i'm studying for my private license and i am a bit confused about this
high to low, look out below. the way I see it: imagine an altimeter sitting at sea level. lets say the atomspheric pressure at the location of the altimeter is "10" (no units, just for simplicity). now lets say you set the altimeter to "10". so now the altimeter reads "0 feet" now decrease the temperature of the air surrounding the altimeter, and since the colder air gets the more dense it gets, the atmospheric pressure goes up. the altimeter doesnt know this. all it sees is an increase in pressure, which it thinks means an decrease in altitude, so it indicates say "-10 feet". this is directly contrary to the "high to low look out below" because the altimeter is telling you you are 10 feet lower than you are, which is not what that saying is implying. SO WHATS THE DEAL? |
ups.com... [...] SO WHATS THE DEAL? The deal is that this is a great example of why one needs to be very careful about using mnemonics. They are memory devices, not physics lessons. The phrase "high to low, look out below" applies to both temperature and pressure, for different reasons. You have mistakenly applied the physics of the pressure situation to a change in temperature, combining the two situations when in fact the mnemonic really assumes that you are holding temperature constant when you change pressure, or vice a versa. In both cases, the issue is easier to understand if you can think about flying at a constant pressure, rather than a constant altitude. This is, of course, what we actually do when we fly, assuming the altimeter setting isn't changed. All the altimeter knows is pressure, so assuming we fly at a constant indication on the altimeter, we are flying at a constant pressure. What this means is that as the actual pressure levels change in height, so does the airplane. For a given barometric pressure, a higher altimeter setting results in a greater actual height above ground. The same thing is true for higher temperature. You've already shown why it's true for a higher altimeter setting, but just to review... Your actual altitude is proportional to the difference between the barometric pressure at your current position and the barometric pressure at the ground below you (always higher than your current position's pressure). If the altimeter is set with too high a setting, your indicated altitude will be too high, and if the altimeter is set too low, the indicated altitude will be too low. This means that if you fly from high pressure to low, the altimeter setting will be too high, resulting in an indicated altitude higher than actual. You can see why thinking you are higher than you are might be bad. In the temperature case, it's because temperature affects how quickly the pressure actually changes with altitude. The higher the temperature, the farther apart two given barometric pressures will be vertically. It's as if the atmosphere is made up of layers of pressures, and higher temperature makes those layers expand away from each other. Conversely, as the temperature goes down, those layer get closer and more compact. Those same two given barometric pressures wind up nearer each other vertically. The altimeter only indicates correctly at a specific temperature. When the temperature is higher than that, the altimeter indicates too low (because the pressure layers have expanded apart), and when the temperature is lower than that, the altimeter indicates too high. And of course again, an altimeter that indicates too high is not good. The mnemonic applies best to the pressure case, as it's easy to see how flying from an area of high pressure to an area of low pressure might be an issue. In addition, in the pressure case it applies mainly to the situation when you actually change position without resetting the altimeter (so it fits the wording of the mnemonic reasonably well). In the case of temperature, the error exists regardless. So in that respect, the mnemonic is misleading. It might be a useful way to remember the issue, but it might mislead someone into thinking the hazard exists only when one starts in an area of higher temperature and flies to an area of lower temperature. That's not actually the case though. The real problem is simply that the altimeter is calibrated assuming a standard atmosphere, with a constant mapping from pressure change to altitude change when in fact a real atmosphere varies this mapping according to temperature. If you are flying in an area of cold air, the indicated altitude (except right on the ground) will always be higher than your actual altitude, assuming you're using the correct altimeter setting. It's not the act of flying from a warmer area to a colder area, it's the act of flying in a colder-than-standard area, period. Hope that helps. Pete |
On Fri, 11 Nov 2005 04:17:27 GMT, George Patterson
wrote: No, it's not contrary. The "high to low" means a flight from an area of high pressure to low pressure, not high temperature to low temperature. When you decreased the temperature, you increased the pressure, which means you're going from low to high. I thought at the time, and I am even more convinced today, that the solution to all this stuff is fly VFR in daylight! (I appreciate that this isn't a great deal of help on the written exam or the checkflight, but the poster might keep it in mind for the future ![]() -- all the best, Dan Ford email: usenet AT danford DOT net Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
George Patterson wrote:
No, it's not contrary. The "high to low" means a flight from an area of high pressure to low pressure, not high temperature to low temperature. When you decreased the temperature, you increased the pressure, which means you're going from low to high. Actually Geoerge, it works for temperature as well as pressure. Going to a colder than standard pressure causes your altimeter to read high as well. |
i'm studying for my private license and i am a bit confused about this high to low, look out below. the way I see it: imagine an altimeter sitting at sea level. lets say the atomspheric pressure at the location of the altimeter is "10" (no units, just for simplicity). now lets say you set the altimeter to "10". so now the altimeter reads "0 feet" now decrease the temperature of the air surrounding the altimeter, and since the colder air gets the more dense it gets, the atmospheric pressure goes up. the altimeter doesnt know this. all it sees is an increase in pressure, which it thinks means an decrease in altitude, so it indicates say "-10 feet". this is directly contrary to the "high to low look out below" because the altimeter is telling you you are 10 feet lower than you are, which is not what that saying is implying. SO WHATS THE DEAL? You are arbitrarily changing the pressure due to decreased temperature. IF that actually happens you are correct. But temperature can decrease without increased pressure. That's why "cold or low, look out below" is correct. If everything else stays the same except temperature drops, you will be lower than indicated. If only the pressure drops, you will be lower than indicted. If both decrease you will be much lower than indicated. If one drops and the other increases, ??????, You are overthinking the problem. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
Next time a big low pressure system moves through, go sit in a plane
and check the altimeter. It should read HIGHER than the field elevation. The altimeter is reacting to a decrease in pressure, which it registers as an increase in altitude. Now instead of sitting on the ground, imagine that you had *flown* from a higher pressure region to a lower pressure region while trying to maintain a constant altitude. You would have compensated for the (false) indication of increased altitude (actually you were just moving from high pressure to low pressure) by lowering the nose ever so slightly and actually *losing* altitude. Thus "high to low, look out below". And forget all the stuff others have posted about temperature. That does nothing but confuse the issue. Jim Rosinski wrote: now decrease the temperature of the air surrounding the altimeter, and since the colder air gets the more dense it gets, the atmospheric pressure goes up. the altimeter doesnt know this. all it sees is an increase in pressure, which it thinks means an decrease in altitude, so it indicates say "-10 feet". this is directly contrary to the "high to low look out below" because the altimeter is telling you you are 10 feet lower than you are, which is not what that saying is implying. SO WHATS THE DEAL? |
"jim rosinski" wrote in message
oups.com... And forget all the stuff others have posted about temperature. That does nothing but confuse the issue. The issue is already confused. People like you who want to pretend it's not only serve to confuse it even more. Forget "all the stuff others have posted about temperature" at your own peril. It's every bit as important an altimeter error as that caused by changes in pressure. |
| High Voltage | Jim Rosinski | Piloting | 7 | October 16th 04 11:48 PM |
| Viagra and the Mile High Club | Cub Driver | Piloting | 17 | May 28th 04 10:22 PM |
| FS2004: Ceilings/visibility too high | ajohnson | Simulators | 2 | March 15th 04 11:55 AM |
| High DPI pictures of clouds | BoDEAN | Piloting | 2 | March 5th 04 01:07 PM |
| AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 10:47 PM |
