I recently acquired a Grob G-102 and am still struggling with getting
that second wing installed during rigging. I'd like to hear from any G-102 owners out there that are willing to share their tips and tricks on setup, especially concerning getting that wing lined up and installed. BDS |
Our club has a G102 that is a problem to rig unless the following points are
observed-- 1. The vertical stabilized must be absolutely vertical and held that way--usually by a person but a jig could be made. The person doing this must be made aware of the importance of this task, as their attention will wander otherwise. 2. The 4 wing pins must be very well greased--if not, they cannot push the spring "fingers" inside the fuselage fitting aside and the friction will prevent the insertion of the wing. This is the usual source of difficulty in our experience. 3. The "olive" bearings that the pins on the end of the spar must be lined up before inserting the wing and watched to be kept that way. The rear one (left wing) is hard to see-often impossible, but keep trying. The right wing goes in first so you can see the one you are chasing. Pay attention to dihedral. Good luck -- Hartley Falbaum "BDS" wrote in message ... I recently acquired a Grob G-102 and am still struggling with getting that second wing installed during rigging. I'd like to hear from any G-102 owners out there that are willing to share their tips and tricks on setup, especially concerning getting that wing lined up and installed. BDS |
Interesting point about the vertical stabilizer - we have found that when
the wing is being particularly stubborn (almost all the time), having someone grab the vertical stabilizer and "wiggle" it back and forth will usually allow the wing to gradually slip into place. I don't like having to do that though because it seems a little rough - I would like to find a method that doesn't require this, but that may not be possible. We have been greasing all of the pins and fittings but it sounds like a little extra on those 4 fuselage pins wouldn't hurt. Thanks for the input. BDS "HL Falbaum" wrote in message ... Our club has a G102 that is a problem to rig unless the following points are observed-- 1. The vertical stabilized must be absolutely vertical and held that way--usually by a person but a jig could be made. The person doing this must be made aware of the importance of this task, as their attention will wander otherwise. 2. The 4 wing pins must be very well greased--if not, they cannot push the spring "fingers" inside the fuselage fitting aside and the friction will prevent the insertion of the wing. This is the usual source of difficulty in our experience. 3. The "olive" bearings that the pins on the end of the spar must be lined up before inserting the wing and watched to be kept that way. The rear one (left wing) is hard to see-often impossible, but keep trying. The right wing goes in first so you can see the one you are chasing. Pay attention to dihedral. Good luck -- Hartley Falbaum |
As stated by HL, item one is an absolute! At Grob in Bluffton they have a
fuselage dolly that holds it firmly in place to keep the fuselage from rotating after the right wing is in place. I assemble mine (upon rare occasion anymore since I keep it assembled in a hangar now) by myself with a wing holder but the most important little item turned out to be a jack under the right wing with very thick padding on top, under the wing about 1-2 feet from the fuselage placed under the spar. This keeps the fuselage from rotating when the weight of the left wing root starts to load the fuselage on its way in. A wing support at the tip doesn't really do the job because of the wing flex and lets the fuselage move sideways slightly. Gale Winnett Grob 102 III |
I am one of the self-proclaimed Grob 102 assembly experts at our club.
In addition to all the points that Hartley made, here are my suggestions: 1. First you must consider the task. You basically need to align 4 different interrelated pins and receptacles at the same time. As you know from a lot of experience, that can be much easier said than done. However, done in the proper sequence, it can actually be a rather simple process. 2. You need 4 well-directed people to do it quickly. (You can get by with 3 if you have the proper tail jig to keep the fuselage from rotating.) The four are distributed as follows: Person A at the leading edge of the wing root, Person B at the trailing edge of the wing root, Person C on the wingtip, and Person D on the tail. The person directing the assembly, Person A, should be at the leading edge of the wing root because that is the only person that can observe the entire operation. 3. The right wing should be put on first. This should give you a chance to observe the task a little closer. As you will see, each wing has a swiveling drag pin at the front and rear of the wing root, an "olive" style receptacle to receive the spar pin from the opposite wing, and a spar pin protruding out from the end of the spar. Prepare the wings by making sure that the "olive" is straight and ready for a pin to be inserted into it. 4. The drag pins _must_ be well lubricated _and_ and the wing root manipulated so that they are perfectly perpendicular to the receptacles on each side of the fuselage before attempting to slide the wing into place. Persons A and B (the ones on the wing root) are the ones who must accomplish this - usually by cooperatively raising and lowering the wing root. Practice a couple of times by taking it out and putting it back in to get the sense of what you are doing. 5. Once the right wing is in place, I usually activate both of the right side retainer mechanisms to keep that wing from being pushed out when we start installing the left wing. 6. Place a wind stand under the right wing tip. 7. Observe the right wing spar and spar pin as it protrudes out of the left wing spar receptacle on the left side of the fuselage. Rotate the fuselage so that the spar is approximately centered vertically. Person D accomplishes that task by rotating the fuselage. 8. Prepare to install the left wing by getting another wing stand near the left wing tip to relieve Person C in case you have difficulty and need to take a break. 9. Rotate the left wing and begin placing it into position but stopping approximately 4 inches out (before any of the pins touch their receptacles. 10. Persons A and B will position the wing root so that only the tips of the fore and aft drag pins are in the fuselage receptacles. Lift and maneuver the wing root so that the drag pins are exactly perpendicular to the receptacles. Hold the wing steady in this position. Do NOT attempt to install it yet. 11. Person A should observe the position of the right wing spar pin as it is approaching the left wing "olive" receptacle. If the pin is high or low then Person D should rotate the fuselage to correct it. Clockwise to lower the pin, counter-clockwise to raise it. Of course Persons A and B should readjust the root to make sure that the drag pins are still perpendicular. Redo this step until it appears that, if you could slide the wing in at that moment, the 3 left side pins would engage without further manipulation. 12. Person A should now look inside the fuselage and observe the left wing spar pin and its relation to the "olive" receptacle in the right wing. Person C (the left wing tip person) is the one that can adjust this. Person A gives Person C the appropriate corrections (up, down, fore, aft) to get this pin aligned. 13. Begin slowly pushing the wing into place. The right spar pin should begin to enter the left wing olive first. If it is not aligning properly then redo the appropriate steps above to get it all aligned. 14. Now shift attention to the left spar pin as it enters the right wing "olive". Give Person C appropriate directions to keep it aligned. 15. With the pins aligned this way, they should slip right together. A little nudging, especially by Persons A and B is usually all that is needed for the whole thing to slip together easily. 16. Engage all 4 of the retaining mechanisms. Be sure all of the retainers are properly tightened. I like to have a person on each wing, flexing them up and down and fore and aft to be able to get all the play out of the mechanisms. While this all sounds complicated, after you understand the task properly, and get the appropriate people in place, it can be done in a very few minutes. Remember, it doesn't require a lot of force. just getting it properly aligned before you slowly slip it into place. Good luck, Larry "BDS" wrote in message : Interesting point about the vertical stabilizer - we have found that when the wing is being particularly stubborn (almost all the time), having someone grab the vertical stabilizer and "wiggle" it back and forth will usually allow the wing to gradually slip into place. I don't like having to do that though because it seems a little rough - I would like to find a method that doesn't require this, but that may not be possible. We have been greasing all of the pins and fittings but it sounds like a little extra on those 4 fuselage pins wouldn't hurt. Thanks for the input. BDS "HL Falbaum" wrote in message ... Our club has a G102 that is a problem to rig unless the following points are observed-- 1. The vertical stabilized must be absolutely vertical and held that way--usually by a person but a jig could be made. The person doing this must be made aware of the importance of this task, as their attention will wander otherwise. 2. The 4 wing pins must be very well greased--if not, they cannot push the spring "fingers" inside the fuselage fitting aside and the friction will prevent the insertion of the wing. This is the usual source of difficulty in our experience. 3. The "olive" bearings that the pins on the end of the spar must be lined up before inserting the wing and watched to be kept that way. The rear one (left wing) is hard to see-often impossible, but keep trying. The right wing goes in first so you can see the one you are chasing. Pay attention to dihedral. Good luck -- Hartley Falbaum |
Assuming your Grob 102 rigs the same as the Astir CS I used to fly
(maybe it's the same model), I always rigged best with just two people. Really very simple: Before starting - Grease all pins, including pins on spar ends, and *check collars are unlocked* - it's amazing how often one has been locked accidentally, and if so you'll never rig it. 1. Slide in starboard wing, lock the collars and trestle tip. 2. Check that the end of the spar is centred vertically in the space wher the port wing spar will go. If not, adjust by rotating fuselage (usually best, as the leverage of raising and lowering the tip often rotates the fueslage so the spar end is still not centred). If the fuselage slips in the belly dolly, a third person could hold the tail in the correct position. 3. Insert port wing until the pins on the fuselage just start to engage (you might need to reach over and lift the trailing edge slightly), then trestle tip to take the weight, but keep wingtip holder at tip. Trestling is not essential here, but why lose a friend? 4. Look at starboard wing root to see where the pin on the port wing root has to engage with a bush/olive (i.e. hole). Ask wing tip holder to raise/lower (trestle shouldn't have been too high to permit this)/move forward/move back until this is lined up. *If the pin/hole are not aligned the wing will never go on*. *Do not allow some well-meaning idiot who has never rigged a glider of this type to wiggle the wingtip*. 5. Check the fuselage/port wing root pins are still engaged - if so, reach over the wing, lift the trailing edge a little, lift the leading edge a little and slide it in to place. Lock off collars. If this takes more than 5 minutes you are doing it wrong. The two key points are (a) making sure the starboard wing spar end is central vertically and (b) aligning the port spar end pin with the hole in the starboard wing. wrote: As stated by HL, item one is an absolute! At Grob in Bluffton they have a fuselage dolly that holds it firmly in place to keep the fuselage from rotating after the right wing is in place. I assemble mine (upon rare occasion anymore since I keep it assembled in a hangar now) by myself with a wing holder but the most important little item turned out to be a jack under the right wing with very thick padding on top, under the wing about 1-2 feet from the fuselage placed under the spar. This keeps the fuselage from rotating when the weight of the left wing root starts to load the fuselage on its way in. A wing support at the tip doesn't really do the job because of the wing flex and lets the fuselage move sideways slightly. Gale Winnett Grob 102 III |
"Chris Reed" wrote in message
... If this takes more than 5 minutes you are doing it wrong. The two key points are (a) making sure the starboard wing spar end is central vertically and (b) aligning the port spar end pin with the hole in the starboard wing. Well, I'm definitely doing it wrong - I'd say we'd be lucky to get the wings on in less than 30-45 minutes and without losing a good 2-3 lbs of body weight due to perspiration! One time before de-rigging and at the suggestion of another club member I marked the proper spar location for the right wing on the bulkhead just behind it. Now I know when I put the right wing in that it is in the proper place, or at least very close. We do check all the pins and their mating bushings before trying to get them to mate. The frustrating thing is that they all look just fine but the wing will still refuse to go in. I have tried (due to frustration) to wiggle the wing fore and aft and up and down but that never helps at all. Based on the experience with wiggling the vert stab and many of the comments here it sounds like my main problem is some twist in the fuselage during the assembly process. I will pay closer attention to this next time and see if things go more smoothly. BDS |
That's essentially how one of our club members does it on his CS,
except he does it alone using his tip stand, wing dolly, ramp and jacks, wing stands and alignment marks (most of the rig he built himself as copies from an LS-3 setup at the club). He does leave his trailer in the same place week to week, but he rigs/derigs daily. It takes a bit of aligning if he moves the trailer, but not a real hassle. Frank Whiteley |
If everythig is alined and it won't go in, the front and rear drag pins need
more grease! The swivelling pins with the groove on them have a very short and steep taper, and the spring fingers inside the receptacle on the fuse are strong. A good viscous grease like wheel bearing grease works better than white lithium. My new favorite (Thanks Larry "01") is Radio Shack lubricating gel. I have not tried STP or Motor Honey but they might work even better. They are liquid and harder to handle though. The part about centering the right spar in the left spar box opening is critical. Perfect practice makes perfect performance-- Best of luck HL Falbaum -- "BDS" wrote in message ... "Chris Reed" wrote in message ... We do check all the pins and their mating bushings before trying to get them to mate. The frustrating thing is that they all look just fine but the wing will still refuse to go in. I have tried (due to frustration) to wiggle the wing fore and aft and up and down but that never helps at all BDS |
Cleaning and greasing help a lot, or did with our G-103. Once we got
our trailer more user friendly, a few people started landing out. Interesting how easy it got to rig and derig once cleaned up and lubed. Frank Whiteley |
| Thread Tools | |
| Display Modes | |
| Glider Independent Palm Nav Setup | John Doe | Soaring | 5 | April 8th 05 05:58 PM |
| Grob 102 AD superseded | Jim Phoenix | Soaring | 3 | September 15th 04 02:40 AM |
| Help with Grob Needed | Scott | Soaring | 5 | January 11th 04 06:07 AM |
| Help, Need Complete Front Canopy for Grob 103 | Carl Buehler | Soaring | 0 | December 28th 03 03:15 AM |
| Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 01:14 AM |
