#11
![]() I had never had a problem until this weekend when I was out on a joyride with a friend. My 296 lost signal twice withing minutes. The first time, I just double checked the anntena connection and it seemed to come back (this is the suction-cup antenna). The second time, I did the same thing again, no joy. Waited a bit, and then realized that the excess cable from the antenna was balled up in and around my headset cord. I picked it all up and shoved it on the dash and the signal came back immediately. It didn't drop for the remaining 45 minutes. Some sort of interference? -ccq |
I have a GPS 296 recently bought - August 2005.
Its problem is that occasionaly does not power on - while is working with battery - and needs to take out and re-insert the battery. I emailed Garmin but no answer yet... Any suggestions? Mike Noel wrote: I had a similar problem with my 296 except that is would turn itself off in the air. I sent it in and Garmin ended up calling it corrupted user data. After they purged the stored data, it worked OK for a while. When it started doing it again the Garmin tech had me clear the data by removing and re-inserting the battery, then holding down three buttons to give it a lobotomy. It's working OK for now, but I suspect I will have to kill the user data again sometime to re-fix it. "Maule Driver" wrote in message . com... No loss of signal... but I just sent my 396 in for service. Long story short -it would just stop working for no apparent reason. Screen would go black. Only way to restart was with a battery re-insert. The only apparent pattern it that it would never happen in the a/c. Only on the ground. Swapped everything except for the stick attenna which I used 100% on the ground and 0% in air. So back it goes for repair. Jeff B wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
The first thing they will have you do is upgrade the software, so you might
as well do that first. Then,if the problem persists (and it probably will), call them on the phone. The email route takes too long. -- Mike Noel, Tucson, Arizona 'Men never do evil so completely and cheerfully as when they do it from religious conviction.' -Blaise Pascal "Alexandros" wrote in message oups.com... I have a GPS 296 recently bought - August 2005. Its problem is that occasionaly does not power on - while is working with battery - and needs to take out and re-insert the battery. I emailed Garmin but no answer yet... Any suggestions? Mike Noel wrote: I had a similar problem with my 296 except that is would turn itself off in the air. I sent it in and Garmin ended up calling it corrupted user data. After they purged the stored data, it worked OK for a while. When it started doing it again the Garmin tech had me clear the data by removing and re-inserting the battery, then holding down three buttons to give it a lobotomy. It's working OK for now, but I suspect I will have to kill the user data again sometime to re-fix it. "Maule Driver" wrote in message . com... No loss of signal... but I just sent my 396 in for service. Long story short -it would just stop working for no apparent reason. Screen would go black. Only way to restart was with a battery re-insert. The only apparent pattern it that it would never happen in the a/c. Only on the ground. Swapped everything except for the stick attenna which I used 100% on the ground and 0% in air. So back it goes for repair. Jeff B wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
I have upgraded... to 3.70 (latest) and I have hard reset it too...
I monitor its behaviour till the end of the week, and lt you know! The email still flows..... ![]() Thanx anyway! Mike Noel wrote: The first thing they will have you do is upgrade the software, so you might as well do that first. Then,if the problem persists (and it probably will), call them on the phone. The email route takes too long. -- Mike Noel, Tucson, Arizona 'Men never do evil so completely and cheerfully as when they do it from religious conviction.' -Blaise Pascal "Alexandros" wrote in message oups.com... I have a GPS 296 recently bought - August 2005. Its problem is that occasionaly does not power on - while is working with battery - and needs to take out and re-insert the battery. I emailed Garmin but no answer yet... Any suggestions? Mike Noel wrote: I had a similar problem with my 296 except that is would turn itself off in the air. I sent it in and Garmin ended up calling it corrupted user data. After they purged the stored data, it worked OK for a while. When it started doing it again the Garmin tech had me clear the data by removing and re-inserting the battery, then holding down three buttons to give it a lobotomy. It's working OK for now, but I suspect I will have to kill the user data again sometime to re-fix it. "Maule Driver" wrote in message . com... No loss of signal... but I just sent my 396 in for service. Long story short -it would just stop working for no apparent reason. Screen would go black. Only way to restart was with a battery re-insert. The only apparent pattern it that it would never happen in the a/c. Only on the ground. Swapped everything except for the stick attenna which I used 100% on the ground and 0% in air. So back it goes for repair. Jeff B wrote: Has anyone experienced significant "loss of signal" hiccups with their new 396?? Since getting ours a few months ago, we have had several...some lasting 15-20 minutes. System shutdowns/start ups may or may not re-initialize it. THe antenna is unobstructed and in plain view of the sky. An older Garmin is still in our plane and works fine so its not some GPS system glitch. I've thought about re-installing the software. There is a new upgrade on the Garmin site so it wouldn't hurt, but none of the fixes address any "loss of signal" problems. Any similar experiences out there??? Thanks!!! |
I had the same problem with my 296, Garmin released a pacth that fixed
this problem up; I guess they'll do the same for the 396; I am considering buying one, if anybody knows where to get a good trade-in deal 296/396 please let me know Thks Hughes |
Hi Hughes - Mine is rhe 296 also! can you assist me how to find the
patch for me too? |
http://www.garmin.com/support/collec...t=010-00356-00
"Alexandros" wrote in message ups.com... Hi Hughes - Mine is rhe 296 also! can you assist me how to find the patch for me too? |
Hello Janice! I already have 3.70 version and the problem exists!
Contact Garmin, they'll trouble shoot with you.
I hope so
![]() I have emailed them and waiting.... |
Garmin 396 Glitch?? | Jeff B | Piloting | 55 | November 11th 05 08:19 PM |
Garmin 96c glitch? | Barry | Piloting | 2 | January 11th 05 09:11 PM |
Garmin 96c glitch? | Barry | General Aviation | 0 | January 11th 05 06:27 AM |
Garmin 96c glitch? | Barry | Rotorcraft | 0 | January 11th 05 06:24 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
