![]() "John T" wrote in message m... "Mike W." wrote in message If you hear 'runway zero', then you know you have missed something in the transmission. Similarly, if you're in the pattern for runway 20 and you hear somebody announce "[your airport] traffic, N123 base, runway 2[garbled]", you can assume you've missed something. You still haven't made a case for using anything but the numbers painted on the runway. Well, yes, the case is easy to make. If everybody used the leading zero all the time, then you KNOW FOR SURE anytime you hear less than two digits, then you have missed something. If the leading zero is NOT used and you hear only ONE digit, then you have no way of knowing whether you missed something, or not. Shortening a direction-based entity in this way is unnatural and causes confusion. Even the FAA's own NACO chart-selection web site, uses the leading zeros in the index, and then omits them on the charts.. |
Why does announcing "Runway Two Zero" allow the last digit to be cut off
while announcing "Runway "Zero Two" prevents the last digit from being cut off? It doesn't. It prevents the last digit from being cut off =unawares=. It acts as a checksum of sorts. If all runways are two digits, then any transmission missing a digit is suspect. If some are one and some are two, then there are some cases where an error would not be noted; this is especially the case with runway 2-20, both of which exist on most airports for which one exists. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
I once flew to an ratehr rundown airport with a 2-20. The Unicom was
so badly garbled that I even after asking Unicom to "say again" three or four times, I had no idea whether the guy was saying "zero two" or "two zero." "Runway one plus one, or runway ten plus ten?" Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
.... this is especially the case with runway 2-20, both of which exist on most
airports for which one exists. I once flew to an ratehr rundown airport with a 2-20. The Unicom was so badly garbled that I even after asking Unicom to "say again" three or four times, I had no idea whether the guy was saying "zero two" or "two zero." No wind tee, wind sock to bedraggled to make out from pattern altitude. Based on winds in the general area, I suspected he was saying "zero two" so I asked him "Runway 2?" and he came back with the same number of garbled sylables as before. Hearing no other traffic after two circuits, I finally just landed on runway 2 and tried to teach the guy how to announce runways. Had he said "Runway two," I would have known from the number of syllables which runway he meant. vince norris |
![]() "Jose" wrote in message .. . It doesn't. It prevents the last digit from being cut off =unawares=. It acts as a checksum of sorts. If all runways are two digits, then any transmission missing a digit is suspect. If some are one and some are two, then there are some cases where an error would not be noted; this is especially the case with runway 2-20, both of which exist on most airports for which one exists. Wouldn't the gap in the transmission do that? |
acts as a checksum of sorts. If all runways are two digits, then any transmission missing a digit is suspect. If some are one and some are two, then there are some cases where an error would not be noted; this is especially the case with runway 2-20, both of which exist on most airports for which one exists. Wouldn't the gap in the transmission do that? Maybe. But not certainly. People don't always speak with the same cadence, so time is a poor checksum. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
![]() "Mike W." wrote in message ... If you hear 'runway zero', then you know you have missed something in the transmission. Two things, actually, the runway and the airport. |
transmission. Two things, actually, the runway and the airport. Yes, but missing the airport does not imply a transmission error. The airport simply may not have been transmitted. Poor form, but not a data error. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Hi Jose. I like your checksum argument. It's two digits for me from now
on, and we should urge everyone to adopt this convention. |
on, and we should urge everyone to adopt this convention. It's actually somebody else's idea, though I recognized it as like a checksum. However, "zero two" and "two zero" can be confused with each other even when each is clearly heard. You've all heard of the dyslexic agnostic insomniac? He stayed up all night wondering if there really was a dog. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
