"Darrel Toepfer" wrote I rewired our C152 outlet to the voltage converters output. Even though the Lowrance Airmap 1000 supports upto 28v input. We didn't have the dropping resistor, input to the outlet was 24v... I'm admitting that I'm not the world's best when it comes to those electrons, all running around helter skelter, but I thought a dropping resistor only worked with a certain sized (constant) load. If you checked voltage at the plug with a volt meter, you would come out with 24 volts; if you checked it with the lighter going, you would come up with 12 volts. Right? That being the case, you have to use a converter, or a regulator, or something. I don't know. Anybody? -- Jim in NC |
"Morgans" wrote in message ... I'm admitting that I'm not the world's best when it comes to those electrons, all running around helter skelter, Me neither, but I've got a lot of people hoodwinked... but I thought a dropping resistor only worked with a certain sized (constant) load. If you checked voltage at the plug with a volt meter, you would come out with 24 volts; if you checked it with the lighter going, you would come up with 12 volts. Right? Absolutely correct. That being the case, you have to use a converter, or a regulator, or something. I don't know. Anybody? With switching regulators now coming into the market about as simple to use as bait, I'm going to run a two or three parter in Kitplanes on how to build simple switchers to go UP or DOWN. Jim |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| Wow - heard on the air... (long) | Nathan Young | Piloting | 68 | July 25th 05 07:51 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
