#21
On Sat, 06 Aug 2005 13:57:33 -0400, Bryan Martin
wrote: See: http://encyclopedia.laborlawtalk.com/Jet_engine According to this article, modern turbine engines may achieve compression ratios of as high as 44:1 at very high altitudes (very cold intake air). But the compression ratio of a turbine engine can't be compared directly with the compression ratio of piston engines due to the differences between cyclic combustion and continuous combustion, among other things. He may have been referring to fuel/air ratios with the 14:1 and 70:1 numbers, but they still don't sound quite right. In any case, just because gasoline is burned at a certain F/A ratio and compression ratio in a piston engine has nothing to do with how you would burn it in a turbine. Piston engines operate at near stoiciometric mixtures: nearly all the oxygen and all the fuel react with each other leaving very little of either in the exhaust. This can not be done in a turbine. No matter what fuel is used it would result in melt-down of the hot section of the engine. Most of the air passing through a turbine engine is used to keep it cool. Only a small portion of the available oxygen is used to burn the fuel. Theoretically, just about any fluid fuel could be used in a turbine as long as you can produce a combustible mixture in the core of the combustor and pump enough excess air through it keep it cool. You could probably burn powdered solid fuels in a turbine if you could manage to feed a steady stream of it to in the combustors and get it to mix properly. Hmmm, a coal burning jet engine? Or flour? |
Bryan Martin wrote:
As I recall, the biggest problem with burning gasoline in a turbine is the the TBO is shortened due to the lower lubricating qualities of gasoline over jet fuel. The fuel pumps and injectors wear out quicker. Another related durability problem is lead deposits on the turbine blades. I'm not sure this was a significant problem with very early jet engines run on avgas, since they didn't last thousands of hours like nowadays. Possible problems while running the engine could result from the different fluid properties of the fuel. For example, gasoline is thinner and evaporates at a lower temperature, so acceleration and deceleration might be affected, vapor lock might occur. Steady state the engine will run the same. Heat and pressure is what drives the turbine, and it doesn't matter if the heat comes from Jet A, 100LL, turpentine, or whatever. |
#24
To AF retired, my experience? I was a jet engine mechanic AF43250, so I know
what I am talking about. As far as the cold section of the engine it has what is called a convergent-divergent duct system to compress the air to 70 parts oxygen to one part fuel, however the engine can't use all the air up to approximately 80% power so it exhausts it thru the bleed valve on the side of the engine.Again, check any engine guide and gasoline engines have approximately 14 parts oxygen to 1 part fuel, doesn't matter how its compressed. The fuel control controls the amount of fuel injected into the engine but it relies on pressure sensors and temperature sensors to do that. Using avgas the egt would go very high because of its quick burning characteristics compared to kerosene or other jets fuels therefore the pressure and temperature sensors would send that information to the fuel control for adjustment. The fuel control also is lubricated by jet fuel and would soon fail without this lubrication ( it is so critical that we had to submerge the fuel control in jet fuel for 24 hours prior to installation and then if we manually moved the controls more the three times prior to installation we had to send it back for rebuilding. Incidentally, I also worked on F-102.T-33,B-57,T-39,C-130,C-133,F-101,all the aircraft had the same requirements for fuel. Perhaps the more modern engine have more tolerant materials , however when talking to recent jet engine mechanics they say the requirements are the same. As I understand it the aircraft you flew on used the jets for takeoff and at times at altitude only, if that's truly the case the engine may be able to operate on avgas at those times and those times only. "Jim Carriere" wrote in message ... Bryan Martin wrote: As I recall, the biggest problem with burning gasoline in a turbine is the the TBO is shortened due to the lower lubricating qualities of gasoline over jet fuel. The fuel pumps and injectors wear out quicker. Another related durability problem is lead deposits on the turbine blades. I'm not sure this was a significant problem with very early jet engines run on avgas, since they didn't last thousands of hours like nowadays. Possible problems while running the engine could result from the different fluid properties of the fuel. For example, gasoline is thinner and evaporates at a lower temperature, so acceleration and deceleration might be affected, vapor lock might occur. Steady state the engine will run the same. Heat and pressure is what drives the turbine, and it doesn't matter if the heat comes from Jet A, 100LL, turpentine, or whatever. |
#25
#27
#28
It would appear as though we have another "wood species expert" in our
midst. In the first place, your original post used the term "compression ratio", not air-fuel ratio. I doubt you know what you are talking about. PLONK. Jim " wrote in message ... To AF retired, my experience? I was a jet engine mechanic AF43250, so I know what I am talking about. |
#29
Sorry Dan, Very true that I was in the Af in the 60's, however the 5 level
in 43250 indicates expert rating, 43270 would be inspections level. I worked on that many aircraft because in the 60's they didn't have as many jet engine mechanics as perhaps they have today, also as I was assigned to the flight line I had to be proficient on multiple aircraft as many different types visited Andrews afb, and the Clark afb. I apologize if I got feisty, it just seemed with some of the comments from everyone that some doubted my expertise and I attempted to explain what was reality versus logical with jet engines. "Dan, U.S. Air Force, retired" wrote in message news:8joJe.73553$FP2.30579@lakeread03... wrote: The J-33 is not a axial flow engine, it is centrifical flow with one stage of compression, AF I suggest YOU are the one who needs to read up on the subject and not me, btw do you believe everything that google returns as the factual information, I suggest you keep in your line of expertise and don't go outside of either apg or flt engineer, you definitely aren't experienced enough to debate jet engines and their feeding. You never made the distinction between types of engines. You said "As far as the cold section of the engine it as what is called a convergent- divergent duct system to compress the air to 70 parts oxygen to one part fuel, however the engine can't use all the air up to approximately 80% power so it exhausts it thru the bleed valve on the side of the engine." Try saying what you actually mean. I told you what my job was and it certainly wasn't a flight engineer. If you really were in the Air Force it wasn't very long since you never went beyond 5 level. How does that compare with my 20 years? As for Google I never said I believed everything or anything, I simply suggested you try using it instead of insulting me. Since you refuse to be civil this discussion is closed. Dan, U.S. Air Force, retired and damned proud of it "Dan, U.S. Air Force, retired" wrote in message news:QvnJe.71991$FP2.65700@lakeread03... wrote: To AF retired, my experience? I was a jet engine mechanic AF43250, so I know what I am talking about. As far as the cold section of the engine it has what is called a convergent-divergent duct system to compress the air to 70 parts oxygen to one part fuel, however the engine can't use all the air up to approximately 80% power so it exhausts it thru the bleed valve on the side of the engine. J-33s had bleed air? Please explain to me the J-33 used "convergent - divergent" air flow. Again, check any engine guide and gasoline engines have approximately 14 parts oxygen to 1 part fuel, doesn't matter how its compressed. The fuel control controls the amount of fuel injected into the engine but it relies on pressure sensors and temperature sensors to do that. Using avgas the egt would go very high because of its quick burning characteristics compared to kerosene or other jets fuels therefore the pressure and temperature sensors would send that information to the fuel control for adjustment. The fuel control also is lubricated by jet fuel and would soon fail without this lubrication ( it is so critical that we had to submerge the fuel control in jet fuel for 24 hours prior to installation and then if we manually moved the controls more the three times prior to installation we had to send it back for rebuilding. The lead in AvGas would have acted as a lubricant long enough to get where you were going. Incidentally, I also worked on F-102.T-33,B-57,T-39,C-130,C-133,F-101,all the aircraft had the same requirements for fuel. When you get a chance look at the -1 TOs for those aircraft. They list substitute fuels. A lot has changed since you were in, I'm assuming 1960ish, but fuel characteristics. You worked on all those aircraft in less than 6 years in the USAF? It took me 20 to do the aircraft I listed. Perhaps the more modern engine have more tolerant materials , however when talking to recent jet engine mechanics they say the requirements are the same. As I understand it the aircraft you flew on used the jets for takeoff and at times at altitude only, if that's truly the case the engine may be able to operate on avgas at those times and those times only. Do us both a favour and do some research on the subject, OK? Try Google. Telling me I don't know what I am talking about doesn't quite make for civil discourse. BTW, I never said I flew on B-36s or C-123s. Dan, U.S. Air Force, retired |
#30
Bryan,
a jet engine does use all the air it intakes after 80% throttle, prior to 80% the engine bleeds the part of the air not needed to the atmosphere thru a valve mounted on the side of the engine called a bleed valve. You are right about physics however the kerosene needs much more air then gasoline to achieve proper combustion. "Bryan Martin" wrote in message ... Gasoline fueled reciprocating engines may use a 14:1 oxygen to fuel ratio but this is totally irrelevant when discussing jet engines. Reciprocating engines combine all the oxygen they take in with the fuel, jet engines do not. You may have been a really good jet mechanic but you obviously don't know much about the physics involved. in article , at wrote on 8/7/05 8:14 AM: what is called a convergent-divergent duct system to compress the air to 70 parts oxygen to one part fuel, however the engine can't use all the air up to approximately 80% power so it exhausts it thru the bleed valve on the side of the engine.Again, check any engine guide and gasoline engines have approximately 14 parts oxygen to 1 part fuel, doesn't matter how its compressed. |
| Oshkosh Reflections | Jay Honeck | Home Built | 54 | August 16th 05 10:24 PM |
| Oshkosh Reflections | Jay Honeck | Owning | 44 | August 7th 05 03:31 PM |
| Oshkosh Reflections | Jay Honeck | Piloting | 45 | August 7th 05 03:31 PM |
| How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 01:05 AM |
| Oshkosh 2003 Redux | Montblack | Owning | 86 | August 14th 03 05:29 PM |
