Entering GPS waypoints
Old July 19th 05, 05:12 AM
Doug
Default Entering GPS waypoints
GPS is great. It's revolutionized small plane navigation. But one thing
that bugs me is that there are two or even possibly three ways of
entering a GPS waypoint.
DD MM SS Degrees minutes seconds which is how we were taught in
school
DD MM.XX Degrees minutes and 10ths and 100ths of minutes
DD.XXXX Some genius has Degrees and decimals of degrees.
I think the first way DD MM SS is the best but I could live with the
second way. But whatever we do, CAN WE GET EVERYONE TO AGREE ON ONE
METHOD!!! If it hasn't already caused an accident I bet it will. Also
search and rescue position reporting etc foulups are easily caused by
this.
Old July 19th 05, 10:33 AM
Cub Driver
On 18 Jul 2005 21:12:54 -0700, "Doug"
school
I've run into this one on DUATS, right?
s.
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old July 19th 05, 03:13 PM
Thomas Borchert
Doug,
METHOD!!!
Uhm, aren't you hailing from the land of feet, Fahrenheit, inch Hg.,
"point" and other pecularities? Coordinates are just another oddity in
the world of units...
Thomas Borchert (EDDH)
Old July 19th 05, 05:50 PM
Maule Driver
I must be living good. The last time I had to enter degrees and
anything was to put my home (private) airport into my Garmin 300XL
because it wasn't in the DB (and I wanted to ensure precision -
otherwise I could have just hit the button when sitting in the middle of
the runway). I've been using it for 6 years and have never entered
another one.
Before that the only time I had to enter them was into 1st generation
panel mount GPS glide computers that had no database. You would enter
20 to 30 waypoints for each contest site. Now that sucked, but GPS was
such magic, it sucked good!
school
this.
Old July 19th 05, 10:24 PM
Cub Driver
On Tue, 19 Jul 2005 16:13:03 +0200, Thomas Borchert
Uhm, what do you think, we have two measures of feet, degrees, inches?
Not for a couple centuries.
(Well, we have two measures of degrees, but only because some mindless
Frenchman thought it would help to run the world by the boiling and
freezing points of water. Here in Fahrenheit-land, the world is run by
the tolerances of the human body. Much more civilized. Who cares a fig
about what water thinks?)
Warbird's Forum:
Old July 20th 05, 12:42 AM
Doug
Well, I can think of a couple. You are down, safely but crashed. You
pick up an airliner on 121.5. Ready to copy, he says. You say N48 34'
26". He says uh, could you give that to me in fssst %^^ north
---***$%^& copy )(*)_*. Last you hear of him.
Or you have to enter the waypoint manually on a ferry flight. The unit
wants it one way, you are used to another. End up entering it wrong.
You run out of fuel.
Or CAP flight is searching off of a waypoint in DD MM SS and it's been
given to them in DD. XXXX and they do the conversion wrong. Guy dies of
exposure just before they find him.
You get the idea.
Old July 20th 05, 07:53 AM
Kai Glaesner
Cub,
[...] Who cares a fig about what water thinks?)
Serious pilots do, because water/moisture is what weather is made of... ;-)
Best regards
Kai
Old July 20th 05, 10:00 AM
Thomas Borchert
Kai,
And the pilots too, mostly.
Old July 20th 05, 12:18 PM
Well, check out the history of the inch.
There were 3 flavors up to the '50s(i believe), now it is set to
25.4mm(as a derivative of the metre) he he he he.
-Kees
PS. we have also two measures of degrees. Kelvin and Celcius, same
scale different zero-point.
Entering info into garmin Pilot3 The Ponderosa Owning 1 January 16th 05 12:32 AM
Types of Waypoints Gene Whitt Instrument Flight Rules 4 January 9th 05 09:29 PM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Minden Waypoints Carl Buehler Soaring 2 August 14th 04 06:22 PM
Garmin 76S question Carl Buehler Soaring 2 April 30th 04 11:06 AM
