We've got one engine on the Aztec that has 1850 SMOH, but all cylinders are
less than 700 hours since overhaul. Our game plan (for now) is to do a bottom end IRAN plus cam when it becomes necessary. Of course, this could all change at any moment. Jim wrote in message ... Maule Driver wrote: : Based on the appearance of metal after 1,100 hours (filings in the : filter and doubling of FE content in 36 hour oil analysis), I'm having : my Lycoming o-360 taken apart. Two major choices to make: : 1) Overhaul or 'look, see, fix'. That is, I could just go for an : overhaul (est $12,000 for 2,000 hours) or LSF (guesstimate $6,000k for : 900 hours). Of course there may not be a choice... : 2) Shop selection. My mechanic is somewhat shop agnostic - they work : with Signature in Ohio and Mattituck. Depending on who does the work, the word "overhaul" means different things to different people. In a regulatory sense, it's quite specific (e.g. accessories must be overhauled, etc). Realistically, if you're splitting the case halves anyway, you might as well do the "difficult" part of the overhaul as part of your exploratory. Send the steel parts off to have the magnafluxed, and replace all the bottom end parts you need to. Think hard about the cam if it (unlikely) doesn't *need* to be replaced.... probably want to anyway. In any event, a quickie bottom-end "overhaul" isn't that expensive. I wouldn't do the jugs or accessories if not necessary... they're easy to do on the plane later. I'm sure other people have differing opinions... ranging from leave it alone to getting a factory new. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Maule Driver wrote:
: I think you are referring to the corrosion AD for o-360s with a CS prop? : That particular one doesn't apply to me since I have a fixed prop with : a solid crank. I was going to mention that but figured you already knew. IIRC, one can treat the hollow crank to have it terminate the AD. With a solid crank that one should be fine. There is, of course, the sintered iron oil pump AD... and a rash the connecting rod bolts from Superior IIRC. Seriously though... if you've got the bottom end apart, you'd be silly not to spend the extra bit to get the steel parts magnafluxed. That's about the only additional thing you'd have to do aside from what's *required* after you split the cases, but it's enough to call it a bottom overhaul. From the sounds of the metal, you'll likely be buying a new cam. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Did you ever find out the source of the metal? Cam seems to be the
speculative consensus. I'd love to do a reman but can't make financial sense out of it in my situation. Otis Winslow wrote: I had a similar situation where my O360 (around 1000 hrs) started making metal. I opted for a factory reman in the interest of minimal down time. Took a couple weeks to get it to me and my mechanic to get it hung on the plane. |
On Fri, 06 Jan 2006 14:19:55 GMT, Michelle
wrote: Maule Driver wrote: Based on the appearance of metal after 1,100 hours (filings in the filter and doubling of FE content in 36 hour oil analysis), I'm having my Lycoming o-360 taken apart. Two major choices to make: 1) Overhaul or 'look, see, fix'. That is, I could just go for an overhaul (est $12,000 for 2,000 hours) or LSF (guesstimate $6,000k for 900 hours). Of course there may not be a choice... 2) Shop selection. My mechanic is somewhat shop agnostic - they work with Signature in Ohio and Mattituck. Your thoughts and opinions are valued. The last time I talked to Mattituck they could have cared less if they got our business. Columbia Aircraft in PA, sorry I can't remember exactly where they are located. They seemed to be eager for our business and had all the right toys. Michelle And the last time I talked Mattituck, they were MORE expensive than a Lycoming factory O/H. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Fri, 06 Jan 2006 20:40:36 GMT, Maule Driver
wrote: Did you ever find out the source of the metal? Cam seems to be the speculative consensus. I'd love to do a reman but can't make financial sense out of it in my situation. Otis Winslow wrote: I had a similar situation where my O360 (around 1000 hrs) started making metal. I opted for a factory reman in the interest of minimal down time. Took a couple weeks to get it to me and my mechanic to get it hung on the plane. When I looked into this in 2000, the only differences between a Lycoming factory O/H vs reman were the price, logbook, and an extra year on the warranty. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Assuming your cam and lifters have gone bad -
Maybe if your top ends have all been good including oil consumption, you could go the barnyard repair approach & split the case, replace the main & rod bearings (they are almost certainly going to be contaminated), the cam and followers, and thoroughly flush the oil galleries and crankshaft oil ports before reassembling. Might it even be practical to leave the pistons in the jugs so that you wouldn't have to deglaze and re-ring it? If the engine is equipped with a full flow filter it is possible that even bearing replacement might not be necessary, but if the parts are not that expensve I can't imagine that to be practical. There might be a requirement for $ rod $ bolt $ replacement on any Lycoming di$a$$embly. If it isn't mandatory though it I wouldn't replace them. This assumes the debris hasn't chewed up your oil pump or caused any pistons to score in the bores. No matter what you do, cleaning up the debris is a very important part of whatever you end up doing. This is not an A&P thoughts though..... |
![]() Maule Driver wrote: Based on the appearance of metal after 1,100 hours (filings in the filter and doubling of FE content in 36 hour oil analysis), I'm having my Lycoming o-360 taken apart. Two major choices to make: 1) Overhaul or 'look, see, fix'. Your thoughts and opinions are valued. When my IO-540 did that at about the same TSMOH, the fact that labor costs to tear down and fix vs to O/H were the same impressed me. Only thing that changes is parts cost. At more than 50% time gone to TBO, I opted for OH. |
Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 03:11 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Engine Sizing and Selection | Toks Desalu | Home Built | 27 | November 6th 03 05:24 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
