All of this diesel engine talk has me wondering -- has anyone built an
RV-6A with a Thielert engine or something similar? Would the RV-6A be underpowered with the 120hp Centurion 1.7? Thanks, -Luke |
Luke Scharf wrote: All of this diesel engine talk has me wondering -- has anyone built an RV-6A with a Thielert engine or something similar? Would the RV-6A be underpowered with the 120hp Centurion 1.7? Thanks, -Luke probably NOT underpowered, because my understanding is that this engine is able to give equivalent thrust to a 180 hp gas engine. I am presuming the difference is in the torque generated. A jet-a Piston RV would be a wonderful accomplishment Dave |
Dave S wrote:
Luke Scharf wrote: All of this diesel engine talk has me wondering -- has anyone built an RV-6A with a Thielert engine or something similar? Would the RV-6A be underpowered with the 120hp Centurion 1.7? Thanks, -Luke probably NOT underpowered, because my understanding is that this engine is able to give equivalent thrust to a 180 hp gas engine. I am presuming the difference is in the torque generated. A jet-a Piston RV would be a wonderful accomplishment I did a little more reading, and the centurion-engines.com site says that they only approve of using the engine with a constant-speed prop. If I'm thinking correctly, you get a benefit out of the extra torque with a constant speed prop, because the prop can take a bigger bite of air. OTOH, with the fixed-pitch props that I'm used to, the RPM sets the amount of power (or is it thrust? I think it's power) that you get out of it -- end of story. Starting to make sense, I think. -Luke |
"Dave S" wrote in message .net... Luke Scharf wrote: All of this diesel engine talk has me wondering -- has anyone built an RV-6A with a Thielert engine or something similar? Would the RV-6A be underpowered with the 120hp Centurion 1.7? Thanks, -Luke probably NOT underpowered, because my understanding is that this engine is able to give equivalent thrust to a 180 hp gas engine. I am presuming the difference is in the torque generated. A jet-a Piston RV would be a wonderful accomplishment Dave I believe that they were planning to only offer the engine with an OEM agreement from the Kit manufacturer. I have not seen any announcements as to that changing, or them having a deal with Van's. I think Thomas Borchert, who posts on here a bit who may know more. The engine is heavier than the 0-360 and would need a special engine mount. The RV's are all light enough that it would be plenty of engine though. I have been thinking that an RV or a Lancair Legacy would be excellent with this engine. You would likely get less climb, but you could likely higher and much faster at altitude. It's not as simple as most aircraft engines though, so you would need some sort of course to do the maintenance. Your EAA buddies and fellow hangar rat's ain't seen one of these before. |
| Thread Tools | |
| Display Modes | |
| 2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 01:39 AM |
| 2-stroke diesel is the (near) future? | Max Kallio | Rotorcraft | 123 | July 18th 05 01:39 AM |
| Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 05:04 AM |
| Diesel Jodel information..........and .........diesel plane groups | Roland M | Owning | 1 | January 4th 04 05:04 AM |
| bulding a kitplane maybe Van's RV9A --- a good idea ????? | Flightdeck | Home Built | 10 | September 9th 03 08:20 PM |
