Zinc Chromate in 2005
I'm looking at a 60 year old Tcraft. She was originally primed with
zinc chromate. If I need to remove some fabric to get at some rust, is there any reason I shouldn't use ZC as a primer? After all, the last application seems to have lasted 60 years! Are there any concerns about any of the Dacron-based covering processes adhereing to the ZC? - Mike |
According to the Polyfiber manual, you can prime over the ZC with epoxy
and then the dacron will stick using polytak. |
Please correct me if I'm wrong, but I believe I've seen multiple fuselages from the mid-70s that were ZC primed and covered in Ceconite, so I'm thinking the dacron adhesion to ZC couldn't be much of a problem! Again, please let me know if you think I'm miss-reading what I've been seeing - Mike wrote: According to the Polyfiber manual, you can prime over the ZC with epoxy and then the dacron will stick using polytak. |
Yes it can be done, but the solvents in the dope disolves the zinc
chromate primer. It's better to use a two part primer that the dope will adhere to, but not disolve. i suspect that back in the 70's two part primers were not that popular so the people who covered aircraft used what had been used all along, ZC. Michael Horowitz wrote: Please correct me if I'm wrong, but I believe I've seen multiple fuselages from the mid-70s that were ZC primed and covered in Ceconite, so I'm thinking the dacron adhesion to ZC couldn't be much of a problem! Again, please let me know if you think I'm miss-reading what I've been seeing - Mike wrote: According to the Polyfiber manual, you can prime over the ZC with epoxy and then the dacron will stick using polytak. |
The solvents in Stits (Polyfiber) glue, known as Polytak, include
methyl ethyl ketone, which will dissolve primers such as zinc chromate. The glue is thereby contaminated and diluted and loses some of its strength. Matter of fact, if you don't prime with Polyfiber's proprietary epoxy over the ZC the STC is voided. I'm unfamiliar with Ceconite but understand Polyfiber has bought the rights to it. |
Similar Threads | ||||
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 08:48 PM |
[ICSEng'05] Final CFP - due date March 10, 2005 | Utthaman | Naval Aviation | 0 | March 5th 05 09:07 AM |
17 Feb 2005 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | February 17th 05 09:51 PM |
Int. Conf. on Systems Engineering'05 - August 16-18, 2005 | avinash | Naval Aviation | 0 | January 29th 05 10:13 PM |
CPA 2005 Fly-In Announced | Jay Honeck | Piloting | 4 | November 15th 04 03:31 AM |
