Folding wing for Ercoupes?
Old October 7th 05, 03:44 PM
Bill Daniels
Glider guys do this all the time with 50 foot (15meter) or larger wings -
sometimes just one man assembly in less than 10 minutes. The newest
sailplanes have automatic control hookups and are very easy to assemble.
They are so easy to assemble that most pilots leave their gliders in
trailers at the airport and assemble them each time they fly.
Bill Daniels
"Andre" wrote in message
news:434670fc$1@newshark...
A few years back I was looking into the Valkyre. They were going to use
carbon fibre wings with linkages between the wing and the body so that all
you had to do was slide the wing into position and lock it. Two min job
per
wing.
Neat design, too bad they spent so much time trying to perfect the design
that they went out of business.
"Morgans" wrote in message
"George Patterson" wrote
I don't see how. You can pull a wing off a Cessna 152, 172, etc. by
removing
three bolts. With a Maule, it's four. Can't get much simpler than
that.
Of
course, you still need to mess around with the aileron cables and
flaps
linkages, but you'd have to do that with a folding design too.
Messing around with aileron and flap cables is not a given, with the
right
design features.
I have read about some planes, (in the case I am thinking of,
sailplanes)
that have the linkages mate in such a way that no tools are even needed.
Anyone know of what I am remembering?
Jim in NC
Old October 7th 05, 03:45 PM
Rich S.
Messing around with aileron and flap cables is not a given, with the right
design features.
I have read about some planes, (in the case I am thinking of, sailplanes)
The two aileron cables are connected to a "Swash plate" located at the wing
joint. Another matching swash plate is mounted in the wing with cables
continuing to the aileron bell crank.
When the wing is in place, the two swash plates are in contact. Which ever
way the inner plate moves, the outer plate must follow.
Rich S.
Old October 7th 05, 10:52 PM
Morgans
"Ron Natalie" wrote
Flaps? flaps? Ercoupes ain't got no flaps.
Chuckle Perhaps I should look at the title of the thread, once in a
while. I forgot all of this folding wing stuff was in reference to
Ercoupes. I don't know why you would want to take a good certified plan,
and chop it up to make the wing fold. Not much to be gained, here.
The poster's intent was talking about a new sLSA design, I thought. I don't
know anymore. What day is it? I'm confused! g
Jim in NC
Old October 7th 05, 10:53 PM
Morgans
wing
I thought that is how it worked. I have never seen a setup like that, in
person; only read about them.
Jim in NC
Old October 8th 05, 04:02 AM
Phil
I do remember the Dewey Bryan crash, recall that he was using an electric
motor with acme screw or a electric solenoid, believe he hit a switch in the
cockpit and retracted a shear pin, EAA recommended making it a requirement
to remove said pin from the outside only, Phil. Lohiser
"Montblack" wrote in message
Fix the high cost [Was:] High Cost of Sportplanes
"Any mass produced successful sport aircraft today ought to have
folding wings, whether it's trailered or if it goes in a community
hanger. There is a folding wing mod for the venerable Ercoupe (it's
STC'd or their equivalent in Canada, I'm not sure here) and five or six
of them will fit in the hangar footprint of a Skylane."
Some Ercoupes have (STC'd) folding wings?
http://www.roadabletimes.com/roadables-integ_bryan.html
(Saw this, for the first time, while hunting in Google)
Montblack
Old October 8th 05, 04:10 AM
Bret Ludwig
EVERY naval carrier aircraft except the A-4 Scooter has folding wings.
They hold up well in naval service, and add a small amount to the
weight of the aircraft.
As far as T-hangars go, obviously you wouldn't have T-hangars in the
first place if the wings folded. A lot of airplanes don't fit well in
T-hangars anyway.
Change; it's a wonderful thing.
Old October 8th 05, 05:01 AM
Newps
Of course they do. The Navy can throw unlimited resources at an
airplane for maintenence. Just look at what it takes to keep an F14 in
the air for an hour.
Old October 8th 05, 05:13 AM
Ernest Christley
Morgans wrote:
wing
The Delta's elevons are split in half. The inner half controlled with a
horn. A pin (a 5/16 bolt) welded in the outer panel's trailing edge
slots into the inner panels trailing edge tube.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old October 8th 05, 05:31 AM
Bret Ludwig
The wing folding systems are not maintenance hogs and are not a
prevailing cause of crashes: in fact i don't think one has ever
happened.
A Crusader was accidentally launched with folding wings once: it was
actually able to recover.
Old October 8th 05, 07:30 PM
Rich S.
"Bret Ludwig" wrote in message
A fellow in our church group is a retired naval captain who flew A-7 Corsair
II's during Nam. His CAG took off one night on a "lights out" training
mission from a Naval Air Station runway. The Corsair II would barely climb,
so he aborted the mission and circled around for landing. He really had to
keep a lot of power on during the approach, but made a successful touchdown
and roll out.
Back on the ramp, he went through his shutdown checklist until he got to the
item "Fold Wings". The switch was in the folded position already. De-assing
the aircraft, he noticed that the wings were more than folded. They were
bent so the tips almost touched.
The wing lift had sprung both wings inward. The aircraft was beyond
practical repair and was scrapped.
Rich S.
Two place, folding wing, historic homebuilt [email protected] Home Built 12 March 11th 06 12:12 AM
Folding wing for Ercoupes? Montblack Home Built 41 October 12th 05 09:38 PM
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
