Perlan project - high wave flights
Old October 18th 05, 09:26 PM
Bill Daniels
Default Perlan project - high wave flights
I wonder if these guys have fireproof flying suits.
See: http://www.sciencedaily.com/releases...1018075220.htm
Quote from article:
"Previous observations near the Andes Mountains in Peru had found that the
atmosphere directly above some peaks was approximately 100 Kelvin [100
degrees Celsius; 200 degrees Fahrenheit] hotter than in nearby regions and
that the difference occasionally reached as much as 400 Kelvin [400 degrees
Celsius; 700 degrees Fahrenheit]. "
Bill Daniels
Old October 20th 05, 01:45 AM
Francisco De Almeida
Quite interesting, but I do not think the article leads to such =
conclusion. Think about it: several types of aircraft have been flying =
very high above mountain peaks in the last half century without bursting =
into flames.
If you go still higher, temperatures rise naturally up to about 800 =
Kelvin in the Thermosphere. You run no risk of burning, though: the air =
density by then is so low that any heat gained from collision with air =
molecules cannot even offset the heat lost to outer space through =
radiation. The (accoustically generated) temperature spikes theorised in =
the article are therefore not so exceptional when viewed in context.
I suppose the Perlan people need to be well dressed, indeed, but not =
against the heat.
F.A.
Old October 20th 05, 02:15 AM
Bill Daniels
"Francisco De Almeida" wrote in message
into flames.
against the heat.
F.A.
You're right, of course. My posting was just a bit tongue in cheek. The
first scan of the abstract didn't make clear that the temperature spikes
were in the thermosphere (150 Km or so above the stratosphere) but a more
careful reading of the body did.
What IS interesting is that a phenomenon with roots in orographic turbulence
reaches this far above the earth's surface.
Oh what we don't know!
Bill Daniels
Sierra wave record breaking flights IGC files [email protected] Soaring 4 April 8th 05 04:15 AM
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 06:56 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
Ownership and passengers Roger Long Owning 30 October 11th 03 03:00 PM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 04:31 AM
