Tost's cable handling notes prohibet the use of a swivel between the cable
	and winch parachute They say it destroys the multistrand cable.- Swivel is only to be used for towing out. THis is counter intuitive - can anyone offer an explanation why this is so? Thanks John Spargo  |
			 "John Sp" wrote in message ... Tost's cable handling notes prohibet the use of a swivel between the cable and winch parachute They say it destroys the multistrand cable.- Swivel is only to be used for towing out. THis is counter intuitive - can anyone offer an explanation why this is so? Thanks John Spargo If you use a swivel the cable will untwist when under tension and then turn itself into a rats nest when the tension is removed. My club uses a swivel that doesn't work when under tension. I'm not sure it would twist during towing out either. As far as I can see the only purpose of the swivel is to prevent the cable twisting as the parachute spins on the way down after a launch. Stephen  |
	... Tost's cable handling notes prohibet the use of a swivel between the cable and winch parachute They say it destroys the multistrand cable.- Swivel is only to be used for towing out. THis is counter intuitive - can anyone offer an explanation why this is so? Thanks John Spargo It is normal to use a swivel that locks when launching to prevent the cable un-twisting whilst under load which would destroy its structure. However, it is desirable to then permit swivelling whilst the cable is retrieved after glider release to prevent the parachute from winding-up the cable. This is normally achieved by having the two sections of the swivel joined by a plain bolt without any form of bearing incorporated. The only use for a freely operating swivel is when retrieving the cable once or twice under a fairly light load when it has been newly fitted and prior to launching any gliders. It is considered by some that this helps to bed the strands in and reduce the springiness in a new cable making it less prone to cause loops at the winch in the event of a glider release under tension. Phil Jeffery  |
| Stuck cowl flap cable | Jim Burns | Owning | 7 | March 24th 05 03:07 PM |
| Winch Cable Splicing (w/o ferrules) | Gary Emerson | Soaring | 11 | April 5th 04 07:51 AM |
| best Winch cable? | yo | Soaring | 2 | April 2nd 04 04:47 PM |
| Winching - Cable danger. | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 9 | March 28th 04 12:51 AM |
| Winch cable | Bill Daniels | Soaring | 5 | August 25th 03 12:13 AM |
