At some point in time I remember hearing that above a certain altitude the
pilot or co-pilot must be wearing an O2 mask on commercial flights. Am I right? Details? |
Bob Gardner "fred" wrote in message ... At some point in time I remember hearing that above a certain altitude the pilot or co-pilot must be wearing an O2 mask on commercial flights. Am I right? Details? |
"Bob Gardner" wrote in message ... 91.211 So what the devil is "91.211"? Bob Gardner "fred" wrote in message ... At some point in time I remember hearing that above a certain altitude the pilot or co-pilot must be wearing an O2 mask on commercial flights. Am I right? Details? |
"fred" wrote in message ... So what the devil is "91.211"? FAR 91.211, applicable to the US. § 91.211 Supplemental oxygen. (a) General. No person may operate a civil aircraft of U.S. registry- (1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen for that part of the flight at those altitudes that is of more than 30 minutes duration; (2) At cabin pressure altitudes above 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen during the entire flight time at those altitudes; and (3) At cabin pressure altitudes above 15,000 feet (MSL) unless each occupant of the aircraft is provided with supplemental oxygen. (b) Pressurized cabin aircraft. (1) No person may operate a civil aircraft of U.S. registry with a pressurized cabin- (i) At flight altitudes above flight level 250 unless at least a 10-minute supply of supplemental oxygen, in addition to any oxygen required to satisfy paragraph (a) of this section, is available for each occupant of the aircraft for use in the event that a descent is necessitated by loss of cabin pressurization; and (ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. (2) Notwithstanding paragraph (b)(1)(ii) of this section, if for any reason at any time it is necessary for one pilot to leave the controls of the aircraft when operating at flight altitudes above flight level 350, the remaining pilot at the controls shall put on and use an oxygen mask until the other pilot has returned to that crewmember's station. |
"fred" wrote in message news:Tk8Me.
"Bob Gardner" wrote in message ... 91.211 So what the devil is "91.211"? So what the devil is Google? +oxygen +"91.211" 480 Hits. moo |
Steven P. McNicoll wrote: (ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. I flew on an air ambulance Lear 25 for a while.. and I can say I NEVER saw the cockpit crew remove the masks from the hangars and place them in "the ready position" even though we routinely went to FL 450-490. I am wondering how many operators follow this rule. Dave |
"Steven P. McNicoll" wrote
(ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed. The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. Bob Moore |
fred wrote:
So what the devil is "91.211"? 14 CFR 91.211 http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.3.7.6 --Sylvain |
"Bob Moore" wrote in message 21... The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. But still not applicable to the Greek 737 that went down yesterday, although a similar requirement may have existed for them. |
On Mon, 15 Aug 2005 23:37:07 GMT, "Steven P. McNicoll"
wrote: "Bob Moore" wrote in message . 121... The Part 121 requirement for Certificated Aircarriers is more restrictive than for Part 91 Operators. The FL350 is replaced with FL 250. But still not applicable to the Greek 737 that went down yesterday, although a similar requirement may have existed for them. What would have been the effect if the O2 bottle for the cockpit had been inadvertently filled with breathing air rather than O2? I seem to remember that this was discovered to have happened somewhere in the US in the last few months? I would think that a casual test would have found it normal, but that the PPO2 would have been substantially too low even with a pressurized mask? |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 06:45 AM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 06:40 PM |
