#11
Glider guys do this all the time with 50 foot (15meter) or larger wings -
sometimes just one man assembly in less than 10 minutes. The newest sailplanes have automatic control hookups and are very easy to assemble. They are so easy to assemble that most pilots leave their gliders in trailers at the airport and assemble them each time they fly. Bill Daniels "Andre" wrote in message news:434670fc$1@newshark... A few years back I was looking into the Valkyre. They were going to use carbon fibre wings with linkages between the wing and the body so that all you had to do was slide the wing into position and lock it. Two min job per wing. Neat design, too bad they spent so much time trying to perfect the design that they went out of business. "Morgans" wrote in message ... "George Patterson" wrote I don't see how. You can pull a wing off a Cessna 152, 172, etc. by removing three bolts. With a Maule, it's four. Can't get much simpler than that. Of course, you still need to mess around with the aileron cables and flaps linkages, but you'd have to do that with a folding design too. Messing around with aileron and flap cables is not a given, with the right design features. I have read about some planes, (in the case I am thinking of, sailplanes) that have the linkages mate in such a way that no tools are even needed. Anyone know of what I am remembering? -- Jim in NC |
... Messing around with aileron and flap cables is not a given, with the right design features. I have read about some planes, (in the case I am thinking of, sailplanes) that have the linkages mate in such a way that no tools are even needed. Anyone know of what I am remembering? -- The two aileron cables are connected to a "Swash plate" located at the wing joint. Another matching swash plate is mounted in the wing with cables continuing to the aileron bell crank. When the wing is in place, the two swash plates are in contact. Which ever way the inner plate moves, the outer plate must follow. ---------------||---------------- || ---------------||---------------- Rich S. |
![]() "Ron Natalie" wrote Flaps? flaps? Ercoupes ain't got no flaps. Chuckle Perhaps I should look at the title of the thread, once in a while. I forgot all of this folding wing stuff was in reference to Ercoupes. I don't know why you would want to take a good certified plan, and chop it up to make the wing fold. Not much to be gained, here. The poster's intent was talking about a new sLSA design, I thought. I don't know anymore. What day is it? I'm confused! g -- Jim in NC |
![]() "Rich S." wrote The two aileron cables are connected to a "Swash plate" located at the wing joint. Another matching swash plate is mounted in the wing with cables continuing to the aileron bell crank. When the wing is in place, the two swash plates are in contact. Which ever way the inner plate moves, the outer plate must follow. ---------------||---------------- || ---------------||---------------- I thought that is how it worked. I have never seen a setup like that, in person; only read about them. -- Jim in NC |
I do remember the Dewey Bryan crash, recall that he was using an electric
motor with acme screw or a electric solenoid, believe he hit a switch in the cockpit and retracted a shear pin, EAA recommended making it a requirement to remove said pin from the outside only, Phil. Lohiser "Montblack" wrote in message ... Fix the high cost [Was:] High Cost of Sportplanes "Any mass produced successful sport aircraft today ought to have folding wings, whether it's trailered or if it goes in a community hanger. There is a folding wing mod for the venerable Ercoupe (it's STC'd or their equivalent in Canada, I'm not sure here) and five or six of them will fit in the hangar footprint of a Skylane." Some Ercoupes have (STC'd) folding wings? http://www.roadabletimes.com/roadables-integ_bryan.html (Saw this, for the first time, while hunting in Google) Montblack |
EVERY naval carrier aircraft except the A-4 Scooter has folding wings.
They hold up well in naval service, and add a small amount to the weight of the aircraft. As far as T-hangars go, obviously you wouldn't have T-hangars in the first place if the wings folded. A lot of airplanes don't fit well in T-hangars anyway. Change; it's a wonderful thing. |
![]() Bret Ludwig wrote: EVERY naval carrier aircraft except the A-4 Scooter has folding wings. They hold up well in naval service, Of course they do. The Navy can throw unlimited resources at an airplane for maintenence. Just look at what it takes to keep an F14 in the air for an hour. |
Morgans wrote:
"Rich S." wrote The two aileron cables are connected to a "Swash plate" located at the wing joint. Another matching swash plate is mounted in the wing with cables continuing to the aileron bell crank. When the wing is in place, the two swash plates are in contact. Which ever way the inner plate moves, the outer plate must follow. ---------------||---------------- || ---------------||---------------- I thought that is how it worked. I have never seen a setup like that, in person; only read about them. The Delta's elevons are split in half. The inner half controlled with a horn. A pin (a 5/16 bolt) welded in the outer panel's trailing edge slots into the inner panels trailing edge tube. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() Newps wrote: Bret Ludwig wrote: EVERY naval carrier aircraft except the A-4 Scooter has folding wings. They hold up well in naval service, Of course they do. The Navy can throw unlimited resources at an airplane for maintenence. Just look at what it takes to keep an F14 in the air for an hour. The wing folding systems are not maintenance hogs and are not a prevailing cause of crashes: in fact i don't think one has ever happened. A Crusader was accidentally launched with folding wings once: it was actually able to recover. |
Newps wrote:
Bret Ludwig wrote: EVERY naval carrier aircraft except the A-4 Scooter has folding wings. They hold up well in naval service, Of course they do. The Navy can throw unlimited resources at an airplane for maintenence. Just look at what it takes to keep an F14 in the air for an hour. Certainly, the F-14 is an extremely complicated piece of equipment. The problem with your example is the Navy doesn't spend a penny on the F-14 for folding wing systems since the wings don't fold, they sweep. Dan, U.S. Air Force, retired |
Two place, folding wing, historic homebuilt | [email protected] | Home Built | 12 | March 11th 06 12:12 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Grob G102 Setup | BDS | Soaring | 11 | August 30th 05 03:42 PM |
Wide Body Folding Wing T-18 Parts for Sale | Don B | Home Built | 0 | October 6th 03 07:21 AM |
