#31
My original comment holds...
horsefeathers. Jim "David Lesher" wrote in message ... "RST Engineering" writes: If you look closely at an incandescent light bulb (especially the aviation versions like the 327-28 volt and 330-14 volt) you will see that the internals of the bulb start with a little dot of ceramic called the "bead". Well, I was not aware we were talking exclusively about aviation/space rated lamps, but as it turns out while working for LeRC; I almost emptied Building 142 with those unshortable lamps. I was driving them with NE555's which turned out to be effective, if somewhat smoky, fuses. The technician and I just looked at each other while the cloud rose toward the smoke detector....the one going to the sprinkler system and Evac alarms. |
Audio Panel Suggestions | Jay Honeck | Owning | 5 | May 9th 05 02:00 PM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 08:11 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
