Anywhere Map with XM weather
Old April 26th 05, 02:44 AM
Doodybutch
Default Anywhere Map with XM weather
I just ordered Anywhere Map with XM weather today using a wireless Compaq
4700 PDA. It sounds like the display and features are a lot better than the
Garmin 430/530 with XM weather, as far as the moving map, terrain avoidance,
and weather displays go, although it is not IFR approved and it has no COM
capability, of course. It is MUCH cheaper. I've been waiting for ground
based radar in the cockpit for 20 years.
I would like to hear comments from others who have tried this product. I
have only seen the Aviation Consumer review and the Anywhere Map web site.
DB
Old April 26th 05, 01:20 PM
Had one, didn't like it, sent it back. Display was slow, and the altitude
was reading 400ft below actual altitude. Could have been the PDA, but I
doubt it. I sent it back and bought a Garmin 296...Hope it works better for
you. Good luck.
"Doodybutch" wrote in message
the Garmin 430/530 with XM weather, as far as the moving map, terrain
avoidance, and weather displays go, although it is not IFR approved and it
has no COM capability, of course. It is MUCH cheaper. I've been waiting
for ground based radar in the cockpit for 20 years.
DB
Old April 26th 05, 02:06 PM
Jon A.
Was that some time ago? I've heard that they've improved the product
because too many people were complaining.
you. Good luck.
DB
Old April 26th 05, 02:26 PM
Stephen McNaught
A couple thoughts on using a PDA with aviation moving map software,
regardless of which software you use. A PDA is a computer, so all "issues"
associated with computers affect PDAs. Some are better than others, have
more memory, faster processors, better screens, bluetooth, wifi, etc...
Performance will be based on the machine selected. Secondly, the GPS is not
part of the software itself. The software takes the information from the GPS
receiver, and displays it in whatever format the software was written. Some
GPS receivers were not built with aviation in mind, and for various reasons,
the altitude reported by the receiver to the software can be off, and the
software won't know, regardless of which software you use.
I think a dedicated unit like the Garmin 296 is a great setup, if you are
just going to use it as a moving map GPS, and don't need the other functions
of a PDA. I use a PDA with a Garmin GPS 10 Bluetooth GPS receiver, and the
atltitude, is usually within 10 feet of my indicated atltude on the
altimeter. The GPS 10 does have a couple magnets in it though. So you have
to be aware where you place it. (The magnets are designed so you could
"stick" the receiver on the hood of your car, or roof, etc.. )
"Jon A." wrote in message
news
for
you. Good luck.
Compaq
it
I
site.
DB
Old April 26th 05, 04:02 PM
Dave Butler
snip
Some
snip
I can't let this go by without pointing out the biggest reasons for GPS altitude
to be perceived as inaccurate. These are all *systemic* reasons and have nothing
to do with the quality of the GPS receiver, or whether it was built with
aviation in mind.
- GPS position calculation in the vertical axis has less precision than in the
horizontal plane because of the geometry. A small error in measuring the time of
arrival of the GPS signal translates into a larger error in the vertical axis
than in the horizontal. Users' expectation that the altitude will be as precise
as the horizontal location is misplaced.
- GPS altitude is usually presented as the height above whatever ellipsoid that
the GPS uses as an earth model. This is not the same as the height above MSL. I
think the difference can be a few hundred feet.
Old April 26th 05, 04:11 PM
Nathan Young
snip
Some
snip
aviation in mind.
Additional data follows...
Many years ago, prior to WAAS, and prior to SA being turned off,
altitude would regularly be several hundred feet different than
indicated on the altimeter.
However, with SA shut off, and a WAAS enabled receiver, the accuracy
in the Z domain is much improved. As an empirical reference - I have
a Garmin 295, which has WAAS capability. The delta between indicated
altitude and GPS altitude is always less than 500 feet, and usually
is less than 100 feet.
Old April 26th 05, 04:26 PM
Ron Natalie
Paul kgyy wrote:
The weather display is more detailed than what you get on the GNS430 at
half the cost.
Has Garmin delivered the XM on the 430 yet? The ad on the back cover of
AOPAPilot that just arrived said soon. The MX20 has it.
Old April 26th 05, 04:40 PM
Matt Barrow
"Dave Butler" wrote in message
news:1114523965.843239@sj-nntpcache-5...
time of
axis
precise
Trivia (AIC): When a ship travels through the Panama Canal, it actually
gains/loses about 25 feet from entry to exit depending on the direction of
travel. Sea Level is not 100.0% level.
Old April 26th 05, 05:22 PM
Paul kgyy
I haven't actually seen GNS430 weather - just basing my statement on
available pixel count.
Old April 26th 05, 06:39 PM
Dan Luke
the altitude
Compared to what? Was that on the ground or in the air?
Dan
C-172RG at BFM
Garmin/AT no longer supporting WSI weather on MX20 moving map Peter R. Owning 10 April 19th 05 04:08 PM
making the transition from renter to owner part 2 (long) Journeyman Piloting 2 April 15th 04 11:19 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 01:07 AM
XMRadio Satellite Weather Has Arrived Richard Kaplan Owning 37 September 2nd 03 03:51 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 05:03 PM
