Checking the battery in a Cherokee
Old May 4th 05, 09:51 PM
Jay Honeck
The shop that does my annual repaints the battery box every annual.
I can think of no valid reason for this.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 4th 05, 09:52 PM
Jay Honeck
How often do you check the battery in your PA28?
At annual. (Or if the plane doesn't start -- which has never happened with
either of the Cherokees I've owned...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 5th 05, 12:47 AM
My shop usually does (maybe they occasionally skip a year). The
reason is that the non-sealed battery usually has seeped some acidic
residue somewhere in the box. That stuff needs to be brushed off
properly, which usually scratches the paint, which requires that the
box be painted afterwards, to protect it from any new seepage.
Old May 5th 05, 01:35 AM
nobody
Guess I'll add "Check battery condition" to the monthly checklist and
replace the battery box in August at annual.
Thanks for the comments everyone.
Eddie
N40008
Old May 5th 05, 12:38 PM
Jay Masino
Robert M. Gary wrote:
The shop that does my annual repaints the battery box every annual. I'm
not sure why, my battery has never leaks. Its either preventative or
just an extra annual tax.
The paint they use on battery boxes is "acid resistant". It helps prevent
battery acid from eating a hole in the bottom of your plane. I have a can
of that paint that I use each year. I wash the battery box with a mixture
of baking soda and water, dry it, and re-coat it with a thin coat of the
acid resistant paint. In addition, I use compressed air to blow out the
vents. Incidentally, your battery DOES leak, you just don't know it
(unless you have one of the newer design "sealed" batteries). The act of
charging causes it to off-gas a vapor of battery acid. That's why battery
boxes have vents.
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old May 5th 05, 12:39 PM
Jay Masino
Obviously, it's checked at annual time, but I'll often try and check it
at the mid-year point, too.
__!__
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
