VG's on a 172
Old June 7th 05, 05:12 PM
Default VG's on a 172
Anyone have experience with installing VG's on a 172 (preferably an
"M")?
If you've done it or flown one with VG's, would you recommend it as a
positive enhancement?
Problems or concerns?
Thanks,
Don
Old June 10th 05, 03:26 PM
Paul kgyy
The situation isn't the same, but I just read an article in the ABS
magazine about a Baron with VGs that became virtually uncontrollable
when the door popped open.
I assume that the Cessna door location under the wing would not cause a
similar problem, but the point of the article is that VGs are not
tested in all flight conditions (maybe couldn't be).
Old June 15th 05, 05:12 AM
Chuck
On 10 Jun 2005 06:26:24 -0700, "Paul kgyy"
Door popped open?!?!?!?!
The one time I've taken off and forgotten to latch the top latch on my
Cherokee door -- we get it to latch. There was a hurricane coming in
the crack at the top of the door pressurizing the cabin and keeping
the door from closing all the way.
The guy in the right seat tried and tried to push it open to slam it
and latch it. But he couldn't push it open no matter what he tried.
I slowed to full-flap slow flight and with help from the guy in back,
he was able to get it open a couple inches and slam it.
With that in mind -- I have no idea how a Baron's door could "pop
open". It took two adult men to push the door open a few inches AND
only after I'd slowed to just above 50kt.
OK, for those wondering the rest of the story. We didn't get the door
latched at top. Someone later suggested I slip sideways to put
pressure on the door. But that didn't occur to us at the time. So,
we spent a nice 40 minute flight with a hellacious wind coming in the
top of the door. It was hitting me right in the head and my wife
behind me. Boy -- talk about some noise in the mics...
Chuck
PA28-180
Old June 15th 05, 10:19 PM
The same as in your Cherokee. It'll pop out a few inches into the
breeze. We had an accident many years back on a holiday weekend
(Memorial or Labor day). A gal in a Bo departed PHX and her door
popped open. She got so involved with trying to close it that she did
a short dive into someone's backyard barbeque. Gotta remember to fly
the plane!
I've closed the door in flight several times on my Cherokee 180. The
slip method works, but it shouldn't be necessary. After slowing the
plane to about 60 mph (flaps down), you slam the door to close the
bottom latch. Then, get a grip on the well around the top latch and
pull the top of the door inward. You should be able to pull it about
1/2", then latch the door. It's best to have your passenger do this as
it's difficult to fly the plane with no hands. One warning though,
make sure the passnger does not try to force the latch. Last time
this happened to me, the passenger didn't pull hard enough to engage
the latch, but he kept twisting the latch until it broke off in his
hand (but it did latch!). It cost me $100 bucks (with labor) to
replace the latch handle, plus I had to exit the plane through the
baggage door when we got to our destination. Quite embarassing if
anyone is watching :-)
Chuck
PA28-180
Old June 16th 05, 12:34 AM
Robert M. Gary
I usually leave the door open on the Cessna when we fly. I live near
Sacramento so it get pretty hot. Keeping the door open provides more
air. You can't do that on the Piper because the shape of the door pulls
it open in flight. The Cessna door tries to close itself, you have to
push on it to get your fresh air.
Old June 20th 05, 11:55 PM
I have to ask...
WHY would you want to put vortex generators on a C172?
We fly the C172 in the mountains of Colorado, yes, to Leadville at 9927 MSL,
and density altitude over 12,000 is not uncommon. We do short and
soft field operations.
I just don't see what vg(s) would do for fun, or to help you or the
airplane to fly! AND... have you also found out that adding vg(s)
LOWERS Va (yes, it does!!! Think about the definition of Va).
Why are you considering vg(s)... I don't even have them on my Cessna-206.
Yes, I fly Bonanzas and Barons and Maule(s) with vg(s)... and they
should have them!
"M")?
Thanks,
Don
Best regards,
Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jer'at'frii.com WEB
http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 228 Young Eagles!
Old June 22nd 05, 10:43 PM
Dale wrote:
I fly VG equipped 206s and there is no change in Va.
Oh, contraire!
Va is a mathematical number, based on Vs0... stall speed (Va = Vs0 *
1.9?). When flying at Va (or below), at max gross weight, the
aircraft WILL stall before it bends. When flying above Va, at max
gross weight, it is possible to bend an aircraft before it stalls.
So, with VG on the aircraft, Vs0 is reduced. Hence, Va is reduced.
Note: Va goes down as weight goes down. (See any POH, especially the
Cessna POHs).
If they are good for a Bonanza or Maule why wouldn't they be good for a
206 or 172?
Because Bonanza and (tricycle gear) Maule stall at too high an
airspeed to be use in the short/soft runway environment. VG moves Vs0
down sufficiently to give controlability at a lower airspeed. Hence
you can operate off shorter airstrips.
Note: the taildragger Maule is fine all by itself and does not need
VG.
A C206 and a C172 and a C182... and MANY others fly slowly enough
that they do not need VG to operate with full utility. Hence,
-- I -- am not willing to give up ANY Va speed for a slower Vs0.
Best regards,
CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/
