USG Engines ( Fanjets - 1,100 lbs. thrust each ) - (2) Williams International FJ33-4 Cabin Size - 52" wide, 43" high, 104" long Cabin Seating - 5 adults Baggage Area - 35 cubic ft. Air Frame - Pre-preg Carbon/Fiber/Nomex "Carl / KG6YKL" wrote in message news:3HG7e.46637$lz2.28467@fed1read07... Okay, here is my aircraft. Now, does anybody have a 0% APR loan with 120 mos differed payments? MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced performance of a constant speed propeller. $136,230.00 Base Price w/ standard equipment $800 Paint Option: Gull Gray Base 2015, Midnight Blue Primary Stripe 2013, Dark Charcoal Velour 3703-44 $2125.00 Complete Berkshire Elephant leather seat and side panel centers and door pockets., including the sides, back and pockets on pilot and copilot seats. Complete leather passenger seats. $300 Lowes Grey Instrument Panel $500 28 Volt System Upgrade for IFR Packages $10,233.00 S-Tec System 50 Autopilot $995 Bose Aviation Headset X (Triport Technology - ANR) $995 Bose Aviation Headset X (Triport Technology - ANR) $65 Bose Install Harness (each headset) $65 Bose Install Harness (each headset) $221 Tires and Tubes 8.50x6 - Tailwheel Models Only $200 Clear Windshield $686 Observation Doors $686 Observation Windows $2900 Super Sky Light w/ Cover $627 Swing-Out Window - Copilot $700 Auxiliary Fuel Tanks (85 gallons total) $390 Dynamic Balancing for Propeller $259 Grab Handles on Fuselage (L/R) $450 Ground Service Plug $210 Hour Meter $251 Landing Light - Right Wing $1834 Shoulder Harness Set (4 point) (Pilot and Copilot) --------------- $161,722.00 Sub Total $12,533.4550 Tax =============== $174,255.4550 GRAND TOTAL Sorry just having fun. Carl  |
Hmph!  If you GAVE me the Maverick, I still probably couldn't afford the
	fuel  .John E. Carty wrote: I'd like the same financing options for a new Maverick jet, though the cost is roughly 2 million :-) Max Cruise - 412 kts. Max Range - 1,508 nm. Ceiling - 31,000 ft. Rate of Climb - 3,000 ft./min Rate of Climb (Single Engine) - 1,300 ft./min. Take-off Distance (Std. Gross Wgt.) - 1,800 ft. Landing Distance (flaps) - 1,900 ft. Stall Speed (Gross Wgt.) - 78 kts. Stall Speed (Empty Wgt.) - 70 kts. Empty Weight - 2,900 lbs. Gross Weight - 5,800 lbs. Useful Load - 2,900 lbs. Length - 28.5 ft. Wingspan - 33.25 ft. Height - 9 ft. Wing Area - 144.6 sq. ft. Wing Loading - 36 lbs./sq.ft. Fuel Capacity - 380 USG Engines ( Fanjets - 1,100 lbs. thrust each ) - (2) Williams International FJ33-4 Cabin Size - 52" wide, 43" high, 104" long Cabin Seating - 5 adults Baggage Area - 35 cubic ft. Air Frame - Pre-preg Carbon/Fiber/Nomex "Carl / KG6YKL" wrote in message news:3HG7e.46637$lz2.28467@fed1read07... Okay, here is my aircraft. Now, does anybody have a 0% APR loan with 120 mos differed payments? MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced performance of a constant speed propeller. $136,230.00 Base Price w/ standard equipment $800 Paint Option: Gull Gray Base 2015, Midnight Blue Primary Stripe 2013, Dark Charcoal Velour 3703-44 $2125.00 Complete Berkshire Elephant leather seat and side panel centers and door pockets., including the sides, back and pockets on pilot and copilot seats. Complete leather passenger seats. $300 Lowes Grey Instrument Panel $500 28 Volt System Upgrade for IFR Packages $10,233.00 S-Tec System 50 Autopilot $995 Bose Aviation Headset X (Triport Technology - ANR) $995 Bose Aviation Headset X (Triport Technology - ANR) $65 Bose Install Harness (each headset) $65 Bose Install Harness (each headset) $221 Tires and Tubes 8.50x6 - Tailwheel Models Only $200 Clear Windshield $686 Observation Doors $686 Observation Windows $2900 Super Sky Light w/ Cover $627 Swing-Out Window - Copilot $700 Auxiliary Fuel Tanks (85 gallons total) $390 Dynamic Balancing for Propeller $259 Grab Handles on Fuselage (L/R) $450 Ground Service Plug $210 Hour Meter $251 Landing Light - Right Wing $1834 Shoulder Harness Set (4 point) (Pilot and Copilot) --------------- $161,722.00 Sub Total $12,533.4550 Tax =============== $174,255.4550 GRAND TOTAL Sorry just having fun. Carl  |
heck... if you want to have fun... you don't need a $10K autopilot.. unless
	you are planning on single pilot IFR... while your at it... I'll take the Maule 260HP Orion, conventional gear of course.. and don't forget the glider tow hook BT "Carl / KG6YKL" wrote in message news:3HG7e.46637$lz2.28467@fed1read07... Okay, here is my aircraft. Now, does anybody have a 0% APR loan with 120 mos differed payments? MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced performance of a constant speed propeller. $136,230.00 Base Price w/ standard equipment $800 Paint Option: Gull Gray Base 2015, Midnight Blue Primary Stripe 2013, Dark Charcoal Velour 3703-44 $2125.00 Complete Berkshire Elephant leather seat and side panel centers and door pockets., including the sides, back and pockets on pilot and copilot seats. Complete leather passenger seats. $300 Lowes Grey Instrument Panel $500 28 Volt System Upgrade for IFR Packages $10,233.00 S-Tec System 50 Autopilot $995 Bose Aviation Headset X (Triport Technology - ANR) $995 Bose Aviation Headset X (Triport Technology - ANR) $65 Bose Install Harness (each headset) $65 Bose Install Harness (each headset) $221 Tires and Tubes 8.50x6 - Tailwheel Models Only $200 Clear Windshield $686 Observation Doors $686 Observation Windows $2900 Super Sky Light w/ Cover $627 Swing-Out Window - Copilot $700 Auxiliary Fuel Tanks (85 gallons total) $390 Dynamic Balancing for Propeller $259 Grab Handles on Fuselage (L/R) $450 Ground Service Plug $210 Hour Meter $251 Landing Light - Right Wing $1834 Shoulder Harness Set (4 point) (Pilot and Copilot) --------------- $161,722.00 Sub Total $12,533.4550 Tax =============== $174,255.4550 GRAND TOTAL Sorry just having fun. Carl  |
Made my day....
	7 years ago I picked up a MX7-180a with 35 hours: fixed pitch prop old style gear no frills, just the basics pair of DCs thrown in .....for about 1/3rd the price - $59k Added $12k of electronics and stuff for some real IFR capability ....and then hand flew 1000hours worth of slow speed, easy, low maintenance travel in my paint chipped little baby. Sweet Two questions pop into mind - How much faster does the constant speed 180 go than the fixed pitch? I get 114 knots at 2500rpms at 4,000' Is the book price that my local tax authority quotes ($82k) real? Carl / KG6YKL wrote: Okay, here is my aircraft. Now, does anybody have a 0% APR loan with 120 mos differed payments? MX-7-180C Star Rocket - Taildragger with 76” Hartzell Constant Speed Prop and Spring Aluminum Gear. Lycoming 0-360 180 hp engine with the enhanced performance of a constant speed propeller. $136,230.00 Base Price w/ standard equipment $800 Paint Option: Gull Gray Base 2015, Midnight Blue Primary Stripe 2013, Dark Charcoal Velour 3703-44 $2125.00 Complete Berkshire Elephant leather seat and side panel centers and door pockets., including the sides, back and pockets on pilot and copilot seats. Complete leather passenger seats. $300 Lowes Grey Instrument Panel $500 28 Volt System Upgrade for IFR Packages $10,233.00 S-Tec System 50 Autopilot $995 Bose Aviation Headset X (Triport Technology - ANR) $995 Bose Aviation Headset X (Triport Technology - ANR) $65 Bose Install Harness (each headset) $65 Bose Install Harness (each headset) $221 Tires and Tubes 8.50x6 - Tailwheel Models Only $200 Clear Windshield $686 Observation Doors $686 Observation Windows $2900 Super Sky Light w/ Cover $627 Swing-Out Window - Copilot $700 Auxiliary Fuel Tanks (85 gallons total) $390 Dynamic Balancing for Propeller $259 Grab Handles on Fuselage (L/R) $450 Ground Service Plug $210 Hour Meter $251 Landing Light - Right Wing $1834 Shoulder Harness Set (4 point) (Pilot and Copilot) --------------- $161,722.00 Sub Total $12,533.4550 Tax =============== $174,255.4550 GRAND TOTAL Sorry just having fun. Carl  |
On 2005-04-15, BTIZ  wrote:
	heck... if you want to have fun... you don't need a $10K autopilot.. unless you are planning on single pilot IFR... Hell, it's less than the tax. And I can assure you my S-Tec 50 flies better than my 1040! -- Ben Jackson http://www.ben.com/  |
			 Hell, it's less than the tax. And I can assure you my S-Tec 50 flies better than my 1040! I'll agree to that.. !!! BT  |
			 "BTIZ" wrote in message news:OZH7e.11073$%c1.6646@fed1read05... and don't forget the glider tow hook Yep, that was the first thing I noticed that was missing. Vaughn  |
Vaughn wrote:
	"BTIZ" wrote in message news:OZH7e.11073$%c1.6646@fed1read05... and don't forget the glider tow hook Yep, that was the first thing I noticed that was missing. Although soaring is great, I'm not stopping my fun to tow planes into the air! I'll leave that to the Pawnees of the world. Carl  |
			 "Carl / KG6YKL" wrote in message news:Yxe8e.54971$lz2.45773@fed1read07... Vaughn wrote: "BTIZ" wrote in message news:OZH7e.11073$%c1.6646@fed1read05... and don't forget the glider tow hook Yep, that was the first thing I noticed that was missing. Although soaring is great, I'm not stopping my fun to tow planes into the air! I'll leave that to the Pawnees of the world. Yes, but you could put the thing to work making its own payments. I have spent many hours contemplating the tail feathers of a Maule from 200 feet back. In general, I would much prefer to be following a Pawnee, but they tend to be single-purpose machines. Vaughn  |
| Thread Tools | |
| Display Modes | |
| I need some advice on buying my own plane BEFORE training... | Anthony L | Piloting | 6 | April 23rd 04 12:13 AM |
| Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 01:06 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 08:27 AM |
