Leaning to Hotest Cylinder
Old July 10th 05, 05:27 PM
O. Sami Saydjari
Default Leaning to Hotest Cylinder
My understanding is that one should lean using the "hotest" cylinder as
the reference point for peak EGT. My question is on the interpretation
of "hotest." Does that mean the cylinder that reaches the hotest EGTs
or CHTs? On mine, they are inversely related (the hotest EGTs are on
the coldest CHT cylinders).
-Sami
N2057M, Piper Turbo Arrow III
Old July 10th 05, 06:42 PM
Robert M. Gary
The cylinder that reaches peak EGT first (not necessarily the highest
EGT temp). In other words, the EGT that starts to cool first as you are
leaning. If you have a good engine monitor, it will compute this for
you and flash the EGT on the monitor.
-Robert
Old July 11th 05, 10:13 AM
Thomas Borchert
O.,
Absolute temperatures are not important. The key issue is the first
cylinder to reach peak EGT. If the peak EGT for that cylinder happens to
be 200 F lower than the peak EGT of the next cylinder, that's not
important for the leaning process (although you might want to check the
engine baffling).
Thomas Borchert (EDDH)
Old July 12th 05, 09:39 AM
Thomas Borchert
Aaron,
Don't forget that O. is flying a turbo. While the absolute value of EGT isn't
terribly important, TIT is, and it's related to EGT (of course).
Missed that, thanks.
Old July 14th 05, 03:10 PM
CriticalMass
of "hotest."
As others have stated in other words, the proper procedure is not to
lean to the "hottest" cylinder, but to lean to the "leanest" cylinder.
IOW, look for the first one to peak, and lean to that one. The fact
that the leanest cylinder may not be the one with the highest EGT is not
a consideration for leaning.
Note also that the leanest cylinder will vary over time. It won't
always be the same cylinder on every flight.
Path of an airplane in a 1G roll Chris W Piloting 47 July 4th 05 11:53 PM
Path of an airplane in a 1G roll Chris W Aerobatics 20 June 29th 05 10:35 AM
Path of an airplane in a 1G roll Chris W Home Built 22 June 29th 05 10:35 AM
Dehydration [email protected] Soaring 23 March 30th 05 03:59 PM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 02:13 PM
