Has anyone had any experience with GEL-GLOSS cleaner on their plane? I
think they sell it at Lowe's and some other stores. Some guy during the standard rainy afternoon hangar talk said he uses it on his plane and it works great as a cleaner and is much cheaper than aviation cleaner. Any thoughts from anyone? Thanks. |
"John Doe" wrote in message ink.net... Has anyone had any experience with GEL-GLOSS cleaner on their plane? I think they sell it at Lowe's and some other stores. Some guy during the standard rainy afternoon hangar talk said he uses it on his plane and it works great as a cleaner and is much cheaper than aviation cleaner. Any thoughts from anyone? Thanks. Some marine gel coat cleaners are very abrasive. Don't know about the product you are talking about but I would be careful. It might clean well at the cost of rapidly grinding away your paint. Gel coats are much thicker than paint. |
"JD" == John Doe writes:
JD Some guy during the standard rainy afternoon hangar talk said JD he uses it on his plane and it works great as a cleaner and is JD much cheaper than aviation cleaner. JD Any thoughts from anyone? Well, yes. I wouldn't use any non-aviation cleaner on an airplane. They surely aren't tested for aircraft or aluminum and might well end up corroding your plane. |
| Thread Tools | |
| Display Modes | |
| Simple Green Aircraft Cleaner | Dan Luke | Owning | 8 | August 3rd 05 01:49 AM |
| Upholstery Cleaner? | Alan Bloom | Owning | 3 | August 21st 04 12:17 AM |
| Oil/Bug cleaner | tony roberts | Owning | 3 | June 2nd 04 02:28 AM |
| Plexiglas cleaner/ polish | eddie | Owning | 9 | August 1st 03 01:59 AM |
| Wing cleaner | Viperdoc | Owning | 27 | July 15th 03 06:03 PM |
