Gas
Old January 21st 06, 01:48 AM posted to rec.aviation.homebuilt
Default Gas
How well does auto gas mix with 100LL?
LJ
Old January 21st 06, 01:56 AM posted to rec.aviation.homebuilt
Default Gas
I've had no problem with it. I've done a fill with 100LL every ~4 fill-ups to
keep up the lead levels. This time of year, I run 100% 100LL because of
stability. Never had a problem with mixing the fuels.
Old January 21st 06, 02:50 AM posted to rec.aviation.homebuilt
Default Gas
Thank Ron!
I have the Rotax,But have been using 100LL.Thanks Again!
LJ
Old January 21st 06, 03:55 AM posted to rec.aviation.homebuilt
Default Gas
LJ,
How many hours do you have on your Rotax? I've heard that running
100LL requires more frequent oil, filter, and spark plug changes. What
is your experience? So far, I've been avoiding avgas, and have managed
to run mine 120 hours on mogas exclusively.
tom
Old January 21st 06, 05:55 AM posted to rec.aviation.homebuilt
Default Gas
Thank Ron!
Ummm, my experience on a Continental only, so I'm not sure how it relates to the
Rotax. I don't believe the fuel chemistry is adversely affected, but it does
mean you've got leaded fuel. If the Rotax can stand lead, you're probably OK.
Old January 22nd 06, 01:05 AM posted to rec.aviation.homebuilt
Default Gas
about 150hr,I changed plugs at 100hr.they were leaded up but were firing
ok.On the oil part of lead,I havn't had the same problem.Maybe-becaues
I changed oil more often.(My plane is one of the Caldwell,Id builders group.
LJ,
tom
