My Zaon XRX PCAS just arrived. I did a test run last weekend (1/15) in
friend's pressurized Golden Eagle (Cessna 420) and Bonanza A36 in the trip to Big Bear City, both planes have Garmin 530/330 TIS/Mode S transponder (like 24Y's) for comparison purpose. I believe this review is the first one you can find over the internet. The Zaon XRX was first on the market on 11/31/2005, however, according to my knowledge, the shipment wasn't begin till 12/15/2005. XRX tracks up to 10 targets and displays the top 3 threats (in display mode-A) on a LCD matrix display. It displays the threats direction (in 45 degree quadrant) , current altitude, climbing or descending, and the estimated distance. The traffic is updated in real time. The good thing about XRX is that it displays traffic not just in the terminal area but any where within a radar coverage, and in area where TCAS equiped airplanes in the vicinity (so surrounding aircrafts respond to the TCAS interrogation). Mode-S transponder can only display traffic information in terminal area (such as SoCal) because Mode-S receives information from the terminal control radar that sends out the host traffic information. For example, Mode-S cannot display traffic when you fly out of SoCal basin...say on the way to Vegas but you are in the center radar coverage. However, XRX relies on the target airplanes with an operational transponder. If an airplane does not have transponder turned on, XRX won't be able to track it. Mode-S will probably display primary target (without altitude) because terminal radar will probably depict this traffic in its TIS broadcast. XRX contains 4 directional antennas (for traffic detection), a digital compass for detecting the plane's heading (it can then correctly point out the threat's direction). It also has a digital altimeter to compare with the plane's mode-C transponder. That will reduce the error caused by plane's shadow when you over fly water or some reflective surface. The Zaon XRX worked as advertised out of box. When we waited in the hold-short line, I could see the 172 took off before us correctly depicted on the XRX with its direction and altitude. When we took off, the target airplane's directions was updated in real time and displayed correctly. I would say its performance is comparable to a Mode-S TIS system. When we climb out higher, however, because of the pressurized cabin, the XRX thought we were still in 1000 feet so it stopped displays traffic until I turned on the pressurized airplane mode. In the pressurized cabin mode, XRX will only use the airplane's transponder instead of use the built-in altimeter for its altitude reference. When I flew back in the non-pressurized Bonanza, it displayed the traffic correctly in the vicinity. The female voice will warn you when a threat is closer enough. However, there are several first look weakness in this test but I don't think they are big issues: 1. It does not display the traffics behind the plane as good as traffic in front of plane or on the side. I think it because the metal blocks the rare view. XRX has a menu that allows you to select the type of aircraft (composit a/c, high-wing a/c, low-wing a/c) so it estimates more accurately. By comparing with the TIS, XRX tends to estimate the distance closer than it is for the traffic behind you. However, I don't think it is a big deal since most of traffic behind you has little threats. 2. XRX does not remember the configuration setting after the power off. Because of this, you have to re-select the type of aircraft everytime you turn on the XRX. Also, you have to set the display mode if you prefer to have Garmin 530-like radar screen (circle). And range, warning distance..etc. It always resets to default setting everytime it turns on. I think it is a bug in the firmware that cause it, because XRX does remember many system settings such as altimeter calibration and heading calibration values beyond the power-reset. The good thing is that since Xaon supports the firmware upgrade, if there is a firmware upgrade, you can send in the unit back and let them upgrade the firmware for you. Another note is that XRX works well with its default setting. Even without selecting the type of aircraft, it still displays the traffic pretty well. I think XRX is a very good and economical alternative of a Mode-S (one third of price of mode-S, exlcuding installation labor). Since FAA is no longer supporting mode-S TIS and is going to gradually disable the mode-S TIS in the next several years, plus the XRX can detect traffic over the non-terminal areas, XRX is a desirable choice until the FAA fully deploys ADS-B in the next 10 years. It helps you a lot to avoid the traffic since you can spot the traffic much easier. Comparing to altitude and range only model (such as Monroy ATD-300), it really is a break through of the portable passive traffic detection system. If you want to know what is PCAS, just goto their website at http://www.zaonflight.com/ |
I received mine about a week ago but I haven't had a chance to fly with
it yet, so I was interested to read about it's performance in-flight. Interesting how when it's turned on, the arrays inside the unit whirl and revolve, obviously to point the directional antennas in as many directions as possible to detect interrogations. According to Zaon's website, they are going to release a panel installation. I'm sure this will require external antennas. They'll give the unit a better view of threats behind your metal aircraft. Also included are interface options to output traffic data via RS-232 to AnywhereMap or True Flight. The True Flight system is a seperate display which shows higher resolution quadrant direction, has flight path tracking, altitude trend and a transponder altitude monitor. http://www.aviationsafety.com/traffic_alert1.htm I am amazed at the tiny size of the unit, it's smaller overall than the previous model VRX even with the antenna enclosure on top. It is, as you say, a better alternative to Mode S. Also ADS-B Out will only provide more traffic information to ATC. Fully operational ADS-B In, when implemented would obviously provide the highest level of traffic awareness to the pilot. The XRX provides a lot of this information right now for a fraction of the cost of TCAS and current implementations of ADS-B. |
Also to the a/c with ADS-B UAT receiver installed. ADS-B UAT receiver does not need ground station to receive other ADS-B Out transmission....but the price is very high now however, the price can be reduced dramatically since UAT is almost functional equavelent to a now-a-day all inclusive cellphone...with a GPS, a transceiver and color LCD display. I have seem a demo Capston system display live traffics in Alaska in a notebook 2 years ago. It can be implemented very easily. the arrays inside the unit whirl and revolve, I think the 4 directional antennas are fixed. The sound you heard was the heat sink fan that disburses the heat generated from the CPU chipset to its case. |
English as a second language? |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 28th 04 12:49 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
