#21
I'm not sure of what to do with your post. I can't argue with anything in
it, but it is not very relevant to what the OP was asking about. If I am remembering correctly, he asked about getting an RV-3 in under the SP rule. It would not have any problem with flutter, or structure, I think it is safe to say. Sure, you could fly past the rule limits, but at some point in time, (probably when the pilot screws up, and the FAA is investigating) it has to make the muckety-mucks happy, that it is SP legal. That is the only question at issue, I think. -- Jim in NC "Rich S." wrote in message ... X-No-Archive "Morgans" wrote in message ... If you took a Lycoming, and said you were going to limit it for continuous operation at 2,000 RPM, that would not fly for the sport plane restrictions. They (the FAA) all know that this engine can run much faster than that, with no harm. So you are told to try again; no dice. Jim........... There are many factors besides engine operating parameters which limit cruising speed. In some aircraft it may be control surface flutter, others may be subject to overstress by outside aerodynamic forces (hence maneuvering speed). While an engine may be capable of driving an airframe at speeds in excess of 120 knots, the airframe itself may be beyond it's limits. The fellow who is holding the stick has the legal responsibility for setting the limits of safe operation on every flight. Just because a designer says it can do more, doesn't mean it will. That's what test periods are for. Let's not become our own worst enemy here by espousing a rule that few people think makes any sense at all -outside the group of new LSA manufacturers who stand to make a buck selling their airplanes. I'm not talking about the speed limit, BTW. I'm talking about the "You crossed the line and can't go back" clause. Rich S. |
"Rich S." wrote Unless I'm greatly mistaken, neither RPM nor airspeed limits are contained in the Operating Limitations of an Experimental, Amateur-built aircraft. True, but if it is being flown by a sport pilot, it has to meet the limitations. -- Jim in NC |
... I'm not sure of what to do with your post. I can't argue with anything in it, but it is not very relevant to what the OP was asking about. If I am remembering correctly, he asked about getting an RV-3 in under the SP rule. It would not have any problem with flutter, or structure, I think it is safe to say. Sure, you could fly past the rule limits, but at some point in time, (probably when the pilot screws up, and the FAA is investigating) it has to make the muckety-mucks happy, that it is SP legal. That is the only question at issue, I think. I guess all I mean is - as long as we don't squeak, another wheel will get greased. )Perhaps an RV-3 with a 10" pitch prop could qualify, and hover. Thanks for not quoting me. Rich S. |
#24
... "Rich S." wrote Unless I'm greatly mistaken, neither RPM nor airspeed limits are contained in the Operating Limitations of an Experimental, Amateur-built aircraft. True, but if it is being flown by a sport pilot, it has to meet the limitations. This time I was trying a direct answer to his question. The Operating Limitations (Big "O" Big "P") do not cover speed or rpm. Gauge markings are covered elsewhere as well. The one thing I (we?) do not want to appear as, is a beanery lawyer. I have no training in Federal Law other than Fire and building Codes. The one thing I did learn is when it ends up in court, it's a whole new ball game. We don't want to go there. Rich "It's a whole lot easier to beg forgiveness than to ask permission." S. |
#25
Once outside the Light Sport Airplane limits,
it's always outside and can't be brought back inside the LSA limits. Several people mentioned this, but I don't recall ever reading this anywhere else. Can someone provide a reference to a published rule that states this? My understanding is that it would be possible to take an experimental aircraft, and modify it so that it would meet the limitations of the sport pilot. I even asked AOPA this exact question about this a week or so ago, and their opinion was that the plane would have to be truly incapable of exceeding the speed limit, rather than just an RPM limitation. I think there's some room for debate on that, particularly if it's not a "normal" well defined aircraft engine. Cheers, Rusty |
#26
If this was the case ("truly incapable") they would not allow the use of a
ground adjustable prop. At least with some planes, while you would be incapable to exceed the speed limitation with a certain prop pitch setting, resetting the prop may allow you to exceed it. This may not be different than a "ground adjustable" RPM limiting device. Frank "Russell Duffy" wrote in message .. . ... ... I even asked AOPA this exact question about this a week or so ago, and their opinion was that the plane would have to be truly incapable of exceeding the speed limit, rather than just an RPM limitation. I think there's some room for debate on that, particularly if it's not a "normal" well defined aircraft engine. Cheers, Rusty |
#27
X-No-Archive
"Russell Duffy" wrote in message .. . I even asked AOPA this exact question about this a week or so ago, and their opinion was that the plane would have to be truly incapable of exceeding the speed limit, rather than just an RPM limitation. Rusty........ The way the rule is worded, "Maximum speed in level flight with maximum continuous power (Vh)-138 mph (120 knots)" doesn't seem to indicate that "the plane would have to be truly incapable of exceeding the speed limit". I think the question is, who determines "maximum continuous power", especially if the engine has no data plate? Rich S. |
#28
"frank" wrote in message
... If this was the case ("truly incapable") they would not allow the use of a ground adjustable prop. At least with some planes, while you would be incapable to exceed the speed limitation with a certain prop pitch setting, resetting the prop may allow you to exceed it. This may not be different than a "ground adjustable" RPM limiting device. Frank You and the AOPA guy seem to agree. He made the same point about the ground adjustable prop. Rusty |
#29
It's in 14 CFR 1.1:
"Light-sport aircraft means an aircraft, other than a helicopter or powered-lift that, since its original certification, has continued to meet the following: (1) A maximum takeoff weight ... (ii) 1,320 pounds (600 kilograms) for aircraft... (2) A maximum airspeed in level flight with maximum continuous power(VH) of not more than 120 knots CAS...." This certainly uncovers some of the confusion. We need to make sure and distinquish between "light sport aircraft", "experimental light sport aircraft", and aircraft that can be flown by sport pilots. The original question asked about a homebuilt, and specifically an RV-3, so I assumed it would have an experimental certification. My understanding is that it would be possible to take an experimental aircraft, and modify it so that it would meet the limitations of the sport pilot. Not if it had an "original certification" outside the limits. I suppose there's an opening for taking it apart, and building something new from some/all of the parts, but that's more than just modifying it. I don't agree with this. I've certified 3 experimental aircraft, and not one single time has the "maximum airspeed in level flight with maximum continuous power(VH)" ever been listed anywhere. The Vne is listed, but many aircraft have Vne's that can't be achieved in level flight, so it doesn't mean the plane will do it. The operating limitations received from the FAA with the airworthiness certificate don't list ANY speeds, as these must be determined during the phase one test period, and noted in the aircraft log. The log can be modified over time to reflect changes in the aircraft as well, so if modification is made that would reduce the weight, airspeed, etc, it appears to be perfectly legal to change the log to reflect that mod. That does not look like the "exact question" asked above. Let's see... The question I asked AOPA was- "I currently have an RV-3 with a two rotor Mazda engine. If I put a single rotor engine, with far less power, and use a prop that will reduce the top speed to 138 mph, could it be flown by a sport pilot?" Seems pretty close to the exact question to me :-) Cheers, Rusty |
#30
If it's your opinion that an experimental aircraft capable
of exceeding Vh of 120 knots when originally certified can later be modified to comply with the LSA definition, then we completely disagree. Yep, that's my opinion. At this point, the best thing we can do is agree to disagree. Rusty |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Weird Experimental Certificate wording - Normal? | Noel Luneau | Soaring | 7 | January 11th 05 03:53 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Onerous OPerating Procedures/Improper (illegal?) Use of Unicom Freq. | rjciii | Soaring | 2 | July 19th 03 08:55 PM |
