Last weekend I lost my spinner through my prop. I had removed it the previous weekend because the screw kept coming loose. I was going to leave it off until I found the right solution. An A&P where I keep my plane saw me messing with it, and came over to help. He went and grabbed a bolt and a difference nut plate, and put the spinner on. He didn't torque the bolt down as tight as I would have because he "didn't want to crush the nose of the spinner". I questioned him on it, asked if we should put lock-tite on it, and he said "naw, that ain't comin' off". Last time I take advice from him.
Two flight hours later the spinner went through the prop. Although the damage to the prop wasn't nearly as bad as I expected, I'm still wondering if my $1,300 prop is now a wall-piece. I've already contacted the manufacturer (Prince Aircraft) and I'm waiting on their response. Let me know what you think. I did fly ~2.5hrs after this occurred (after checking it out on the ground). Tell me what you think...repairable or not? Pictures: http://www.wotelectronics.com/prop/ |
Quote:
It's been my experience that if you ask a manufacturer, "Is this broken?", they'll see it as an opportunity to sell you another one. I don't know about airplane parts companies. Do most of them play straight with people? I guess I'm just overly suspicious. |
In article , Richard Riley says...
: :Tell me what you think...repairable or not? Absolutely repairable. I concur Chuck S |
Fisherman wrote: SteveR Wrote: Last weekend I lost my spinner through my prop. I had removed it the previous weekend because the screw kept coming loose. I was going to leave it off until I found the right solution. An A&P where I keep my plane saw me messing with it, and came over to help. He went and grabbed a bolt and a difference nut plate, and put the spinner on. He didn't torque the bolt down as tight as I would have because he "didn't want to crush the nose of the spinner". I questioned him on it, asked if we should put lock-tite on it, and he said "naw, that ain't comin' off". Last time I take advice from him. Two flight hours later the spinner went through the prop. Although the damage to the prop wasn't nearly as bad as I expected, I'm still wondering if my $1,300 prop is now a wall-piece. I've already contacted the manufacturer (Prince Aircraft) and I'm waiting on their response. Let me know what you think. I did fly ~2.5hrs after this occurred (after checking it out on the ground). Tell me what you think...repairable or not? Pictures: http://www.wotelectronics.com/prop/ Howdy Steve! It's been my experience that if you ask a manufacturer, "Is this broken?", they'll see it as an opportunity to sell you another one. I don't know about airplane parts companies. Do most of them play straight with people? I guess I'm just overly suspicious. -- Fisherman Lost a ittty bitty spinner, you know the ones that just cover the prop bolts and little more. It hit the end of the prop as that was the only nick I could find, then hit the wing tip, just a small scratch. The local A&P was jumping up and down claiming I had to take the engine apart to check for crankshaft damage from a prop strike. I just filed the nick and put on a new spinner. |
Sport Pilot wrote: The local A&P was jumping up and down claiming I had to take the engine apart to check for crankshaft damage from a prop strike. I just filed the nick and put on a new spinner. Was this the same A&P who didnt do the job right in the first place? I wonder if he would be willing to finance a 3rd party doing the teardown and inspection, cause that is who I would send the bill to. I may be mistaken, but I was told if the strike didnt result in engine stoppage a teardown was not needed. Dave |
No problem to fix it.
The old AC 43 ?? tell you how to do it. best Jan Carlsson JC Propeller Design www.jcpropellerdesign.com "SteveR" skrev i meddelandet ... Last weekend I lost my spinner through my prop. I had removed it the previous weekend because the screw kept coming loose. I was going to leave it off until I found the right solution. An A&P where I keep my plane saw me messing with it, and came over to help. He went and grabbed a bolt and a difference nut plate, and put the spinner on. He didn't torque the bolt down as tight as I would have because he "didn't want to crush the nose of the spinner". I questioned him on it, asked if we should put lock-tite on it, and he said "naw, that ain't comin' off". Last time I take advice from him. Two flight hours later the spinner went through the prop. Although the damage to the prop wasn't nearly as bad as I expected, I'm still wondering if my $1,300 prop is now a wall-piece. I've already contacted the manufacturer (Prince Aircraft) and I'm waiting on their response. Let me know what you think. I did fly ~2.5hrs after this occurred (after checking it out on the ground). Tell me what you think...repairable or not? Pictures: http://www.wotelectronics.com/prop/ -- SteveR |
Dave S wrote:
Sport Pilot wrote: The local A&P was jumping up and down claiming I had to take the engine apart to check for crankshaft damage from a prop strike. I just filed the nick and put on a new spinner. Was this the same A&P who didnt do the job right in the first place? I wonder if he would be willing to finance a 3rd party doing the teardown and inspection, cause that is who I would send the bill to. I may be mistaken, but I was told if the strike didnt result in engine stoppage a teardown was not needed. Dave It kinda 'depends'. There's an AD for Lycs that says you must inspect a gear in the accessory case if you have a prop strike even if the strike is against *grass*. I suppose if you're smart enough to fly a homebuilt (or to wipe off the grass stains) then the AD might not apply... |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| my ignorance | LCT Paintball | Home Built | 25 | April 9th 05 07:54 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Prop spinner for Piper Arrow | dutch | Aviation Marketplace | 0 | January 18th 04 03:02 AM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
